Xorg Problem
Diskutiere Xorg Problem im Gentoo Forum im Bereich Linux Distributionen; Hallo zusammen, ich habe ein Problem mit meinem Xorg. Wenn ich in der Console bin und startx eingeben, startet mein Xserver wunderbar. Mit...
  1. #1 Blacksmoker, 03.04.2005
    Blacksmoker
    Blacksmoker Grünschnabel
    03.04.2005
    Hallo zusammen,
    Mit meinem Mplayer kann ich wunderbar Musik hören. Nur wenn ich mit meinem Mplayer Videos gucken möchte, dann hängt mein kompletter Xorg.
    Ich habe ein EPIA M10000.
    Das ist meine xorg.conf:
    # File generated by xorgconfig.
    # Copyright 2004 The X.Org Foundation
    # Permission is hereby granted, free of charge, to any person obtaining a
    # copy of this software and associated documentation files (the "Software"),
    # to deal in the Software without restriction, including without limitation
    # the rights to use, copy, modify, merge, publish, distribute, sublicense,
    # and/or sell copies of the Software, and to permit persons to whom the
    # Software is furnished to do so, subject to the following conditions:
    # The above copyright notice and this permission notice shall be included in
    # all copies or substantial portions of the Software.
    # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
    # The X.Org Foundation BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
    # WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
    # OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
    # SOFTWARE.
    # Except as contained in this notice, the name of The X.Org Foundation shall
    # not be used in advertising or otherwise to promote the sale, use or other
    # dealings in this Software without prior written authorization from
    # The X.Org Foundation.
    # Refer to the xorg.conf(5x) man page for details about the format of
    # this file.
    # Module section -- this  section  is used to specify
    # which dynamically loadable modules to load.
    Section "Module"
    # This loads the DBE extension module.
        Load        "dbe"  	# Double buffer extension
    # This loads the miscellaneous extensions module, and disables
    # initialisation of the XFree86-DGA extension within that module.
        SubSection  "extmod"
          Option    "omit xfree86-dga"   # don't initialise the DGA extension
        EndSubSection
    # This loads the font modules
        Load        "type1"
    #    Load        "speedo"
        Load        "freetype"
    #    Load        "xtt"
    # This loads the GLX module
    #    Load       "glx"
    # This loads the DRI module
    #    Load       "dri"
    EndSection
    # Files section.  This allows default font and rgb paths to be set
    Section "Files"
    # The location of the RGB database.  Note, this is the name of the
    # file minus the extension (like ".txt" or ".db").  There is normally
    # no need to change the default.
        RgbPath	"/usr/X11R6/lib/X11/rgb"
    # Multiple FontPath entries are allowed (which are concatenated together),
    # as well as specifying multiple comma-separated entries in one FontPath
    # command (or a combination of both methods)
        FontPath   "/usr/share/fonts/misc/"
        FontPath   "/usr/share/fonts/TTF/"
        FontPath   "/usr/share/fonts/Type1/"
    #    FontPath   "/usr/share/fonts/CID/"
        FontPath   "/usr/share/fonts/75dpi/"
        FontPath   "/usr/share/fonts/100dpi/"
        FontPath   "/usr/share/fonts/local/"
    #    FontPath   "/usr/share/fonts/Speedo/"
    #    FontPath   "/usr/share/fonts/TrueType/"
    #    FontPath   "/usr/share/fonts/freefont/"
    # The module search path.  The default path is shown here.
    #    ModulePath "/usr/X11R6/lib/modules"
    EndSection
    # Server flags section.
    Section "ServerFlags"
