Tux-Forever
Linuxer
serwuz
ich hab da ein kleines problem mit meiner geforce fx 5700 und zwar wird die 3d beschleunigung nicht aktiviert
die nvidia treiber wurden ohne fehler installiert sind die 5328
wird die karte noch nicht unterstützt???
das nvidia logo erscheint auch beim starten des x servers
meine distri is aurox 9.2 hier mal meine xf86config
# XFree86 4 configuration created by redhat-config-xfree86
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "DevInputMice" "AlwaysCore"
EndSection
Section "Files"
# RgbPath is the location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
# Load "fbdevhw"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
# Load "dri"
# Load "GLcore"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# Or if you just want both to be control, use:
# Option "XkbOptions" "ctrl:nocaps"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
# If the normal CorePointer mouse is not a USB mouse then
# this input device can be used in AlwaysCore mode to let you
# also use USB mice at the same time.
Identifier "DevInputMice"
Driver "mouse"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Samsung SyncMaster 750(M)b"
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 160.0
Option "dpms"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
# VendorName "Videocard vendor"
# BoardName "VESA driver (generic)"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 16
SubSection "Display"
Depth 16
Modes "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
# Load "fbdevhw"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
# Load "dri"
# Load "GLcore"
EndSection
# or:
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
Option "dpms"
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 16
Depth 16
EndSubSection
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
