Shell Sripts: How to call another scripts with one script
Diskutiere Shell Sripts: How to call another scripts with one script im Shell-Skripte Forum im Bereich Programmieren unter Linux/Unix; Please, can someone Help me with: How to execute 3 other sripts in one. ----------- and also Please how to make a tar files which will...
  1. #1 Zoungou, 02.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Please,
    and also Please how to make a tar files which will work at the end of each month with a format like <yyyymm>
    Please help me since 6 hours now trying to find a solution
    Thanks a lot in advance.
    Sonson
  3. #2 daboss, 02.04.2009
    daboss
    05.01.2007
    1.294
    sydney.australia.world
    U mean sth. like the following one?
    {-alex-|-asterix-} => [~/bin]
    (18:37:43) cat start.sh
    #!/bin/bash
    echo "starter";
    /home/alex/bin/first.sh;
    /home/alex/bin/second.sh;
    /home/alex/bin/third.sh;
    (18:37:55) cat first.sh
    #!/bin/bash
    echo "first one";
    (18:37:57) cat second.sh
    #!/bin/bash
    echo "second one";
    (18:37:59) cat third.sh
    #!/bin/bash
    echo "third one";
    (18:38:01) ./start.sh
    starter
    first one
    second one
    third one
    e.g. sth. like
     tar -cf tarfilename`date +"%Y%m"`.tar <files_to_tar>
    as a cronjob...
  4. #3 Zoungou, 03.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Sir Daboss,
    before i test your advices let me give you my best Greetings first for this quick responds and your big interrest to help others
    Thanks in advance.
    Sonson
  5. daboss
    05.01.2007
    1.294
    No worries, I hope it'll help ;)
  6. #5 Zoungou, 03.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Daboss dein Hinweise hat geholfen aber i komme nicht weiter hier is was wir brauchen:
    TO -DO:
    wir benötigen ein Skript welches und die Daten für den ServiceReport sammelt und diese
    in ein File ( tar ) packt.
    Im einzelnen folgendes sammeln:
    Alle Files des letzten Monat aus dem Verzeichnis: BA_eAkte_accounting/out
    Den Output von:
    /master/home/arcadm/accounting/scripts/print_monthly_responsetime_report_interactive.csh
    /master/home/arcadm/work/e_reporting.csh
    /master/home/arcadm/work/e_monitor2.csh
    Den Namen des Tar-Files bitte mit ServiceReport….. und dem letzen Monat ( aus dem die Daten stammen ) versehen.
    Please hier is exactly what we want.
    If you cannot read German den Please let me know i'll translate all in English.
    Danke im voraus,
    Sonson
  7. #6 daboss, 03.04.2009
    daboss
    05.01.2007
    1.294
    Hey,
    also
    könnte man eventuell so lösen:
    find  BA_eAkte_accounting/out -newerat `date -d "1 month ago" +"%Y%m"`01 -type f -exec tar -cf ServiceReport`date -d "1 month ago" +"%Y%m"`.tar  {}  \;
    Den Output der Skripte (schon normaler Text, oder?) solltest du z.Bsp. mit
    /master/home/arcadm/work/e_reporting.csh > e_reporting_output.txt
    /master/home/arcadm/work/e_monitor2.csh > e_monitor2.txt
    /master/home/arcadm/accounting/scripts/print_monthly_responsetime_report_interactive.csh > print_monthly_responsetime_report_interactive.txt
    bekommen.
    /Edit 2: Die kannst du dann mit
    tar -rf ServiceReport`date -d "1 month ago" +"%Y%m"`.tar e_reporting_output.txt e_monitor2.txt print_monthly_responsetime_report_interactive.txt
    rm -f e_reporting_output.txt e_monitor2.txt print_monthly_responsetime_report_interactive.txt
    zum Archiv hinzufuegen und wieder von der Platte löschen.
    /Edit: Ich seh gerade, deine anderen Scripte sind csh-Dateien, deswegen: Zumindest in der bash funktionierts, aber ich weiß nicht, inwieweit sich csh und bash da unterscheiden...
    /Edit 3:
    Na, ist ja auch ein deutschsprachiges Forum hier, insofern wäre es eh besser, wenn du/wir bei der deutschen Sprache bleiben ;) :)
  8. #7 Zoungou, 03.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Ok Danke Daboss
    Gruß und bis bald für das Feedback
    ich arbeite tcsh shell
    Die tar soll die files.csv einpacking
    wenn ich find mache bekomme ich diese Fehlermeldung:
    arcadm@bm1:/master/home/arcadm/BA_eAkte_accounting/scripts> find /master/home/earcadm/BA_eAkte_accounting/out -newerat `date -d "1 month ago" +"%Y%m"`01 -type f -exec tar -cf Kat2-ServiceReport`date -d "1 month ago" +"%Y%m"`.tar {} \;
    date: illegal option -- d
    usage: date [-u] mmddHHMM[[cc]yy][.SS]
    date [-u] [+format]
    date -a [-]sss[.fff]
    date [-u] [+format]
    find: bad option -newerat
    find: [-H | -L] path-list predicate-list
    bitte kann jemand mir helfen!
    wenn ich dieser Befehl ausführt bekomme ich diese Fehlermeldung:
    command:
    find /master/home/arcadm/accounting/out -newer `date -u "1 month ago" +"%Y%m"`01 -type f -exec cp {} tar -cf Kat2-ServiceReport`date -u "1 month ago" +"%Y%m"`.tar {} \;
    Error Output:
    date [-u] [+format]
    date [-u] [+format]
    find: cannot access 01
    Vielen Dank an alle.
    zoungou (Sonson)
  9. daboss
    05.01.2007
    1.294
    Hm, dann hast du wohl andere Versionen von find und date als ich... Musste mal schauen, wie du's mit den, dir zur Verfügung stehenden Optionen "workarounden" kannst. Irgendwie schnell geschossen Jahr und Monat einzeln heraus ziehen und dann manuell einen Monat abziehen oder so.