    # Uncomment this to cause a core dump at the spot where a signal is
    # received.  This may leave the console in an unusable state, but may
    # provide a better stack trace in the core dump to aid in debugging
    #    Option "NoTrapSignals"
    # Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
    # (where n is 1 through 12).  This allows clients to receive these key
    # events.
    #    Option "DontVTSwitch"
    # Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
    # This allows clients to receive this key event.
    #    Option "DontZap"
    # Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
    # sequences.  This allows clients to receive these key events.
    #    Option "Dont Zoom"
    # Uncomment this to disable tuning with the xvidtune client. With
    # it the client can still run and fetch card and monitor attributes,
    # but it will not be allowed to change them. If it tries it will
    # receive a protocol error.
    #    Option "DisableVidModeExtension"
    # Uncomment this to enable the use of a non-local xvidtune client.
    #    Option "AllowNonLocalXvidtune"
    # Uncomment this to disable dynamically modifying the input device
    # (mouse and keyboard) settings.
    #    Option "DisableModInDev"
    # Uncomment this to enable the use of a non-local client to
    # change the keyboard or mouse settings (currently only xset).
    #    Option "AllowNonLocalModInDev"
    EndSection
    # Input devices
    # Core keyboard's InputDevice section
    Section "InputDevice"
        Identifier	"Keyboard1"
        Driver	"kbd"
    # For most OSs the protocol can be omitted (it defaults to "Standard").
    # When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
    # uncomment the following line.
    #    Option     "Protocol"      "Xqueue"
        Option "AutoRepeat" "500 30"
    # Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
    #    Option	"Xleds"      "1 2 3"
    #    Option "LeftAlt"     "Meta"
    #    Option "RightAlt"    "ModeShift"
    # To customise the XKB settings to suit your keyboard, modify the
    # lines below (which are the defaults).  For example, for a non-U.S.
    # keyboard, you will probably want to use:
    #    Option "XkbModel"    "pc105"
    # If you have a US Microsoft Natural keyboard, you can use:
    #    Option "XkbModel"    "microsoft"
    # Then to change the language, change the Layout setting.
    # For example, a german layout can be obtained with:
    #    Option "XkbLayout"   "de"
    # or:
    #    Option "XkbVariant"  "nodeadkeys"
    # If you'd like to switch the positions of your capslock and
    # control keys, use:
    #    Option "XkbOptions"  "ctrl:swapcaps"
    # These are the default XKB settings for Xorg
    #    Option "XkbRules"    "xorg"
    #    Option "XkbLayout"   "us"
    #    Option "XkbVariant"  ""
    #    Option "XkbOptions"  ""
    #    Option "XkbDisable"
        Option "XkbModel"	"pc101"
        Option "XkbVariant"	"de"
    EndSection
    # Core Pointer's InputDevice section
    # Identifier and driver
        Identifier	"Mouse1"
        Driver	"mouse"
        Option "Protocol"    "Auto"
        Option "Device"      "/dev/mouse"
    # Mouse-speed setting for PS/2 mouse.
    #    Option "Resolution"	"256"
    # When using XQUEUE, comment out the above two lines, and uncomment
    # the following line.
    # Baudrate and SampleRate are only for some Logitech mice. In
    # almost every case these lines should be omitted.
    #    Option "BaudRate"	"9600"
    #    Option "SampleRate"	"150"
    # Emulate3Buttons is an option for 2-button Microsoft mice
    # Emulate3Timeout is the timeout in milliseconds (default is 50ms)
    #    Option "Emulate3Buttons"
    #    Option "Emulate3Timeout"    "50"
    # ChordMiddle is an option for some 3-button Logitech mice
    #    Option "ChordMiddle"
    EndSection
    # Other input device sections
    # this is optional and is required only if you
    # are using extended input devices.  This is for example only.  Refer
    # to the xorg.conf man page for a description of the options.
    # Section "InputDevice"
    #    Identifier  "Mouse2"
    #    Driver      "mouse"
    #    Option      "Protocol"      "MouseMan"
    #    Option      "Device"        "/dev/mouse2"
    # EndSection
    #    Identifier "spaceball"
    #    Driver     "magellan"
    #    Option     "Device"        "/dev/cua0"
    # EndSection
    #    Identifier "spaceball2"
    #    Driver     "spaceorb"
    # EndSection
    #    Identifier "touchscreen0"
    #    Driver     "microtouch"
    #    Option     "Device"        "/dev/ttyS0"
    #    Option     "MinX"          "1412"
    #    Option     "MaxX"          "15184"
    #    Option     "MinY"          "15372"
    #    Option     "MaxY"          "1230"
    #    Option     "ScreenNumber"  "0"
    #    Option     "ReportingMode" "Scaled"
    #    Option     "ButtonNumber"  "1"
    #    Option     "SendCoreEvents"
    # EndSection
    #    Identifier "touchscreen1"
    #    Driver     "elo2300"
    #    Option     "MinX"          "231"
    #    Option     "MaxX"          "3868"
    #    Option     "MinY"          "3858"
    #    Option     "MaxY"          "272"
    #    Option     "ButtonThreshold"       "17"
    # EndSection
    # Monitor section
    # Any number of monitor sections may be present
    Section "Monitor"
        Identifier  "My Monitor"
