Linker Problem
Diskutiere Linker Problem im Gentoo Forum im Bereich Linux Distributionen; Ich verwende Gentoo 2006.1 AMD64. Ich möchte den GCC u.a. mit den folgenden Optionen ansteuern: -lrt -lm. Nur erscheint dann die...
  1. #1 Keruskerfürst, 20.12.2006
    Keruskerfürst
    Keruskerfürst Kaiser
    12.02.2006
    1.366
    -lrt -lm.
    Nur erscheint dann die Fehlermeldung:
    linker input file not used, since no linking done.
    Hier noch meine make.conf:
    # These settings were set by the catalyst build script that automatically built this stage
    # Please consult /etc/make.conf.example for a more detailed example
    #ACCEPT KEYWORDS
    #ACCEPT_KEYWORDS="~amd64"
    ACCEPT_KEYWORDS="amd64"
    #CFLAGS
    CFLAGS="-march=athlon64"
    CFLAGS="${CFLAGS} -lrt"
    CFLAGS="${CFLAGS} -lm"
    #CFLAGS="${CFLAGS} -std=gnu99"
    CFLAGS="${CFLAGS} -mtune=athlon64"
    #CFLAGS="${CFLAGS} -masm=att"
    #CFLAGS="${CFLAGS} -masm=intel"
    CFLAGS="${CFLAGS} -O2"
    CFLAGS="${CFLAGS} -combine"
    #CFLAGS="${CFLAGS} -fforce-addr"nicht schneller
    #CFLAGS="${CFLAGS} -fgcse-lm"Program Fehlfunktion
    #CFLAGS="${CFLAGS} -fgcse-sm"Program Fehlfunktion
    #CFLAGS="${CFLAGS} -fgcse-las"Program Fehlfunktion
    CFLAGS="${CFLAGS} -fgcse-after-reload"
    #CFLAGS="${CFLAGS} -fmerge-all-constants"Program Fehlfunktion
    #CFLAGS="${CFLAGS} -momit-leaf-frame-pointer"
    #CFLAGS="${CFLAGS} -fmodulo-sched"
    CFLAGS="${CFLAGS} -fno-ident"
    CFLAGS="${CFLAGS} -fomit-frame-pointer"
    CFLAGS="${CFLAGS} -fprefetch-loop-arrays"
    #CFLAGS="${CFLAGS} -fprofile-generate"noch nicht getestet
    #CFLAGS="${CFLAGS} -fprofile-use"noch nicht getestet
    CFLAGS="${CFLAGS} -frename-registers"
    #CFLAGS="${CFLAGS} -ftree-loop-linear"
    #CFLAGS="${CFLAGS} -ftree-loop-im"
    #CFLAGS="${CFLAGS} -freorder-blocks-and-partition"langsamer
    #CFLAGS="${CFLAGS} -ftracer"
    CFLAGS="${CFLAGS} -funit-at-a-time"
    CFLAGS="${CFLAGS} -fweb"
    #CFLAGS="${CFLAGS} -fwhole-program"kein Kompilieren
    CFLAGS="${CFLAGS} -mmmx"
    CFLAGS="${CFLAGS} -m3dnow"
    CFLAGS="${CFLAGS} -msse"
    CFLAGS="${CFLAGS} -msse2"
    CFLAGS="${CFLAGS} -m80387"
    CFLAGS="${CFLAGS} -mhard-float"
    CFLAGS="${CFLAGS} -pipe"
    CFLAGS="${CFLAGS} -s"
    #CXXFLAGS
    CXXFLAGS="${CFLAGS}"
    #CHOST
    CHOST="x86_64-pc-linux-gnu"
    #CBUILD
    CBUILD="x86_64-pc-linux-gnu"
    #CLEAN_DELAY
    CLEAN_DELAY=0
    #FEATURES
    FEATURES="parallel-fetch fix-packages"
    #FETCH/RESUME COMMAND
    FETCHCOMMAND="/usr/bin/rsync -v --progress \${URI} /\${DISTDIR}/\${FILE}"
    RESUMECOMMAND="/usr/bin/rsync -v --progress \${URI} /\${DISTDIR}/\${FILE}"
    #INPUT_DEVICES
    INPUT_DEVICES="keyboard mouse"
    #LDFLAGS
    LDFLAGS="-Wl,-O1"
    LDFLAGS="${LDFLAGS} -Wl,--as-needed"
    LDFLAGS="${LDFLAGS} -Wl,--enable-new-dtags"
    LDFLAGS="${LDFLAGS} -Wl,-s"
    LDFLAGS="${LDFLAGS} -Wl,--sort-common"
    LDFLAGS="${LDFLAGS} -Wl,-znow"
    #LINGUAS
    LINGUAS="en"
    #MAKEOPTS
    MAKEOPTS="-j1 -s"
    #PORT_LOGDIR
    PORT_LOGDIR="/var/log/portage"
    #GENTOO_MIRRORS
    #GENTOO_MIRRORS="http://ftp.join.uni-muenster.de/gentoo/"
    #GENTOO_MIRRORS="${GENTOO_MIRRORS} http://mirrors.sec.informatik.tu-darmstadt.de/gentoo/"