  10. #9 Zoungou, 06.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Danke für Ihre Antworte; Kann man dass mit (date -u) machen? And auch bekommt ich ein Fehlermeldung manchmal dass : 01 keine Verzeichnis (kann nicht gefunden werden) bei (01 -type f -exec)
    Danke und ein angenehmer Tag wünsch ich dir
  11. #10 tuxlover, 06.04.2009
    tuxlover
    tuxlover Der den Tux knuddelt
    26.10.2005
    2.106
    berlin
    dabos, danke für den hinweis. ich dachte immer sowas würde in bash nicht funktionuieren.
  12. daboss
    05.01.2007
    1.294
    Kein Problem...
    meintest du des mit den 3 Skripten? Oder des andere?
  13. #12 Zoungou, 07.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Hallo Daboss,
    was kann ich jetzt machen mit den find und tar Befehle.
    Danke im voraus.
  14. #13 daboss, 07.04.2009
    daboss
    05.01.2007
    1.294
    Hab ich doch oben schon gesagt:
    Ich dachte eher an sowas, aber ich habs jetzt weder getestet, noch weiß ich, ob der newer-Parameter von deinem find dem newerat von meinem find ausreichend ähnelt... ausserdem hab ich doch selber kaum Ahnung von Shellskripten ;)
    #!/bin/bash
    JAHR_AKT=$(date +"%Y");
    JAHR_DEK=$(($JAHR_AKT - 1));
    MONAT_AKT=$(date +"%m");
    MONAT_DEK=$(($MONAT_AKT - 1));
    #Monat zu klein?
    if [ "$MONAT_DEK" -le "0" ]; then
        MONAT_DEK="12";
        JAHR_AKT="$JAHR_DEK";
    fi;
    #Monat wird beim subtrahieren ggf. einstellig
    if [ "$MONAT_DEK" -le "9" ] && [ "$MONAT_DEK" -ge "1" ]; then
        MONAT_DEK="0$MONAT_DEK";
    fi;
    DATUM_FIND="$JAHR_AKT$MONAT_DEK$(echo "01")"; #yyyymm01
    DATUM_TARNAME="$JAHR_AKT$MONAT_DEK"; #yyyymm
    find /master/home/arcadm/accounting/out -newer $DATUM_FIND -type f -exec tar -cf Kat2-ServiceReport$DATUM_TARNAME.tar {} \;
  16. #14 Zoungou, 07.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Daboss,
    vielen Dank im voraus,
    ich probiere das aus und gebe dir Bescheid asap.
    Danke
    Zoungou
    Hi Daboss,
    ich bekomme ein Fehlermeldung wenn ich alle zusammen mit dein script ausführt
    arcadm@dbm:/master/home/arcadm/e_accounting/monatlichen_service_report> ./report_07062009.csh
    Variable syntax
    how can i now put together with my 3 scripts:
    """"Alle Files des letzten Monat aus dem Verzeichnis: BA_eAkte_accounting/out
    Den Output von:
    my shell ist so: /bin/tcsh
    arcadm@dbm:/master/home/arcadm/e_accounting/echo $SHELL
    /bin/tcsh
    Gruß Daboss.
    Zoungou
  17. #15 Zoungou, 08.04.2009
    Zoungou
    Zoungou Jungspund
    02.04.2009
    16
    Hi Daboss,
    ich habe versuche alles zu basteln und nach der Ausführung bekomme ich dieser Fehlermeldung:
    syntax error at line 2: `JAHR_AKT=$' unexpected
    ich glaube deiner Skript is was ich brauch
    Zoungou
Shell Sripts: How to call another scripts with one script - Ähnliche Themen
  1. HandbrakeCLI Shell Skript
    HandbrakeCLI Shell Skript: Hallo zusammen und Schöne grüße aus Süddeutschland. Ich versuche mich gerade an einem Skript für Handbrake. Ich bin ein Anfänger , und habe mir...
  2. Shell Skript beschleunigen
    Shell Skript beschleunigen: Hallo zusammen, ich bin neu hier und hab gerade angefangen mich an Schell Skripte zu wagen. Nun hab eine Frage ich hab ein Skript geschrieben und...
  3. [Erledigt] Shell-Skript lässt sich nicht mit Cron ausführen
    [Erledigt] Shell-Skript lässt sich nicht mit Cron ausführen: Hallo, ich hoffe ihr könnt mir helfen. Ich entwerfe im Moment ein Skript, welches den Callmonitor (Telnet) auf meiner FritzBox abfragt und wenn...
  4. Shell-Skript Datum in einer Datai suchen
    Shell-Skript Datum in einer Datai suchen: Hallo zusammen Ich komm eigentlich aus der Klicki-Bunti-Welt von Windows. Seit geraumer Zeit versuche ich meine Künste mit verschiedenen...
  5. Shell Script Problem