    # HorizSync is in kHz unless units are specified.
    # HorizSync may be a comma separated list of discrete values, or a
    # comma separated list of ranges of values.
    # NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
    # USER MANUAL FOR THE CORRECT NUMBERS.
        HorizSync   31.5 - 35.1
    #    HorizSync	30-64         # multisync
    #    HorizSync	31.5, 35.2    # multiple fixed sync frequencies
    #    HorizSync	15-25, 30-50  # multiple ranges of sync frequencies
    # VertRefresh is in Hz unless units are specified.
    # VertRefresh may be a comma separated list of discrete values, or a
        VertRefresh 50-70
    EndSection
    # Graphics device section
    # Any number of graphics device sections may be present
    # Standard VGA Device:
    Section "Device"
        Identifier	"Standard VGA"
        VendorName	"Unknown"
        BoardName	"Unknown"
    # The chipset line is optional in most cases.  It can be used to override
    # the driver's chipset detection, and should not normally be specified.
    #    Chipset	"generic"
    # The Driver line must be present.  When using run-time loadable driver
    # modules, this line instructs the server to load the specified driver
    # module.  Even when not using loadable driver modules, this line
    # indicates which driver should interpret the information in this section.
        Driver     "vga"
    # The BusID line is used to specify which of possibly multiple devices
    # this section is intended for.  When this line isn't present, a device
    # section can only match up with the primary video device.  For PCI
    # devices a line like the following could be used.  This line should not
    # normally be included unless there is more than one video device
    # intalled.
    #    BusID      "PCI:0:10:0"
    #    VideoRam	256
    #    Clocks	25.2 28.3
    EndSection
    # Device configured by xorgconfig:
    Section "Device"
        Identifier  "My Video Card"
        Driver      "via"
    	# unsupported card
        #VideoRam    32768
        # Insert Clocks lines here if appropriate
    EndSection
    # Screen sections
    # Any number of screen sections may be present.  Each describes
    # the configuration of a single screen.  A single specific screen section
    # may be specified from the X server command line with the "-screen"
    # option.
    Section "Screen"
        Identifier  "Screen 1"
        Device      "My Video Card"
        Monitor     "My Monitor"
        DefaultDepth 16
        Subsection "Display"
            Depth       8
            Modes       "1280x1024" "1024x768" "800x600" "640x480"
            ViewPort    0 0
        EndSubsection
            Depth       16
            ViewPort    0 0
        EndSubsection
            Depth       24
            ViewPort    0 0
        EndSubsection
    EndSection
    # ServerLayout sections.
    # Any number of ServerLayout sections may be present.  Each describes
    # the way multiple screens are organised.  A specific ServerLayout
    # section may be specified from the X server command line with the
    # "-layout" option.  In the absence of this, the first section is used.
    # When now ServerLayout section is present, the first Screen section
    # is used alone.
    Section "ServerLayout"
    # The Identifier line must be present
        Identifier  "Simple Layout"
    # Each Screen line specifies a Screen section name, and optionally
    # the relative position of other screens.  The four names after
    # primary screen name are the screens to the top, bottom, left and right
    # of the primary screen.  In this example, screen 2 is located to the
    # right of screen 1.
        Screen "Screen 1"
    # Each InputDevice line specifies an InputDevice section name and
    # optionally some options to specify the way the device is to be
    # used.  Those options include "CorePointer", "CoreKeyboard" and
    # "SendCoreEvents".
        InputDevice "Mouse1" "CorePointer"
        InputDevice "Keyboard1" "CoreKeyboard"
    EndSection
    # Section "DRI"
    #    Mode 0666
    # EndSection
    Das ist meine Log Datei vom Xorg:
    X Window System Version 6.8.2
    Release Date: 9 February 2005
    X Protocol Version 11, Revision 0, Release 6.8.2
    Build Operating System: Linux 2.6.11-rc4-kraxel2 i686 [ELF]
    Current Operating System: Linux localhost 2.6.11-rc4-kraxel2 #13 Thu Mar 17 22:38:25 Local time zone must be set--see zic man i686
    Build Date: 16 March 2005
    	Before reporting problems, check http://wiki.X.Org
    Module Loader present
    (==) Log file: "/var/log/Xorg.0.log", Time: Sun Apr  3 11:28:53 2005