    #GENTOO_MIRRORS="${GENTOO_MIRRORS} http://ftp-stud.fht-esslingen.de/gentoo/"
    #GENTOO_MIRRORS="${GENTOO_MIRRORS} http://gentoo.intergenai.de/gentoo/"
    #GENTOO_MIRRORS="${GENTOO_MIRRORS} http://ftp.belnet.be/gentoo/"
    GENTOO_MIRRORS="rsync://linux.rz.ruhr-uni-bochum.de/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.join.uni-muenster.de/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://mirrors.sec.informatik.tu-darmstadt.de/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp-stud.fht-esslingen.de/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://gentoo.intergenia.de/gentoo-linux/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.belnet.be/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.snt.utwente.nl/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://gd.tuwien.ac.at/opsys/linux/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.fi.muni.cz/pub/linux/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://gentoo.prz.rzeszow.pl/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.lug.ro/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://trumpetti.atm.tut.fi/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://ftp.rhnet.is/gentoo/"
    GENTOO_MIRRORS="${GENTOO_MIRRORS} rsync://mirror.hamakor.org.il/gentoo/"
    #SYNC
    SYNC="rsync://linux.rz.ruhr-uni-bochum.de/gentoo-portage"
    #SYNC="rsync://rsync.gentoo.org/gentoo-portage"
    #USE
    USE="3dnow 3dnowext"
    USE="${USE} a52 aac aiglx alsa -arts"
    USE="${USE} cdr cdparanoia -cracklib -crypt"
    USE="${USE} -debug dts dvd dvdr"
    #USE="${USE} doc"
    USE="${USE} -eds -emboss"
    USE="${USE} -fam firefox -fortran ftp"
    USE="${USE} -gdbm glibc-omitfp gnome -gpm gtk gtk2"
    USE="${USE} -kde"
    USE="${USE} ipv6 -isdnlog"
    USE="${USE} java javascript"
    USE="${USE} mpeg2 mmx mmxext"
    USE="${USE} nptl nptlonly"
    USE="${USE} -oss"
    #USE="${USE} pdf"
    USE="${USE} -qt3 -qt4"
    USE="${USE} truetype"
    USE="${USE} -spell sse sse2"
    USE="${USE} wxGTK"
    USE="${USE} unicode"
    #VIDEO_CARDS
    VIDEO_CARDS="nv"
Linker Problem
Linker Problem - Ähnliche Themen
  1. Linkerproblem mit MXE
    Linkerproblem mit MXE: Hallo Leute :winke:, ich war echt lange nicht mehr hier... Wie auch immer, ich schreibe gerade ein Programm, das sowohl Qt5, als auch OpenMP...
  2. LLVM entwickelt eigenen ELF-Linker
    LLVM entwickelt eigenen ELF-Linker: Wie das LLVM-Projekt bekannt gab, steht mit »lld« ein alternativer Linker bereit, der sich vor allem durch seine gesteigerte Geschwindigkeit...
  3. Linker meckert über nicht definierte Funktion
    Linker meckert über nicht definierte Funktion: Hallo zusammen. Ich habe mir bei mysql den Connector und Beispielcode für den Zugriff auf eine mysql-Datenbank runtergeladen und habe damit,...
  4. Über Linker Skript externe Variablen übergeben
    Über Linker Skript externe Variablen übergeben: Hi, ich habe mich im Rahmen einer Projektarbeit an der Uni mit der "Linker Command Language" beschäftigt und mit dem Umgang des LD's. Als...
  5. DRINGEND Linker Frage!
    DRINGEND Linker Frage!: Hi, muss dringend ein Projekt komplieren, jedoch muss eigene Librarys nutzem, die ich in der Makefile für LD_FLAGS eintrage. Nun habe ich auch...