    (==) Using config file: "/etc/X11/xorg.conf"
    (==) ServerLayout "Simple Layout"
    (**) |-->Screen "Screen 1" (0)
    (**) |   |-->Monitor "My Monitor"
    (**) |   |-->Device "My Video Card"
    (**) |-->Input Device "Mouse1"
    (**) |-->Input Device "Keyboard1"
    (**) FontPath set to "/usr/share/fonts/misc/,/usr/share/fonts/TTF/,/usr/share/fonts/Type1/,/usr/share/fonts/75dpi/,/usr/share/fonts/100dpi/,/usr/share/fonts/local/"
    (**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
    (==) ModulePath set to "/usr/lib/modules"
    (WW) Open APM failed (/dev/apm_bios) (No such file or directory)
    (II) Module ABI versions:
    	X.Org ANSI C Emulation: 0.2
    	X.Org Video Driver: 0.7
    	X.Org XInput driver : 0.4
    	X.Org Server Extension : 0.2
    	X.Org Font Renderer : 0.4
    (II) Loader running on linux
    (II) LoadModule: "bitmap"
    (II) Loading /usr/lib/modules/fonts/libbitmap.a
    (II) Module bitmap: vendor="X.Org Foundation"
    	compiled for 6.8.2, module version = 1.0.0
    	Module class: X.Org Font Renderer
    	ABI class: X.Org Font Renderer, version 0.4
    (II) Loading font Bitmap
    (II) LoadModule: "pcidata"
    (II) Loading /usr/lib/modules/libpcidata.a
    (II) Module pcidata: vendor="X.Org Foundation"
    	ABI class: X.Org Video Driver, version 0.7
    Using vt 7
    (--) using VT number 7
    (II) PCI: PCI scan (all values are in hex)
    (II) PCI: 00:00:0: chip 1106,3123 card 1106,aa01 rev 00 class 06,00,00 hdr 00
    (II) PCI: 00:01:0: chip 1106,b091 card 0000,0000 rev 00 class 06,04,00 hdr 01
    (II) PCI: 00:0d:0: chip 1106,3044 card 1106,3044 rev 80 class 0c,00,10 hdr 00
    (II) PCI: 00:10:0: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
    (II) PCI: 00:10:1: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
    (II) PCI: 00:10:2: chip 1106,3038 card 1106,3038 rev 80 class 0c,03,00 hdr 80
    (II) PCI: 00:10:3: chip 1106,3104 card 1106,3104 rev 82 class 0c,03,20 hdr 00
    (II) PCI: 00:11:0: chip 1106,3177 card 1106,aa01 rev 00 class 06,01,00 hdr 80
    (II) PCI: 00:11:1: chip 1106,0571 card 1106,aa01 rev 06 class 01,01,8a hdr 00
    (II) PCI: 00:11:5: chip 1106,3059 card 1106,aa01 rev 50 class 04,01,00 hdr 00
    (II) PCI: 00:12:0: chip 1106,3065 card 1106,0102 rev 74 class 02,00,00 hdr 00
    (II) PCI: 00:14:0: chip 109e,036e card 0070,13eb rev 02 class 04,00,00 hdr 80
    (II) PCI: 00:14:1: chip 109e,0878 card 0070,13eb rev 02 class 04,80,00 hdr 80
    (II) PCI: 01:00:0: chip 1106,3122 card 1106,3122 rev 03 class 03,00,00 hdr 00
    (II) PCI: End of PCI scan
    (II) Host-to-PCI bridge:
    (II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
    (II) Bus 0 I/O range:
    	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) Bus 0 non-prefetchable memory range:
    	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
    (II) Bus 0 prefetchable memory range:
    (II) PCI-to-PCI bridge:
    (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
    (II) Bus 1 non-prefetchable memory range:
    	[0] -1	0	0xe6000000 - 0xe7ffffff (0x2000000) MX[B]
    (II) Bus 1 prefetchable memory range:
    	[0] -1	0	0xe0000000 - 0xe3ffffff (0x4000000) MX[B]
    (II) PCI-to-ISA bridge:
    (II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
    (--) PCI: (0:20:0) Brooktree Corporation Bt878 Video Capture rev 2, Mem @ 0xe8003000/12
    (--) PCI:*(1:0:0) unknown vendor (0x1106) unknown chipset (0x3122) rev 3, Mem @ 0xe0000000/26, 0xe6000000/24
    (II) Addressable bus resource ranges are
    	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) OS-reported resource ranges:
    	[0] -1	0	0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    	[1] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[2] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[3] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[4] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[5] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[6] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    (II) PCI Memory resource overlap reduced 0xe4000000 from 0xe5ffffff to 0xe3ffffff
    (II) Active PCI resource ranges:
    	[0] -1	0	0xe8004000 - 0xe8004fff (0x1000) MX[B]
    	[1] -1	0	0xe8002000 - 0xe80020ff (0x100) MX[B]
    	[2] -1	0	0xe8001000 - 0xe80010ff (0x100) MX[B]
    	[3] -1	0	0xe8000000 - 0xe80007ff (0x800) MX[B]
    	[4] -1	0	0xe4000000 - 0xe3ffffff (0x0) MX[B]O
    	[5] -1	0	0xe6000000 - 0xe6ffffff (0x1000000) MX[B](B)
    	[6] -1	0	0xe0000000 - 0xe3ffffff (0x4000000) MX[B](B)
    	[7] -1	0	0xe8003000 - 0xe8003fff (0x1000) MX[B](B)
    	[8] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[B]
    	[9] -1	0	0x0000e400 - 0x0000e4ff (0x100) IX[B]
    	[10] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
    	[11] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[B]
    	[12] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[B]
    	[13] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[B]
    	[14] -1	0	0x0000d000 - 0x0000d07f (0x80) IX[B]
    (II) Active PCI resource ranges after removing overlaps:
    (II) OS-reported resource ranges after removing overlaps with PCI:
    (II) All system resource ranges:
    	[5] -1	0	0xe8004000 - 0xe8004fff (0x1000) MX[B]
    	[6] -1	0	0xe8002000 - 0xe80020ff (0x100) MX[B]
    	[7] -1	0	0xe8001000 - 0xe80010ff (0x100) MX[B]
    	[8] -1	0	0xe8000000 - 0xe80007ff (0x800) MX[B]
    	[9] -1	0	0xe4000000 - 0xe3ffffff (0x0) MX[B]O
    	[10] -1	0	0xe6000000 - 0xe6ffffff (0x1000000) MX[B](B)
    	[11] -1	0	0xe0000000 - 0xe3ffffff (0x4000000) MX[B](B)
    	[12] -1	0	0xe8003000 - 0xe8003fff (0x1000) MX[B](B)
    	[13] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[14] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[15] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[B]
    	[16] -1	0	0x0000e400 - 0x0000e4ff (0x100) IX[B]
    	[17] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
    	[18] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[B]
    	[19] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[B]
    	[20] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[B]
    	[21] -1	0	0x0000d000 - 0x0000d07f (0x80) IX[B]
    (II) LoadModule: "dbe"
    (II) Loading /usr/lib/modules/extensions/libdbe.a
    (II) Module dbe: vendor="X.Org Foundation"
    	Module class: X.Org Server Extension
    	ABI class: X.Org Server Extension, version 0.2
    (II) Loading extension DOUBLE-BUFFER
    (II) LoadModule: "extmod"
    (II) Loading /usr/lib/modules/extensions/libextmod.a
    (II) Module extmod: vendor="X.Org Foundation"
    (II) Loading extension SHAPE
    (II) Loading extension MIT-SUNDRY-NONSTANDARD
    (II) Loading extension BIG-REQUESTS
    (II) Loading extension SYNC
    (II) Loading extension MIT-SCREEN-SAVER
    (II) Loading extension XC-MISC
    (II) Loading extension XFree86-VidModeExtension
    (II) Loading extension XFree86-Misc
    (II) Loading extension DPMS
    (II) Loading extension TOG-CUP
    (II) Loading extension Extended-Visual-Information
    (II) Loading extension XVideo
    (II) Loading extension XVideo-MotionCompensation
    (II) Loading extension X-Resource
    (II) LoadModule: "type1"
    (II) Loading /usr/lib/modules/fonts/libtype1.a
    (II) Module type1: vendor="X.Org Foundation"
    	compiled for 6.8.2, module version = 1.0.2
    (II) Loading font Type1
    (II) Loading font CID
    (II) LoadModule: "freetype"
    (II) Loading /usr/lib/modules/fonts/libfreetype.so
    (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
    	compiled for 6.8.2, module version = 2.1.0
    (II) Loading font FreeType
    (II) LoadModule: "via"
    (II) Loading /usr/lib/modules/drivers/via_drv.o
    (II) Module via: vendor="X.Org Foundation"
    	compiled for 4.3.99.902, module version = 4.1.30
    	Module class: X.Org Video Driver
    (II) LoadModule: "mouse"
    (II) Loading /usr/lib/modules/input/mouse_drv.o
    (II) Module mouse: vendor="X.Org Foundation"
    	Module class: X.Org XInput Driver
    	ABI class: X.Org XInput driver, version 0.4
    (II) LoadModule: "kbd"
    (II) Loading /usr/lib/modules/input/kbd_drv.o
    (II) Module kbd: vendor="X.Org Foundation"
    (II) via: driver for VIA chipsets: CLE266, KM400, K8M800
    (II) Primary Device is: PCI 01:00:0
    (--) Assigning device section with no busID to primary device
    (--) Chipset CLE266 found
    (II) resource ranges after xf86ClaimFixedResources() call:
    (II) resource ranges after probing:
    	[13] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
    	[14] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
    	[15] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
    	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[18] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[B]
    	[19] -1	0	0x0000e400 - 0x0000e4ff (0x100) IX[B]
    	[20] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
    	[21] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[B]
    	[22] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[B]
    	[23] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[B]
    	[24] -1	0	0x0000d000 - 0x0000d07f (0x80) IX[B]
    	[25] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
    	[26] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
    (II) Setting vga for screen 0.
    (II) Loading sub module "vgahw"
    (II) LoadModule: "vgahw"
    (II) Loading /usr/lib/modules/libvgahw.a
    (II) Module vgahw: vendor="X.Org Foundation"
    	compiled for 6.8.2, module version = 0.1.0
    (**) VIA(0): Depth 16, (--) framebuffer bpp 16
    (==) VIA(0): RGB weight 565
    (==) VIA(0): Default visual is TrueColor
    (==) VIA(0): Using HW cursor
    (==) VIA(0): Not using video BIOS to set modes
    (II) Loading sub module "int10"
    (II) LoadModule: "int10"
    (II) Loading /usr/lib/modules/linux/libint10.a
    (II) Module int10: vendor="X.Org Foundation"
    (II) VIA(0): Primary V_BIOS segment is: 0xc000
    (II) Loading sub module "vbe"
    (II) LoadModule: "vbe"
    (II) Loading /usr/lib/modules/libvbe.a
    (II) Module vbe: vendor="X.Org Foundation"
    	compiled for 6.8.2, module version = 1.1.0
    (II) VIA(0): VESA BIOS detected
    (II) VIA(0): VESA VBE Version 3.0
    (II) VIA(0): VESA VBE Total Mem: 32768 kB
    (II) VIA(0): VESA VBE OEM: VIA CLE266
    (II) VIA(0): VESA VBE OEM Software Rev: 0.0
    (--) VIA(0): Chipset: "CLE266"
    (--) VIA(0): Chipset Rev.: 3
    (II) VIA(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
    (--) VIA(0): mapping MMIO @ 0xe6000000 with size 0x9000
    (--) VIA(0): mapping BitBlt MMIO @ 0xe6200000 with size 0x10000
    (==) VIA(0): Using gamma correction (1.0, 1.0, 1.0)
    (--) VIA(0): videoram =  32768k
    (II) Loading sub module "i2c"
    (II) LoadModule: "i2c"
    (II) Loading /usr/lib/modules/libi2c.a
    (II) Module i2c: vendor="X.Org Foundation"
    	compiled for 6.8.2, module version = 1.2.0
    (II) VIA(0): I2C bus "I2C bus 1" initialized.
    (II) VIA(0): I2C bus "I2C bus 2" initialized.
    (II) Loading sub module "ddc"
    (II) LoadModule: "ddc"
    (II) Loading /usr/lib/modules/libddc.a
    (II) Module ddc: vendor="X.Org Foundation"
    (II) Reloading /usr/lib/modules/libddc.a
    (II) VIA(0): VESA VBE DDC supported
    (II) VIA(0): VESA VBE DDC Level 2
    (II) VIA(0): VESA VBE DDC transfer in appr. 1 sec.
    (II) VIA(0): VESA VBE DDC read failed
    (II) VIA(0): I2C device "I2C bus 1:ddc2" registered at address 0xA0.
    (II) VIA(0): I2C device "I2C bus 1:ddc2" removed.
    (--) VIA(0): No DDC signal
    (II) VIA(0): My Monitor: Using hsync range of 31.50-35.10 kHz
    (II) VIA(0): My Monitor: Using vrefresh range of 50.00-70.00 Hz
    (II) VIA(0): Clock range:  20.00 to 230.00 MHz
    (II) VIA(0): Not using default mode "640x350" (hsync out of range)
    (II) VIA(0): Not using default mode "320x175" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "640x400" (hsync out of range)
    (II) VIA(0): Not using default mode "320x200" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "720x400" (hsync out of range)
    (II) VIA(0): Not using default mode "360x200" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "320x240" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "640x480" (hsync out of range)
    (II) VIA(0): Not using default mode "400x300" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "800x600" (hsync out of range)
    (II) VIA(0): Not using default mode "1024x768" (hsync out of range)
    (II) VIA(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1152x864" (hsync out of range)
    (II) VIA(0): Not using default mode "576x432" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1280x960" (hsync out of range)
    (II) VIA(0): Not using default mode "640x480" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1280x1024" (hsync out of range)
    (II) VIA(0): Not using default mode "640x512" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1600x1200" (hsync out of range)
    (II) VIA(0): Not using default mode "800x600" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1792x1344" (hsync out of range)
    (II) VIA(0): Not using default mode "896x672" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1792x1344" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1856x1392" (hsync out of range)
    (II) VIA(0): Not using default mode "928x696" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1856x1392" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1920x1440" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "960x720" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "832x624" (hsync out of range)
    (II) VIA(0): Not using default mode "416x312" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1152x768" (hsync out of range)
    (II) VIA(0): Not using default mode "576x384" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1400x1050" (hsync out of range)
    (II) VIA(0): Not using default mode "700x525" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1600x1024" (hsync out of range)
    (II) VIA(0): Not using default mode "800x512" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
    (II) VIA(0): Not using mode "1280x1024" (no mode of this name)
    (II) VIA(0): Not using mode "1024x768" (no mode of this name)
    (II) VIA(0): I2C device "I2C bus 2:TV" registered at address 0x40.
    (II) VIA(0): I2C device "I2C bus 2:TV" removed.
    (II) VIA(0): I2C device "I2C bus 2:VT1622" registered at address 0x40.
    (II) VIA(0): I2C device "I2C bus 2:VT1622" removed.
    (--) VIA(0): Virtual size is 800x600 (pitch 800)
    (**) VIA(0): *Default mode "800x600": 36.0 MHz (scaled from -161745.9 MHz), 35.2 kHz, 56.2 Hz
    (II) VIA(0): Modeline "800x600"   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync
    (**) VIA(0): *Default mode "640x480": 25.2 MHz (scaled from 2034261.5 MHz), 31.5 kHz, 60.0 Hz
    (II) VIA(0): Modeline "640x480"   25.20  640 656 752 800  480 490 492 525 -hsync -vsync
    (==) VIA(0): DPI set to (75, 75)
    (II) Loading sub module "fb"
    (II) LoadModule: "fb"
    (II) Loading /usr/lib/modules/libfb.a
    (II) Module fb: vendor="X.Org Foundation"
    	ABI class: X.Org ANSI C Emulation, version 0.2
    (II) Loading sub module "xaa"
    (II) LoadModule: "xaa"
    (II) Loading /usr/lib/modules/libxaa.a
    (II) Module xaa: vendor="X.Org Foundation"
    (II) Loading sub module "ramdac"
    (II) LoadModule: "ramdac"
    (II) Loading /usr/lib/modules/libramdac.a
    (II) Module ramdac: vendor="X.Org Foundation"
    (**) VIA(0): Option: Cap0_FieldSwap Disabled
    (II) do I need RAC?  No, I don't.
    (II) resource ranges after preInit:
    	[0] 0	0	0xe6000000 - 0xe6ffffff (0x1000000) MS[B]
    	[1] 0	0	0xe0000000 - 0xe3ffffff (0x4000000) MS[B]
    	[2] -1	0	0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    	[3] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[4] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[5] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[6] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[7] -1	0	0xe8004000 - 0xe8004fff (0x1000) MX[B]
    	[8] -1	0	0xe8002000 - 0xe80020ff (0x100) MX[B]
    	[9] -1	0	0xe8001000 - 0xe80010ff (0x100) MX[B]
    	[10] -1	0	0xe8000000 - 0xe80007ff (0x800) MX[B]
    	[11] -1	0	0xe4000000 - 0xe3ffffff (0x0) MX[B]O
    	[12] -1	0	0xe6000000 - 0xe6ffffff (0x1000000) MX[B](B)
    	[13] -1	0	0xe0000000 - 0xe3ffffff (0x4000000) MX[B](B)
    	[14] -1	0	0xe8003000 - 0xe8003fff (0x1000) MX[B](B)
    	[15] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
    	[16] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
    	[17] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
    	[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[19] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[20] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[B]
    	[21] -1	0	0x0000e400 - 0x0000e4ff (0x100) IX[B]
    	[22] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
    	[23] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[B]
    	[24] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[B]
    	[25] -1	0	0x0000d400 - 0x0000d41f (0x20) IX[B]
    	[26] -1	0	0x0000d000 - 0x0000d07f (0x80) IX[B]
    	[27] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
    	[28] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
    (--) VIA(0): mapping framebuffer @ 0xe0000000 with size 0x2000000
    (==) VIA(0): Write-combining range (0xe0000000,0x2000000)
    (--) VIA(0): Frame buffer start: 0xb5d7f000, free start: 0xea600 end: 0x2000000
    (II) VIA(0): VIAInternalScreenInit
    (II) VIA(0): Clipping pixmap cache for old DRI/DRM module.
    (II) VIA(0): Using XFree86 Acceleration Architecture (XAA)
    	Screen to screen bit blits
    	Solid filled rectangles
    	8x8 mono pattern filled rectangles
    	8x8 color pattern filled rectangles
    	Screen to Screen color expansion
    	Solid Lines
    	Dashed Lines
    	Image Writes
    	Offscreen Pixmaps
    	Setting up tile and stipple cache:
    		5 128x128 slots
    		32 8x8 color pattern slots
    (==) VIA(0): Backing store disabled
    (II) VIA(0): I2C device "I2C bus 2:TV Probe" registered at address 0x88.
    (II) VIA(0): I2C device "I2C bus 2:SAA7113H" removed.
    (II) VIA(0): I2C device "I2C bus 2:SAA7114H" removed.
    (II) VIA(0): I2C device "I2C bus 2:TV Probe" removed.
    (==) RandR enabled
    (II) Initializing built-in extension MIT-SHM
    (II) Initializing built-in extension XInputExtension
    (II) Initializing built-in extension XTEST
    (II) Initializing built-in extension XKEYBOARD
    (II) Initializing built-in extension LBX
    (II) Initializing built-in extension XC-APPGROUP
    (II) Initializing built-in extension SECURITY
    (II) Initializing built-in extension XINERAMA
    (II) Initializing built-in extension XFIXES
    (II) Initializing built-in extension XFree86-Bigfont
    (II) Initializing built-in extension RENDER
    (II) Initializing built-in extension RANDR
    (II) Initializing built-in extension COMPOSITE
    (II) Initializing built-in extension DAMAGE
    (II) Initializing built-in extension XEVIE
    (**) Option "Protocol" "Auto"
    (**) Mouse1: Device: "/dev/mouse"
    (**) Mouse1: Protocol: "Auto"
    (**) Option "CorePointer"
    (**) Mouse1: Core Pointer
    (**) Option "Device" "/dev/mouse"
    (==) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
    (==) Mouse1: Buttons: 3
    (**) Mouse1: SmartScroll: 1
    (**) Option "CoreKeyboard"
    (**) Keyboard1: Core Keyboard
    (**) Option "Protocol" "standard"
    (**) Keyboard1: Protocol: standard
    (**) Option "AutoRepeat" "500 30"
    (**) Option "XkbRules" "xorg"
    (**) Keyboard1: XkbRules: "xorg"
    (**) Option "XkbModel" "pc101"
    (**) Keyboard1: XkbModel: "pc101"
    (**) Option "XkbLayout" "us"
    (**) Keyboard1: XkbLayout: "us"
    (**) Option "XkbVariant" "de"
    (**) Keyboard1: XkbVariant: "de"
    (**) Option "CustomKeycodes" "off"
    (**) Keyboard1: CustomKeycodes disabled
    (II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
    (II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
    (--) Mouse1: PnP-detected protocol: "ExplorerPS/2"
    (II) Mouse1: ps2EnableDataReporting: succeeded
    Could not init font path element /usr/share/fonts/local/, removing from list!
    Würde mich über eine Antwort freuen :)
    Danke schonmal
    Blacksmoker
Xorg Problem
Xorg Problem - Ähnliche Themen
  1. xorg-server update: umstieg von hal auf udev -> probleme mit tastatur & maus
    xorg-server update: umstieg von hal auf udev -> probleme mit tastatur & maus: Hi also der Betreff sagt schon des meiste. Hab mein Gentoo-System seit längerer Zeit mal wieder aktualisiert, was 2 größere Änderungen mit sich...
  2. Problem mit Xorg 1.8
    Problem mit Xorg 1.8: Hallo Wie müpsen die config-dateien in /etc/X11/xorg.conf.d aussehen, bzw. wie müssen die heißen? hab arch für 64Bit neu aufgesetzt und hab...
  3. 0-laenge Pakete und Xorg Probleme
    0-laenge Pakete und Xorg Probleme: Hallo. Nachdem ich nun langsam in meinem bisher reinen ueber Konsole betriebenen Arch einen X-Server benutzen will haeufen sich die Probleme...
  4. Xorg probleme mit Maus und Tastertur
    Xorg probleme mit Maus und Tastertur: Hi ich hab Xorg mit pacman draufgemacht. Füher hat das immer ganz gut funktioniert aber irgentwie wird die Maus und die Tastertur nicht erkannt...
  5. Xorg Leistungs Problem
    Xorg Leistungs Problem: Hi, ich hab ein kleines Problem mit meinem X. Es besteht eigentlich schon länger, nur so richtig realisiert hab ich es erst jetzt. Vor ca nem...
