Problem mit Stresstool? Versteht ihr wie das gemeint ist?
Diskutiere Problem mit Stresstool? Versteht ihr wie das gemeint ist? im Web- & File-Services Forum im Bereich Netzwerke & Serverdienste; Hallo, ich teste grad den Darwin Streaming Server mit dem enthaltenen Stresstool Streaming LoadTool. Dazu gibts ne streamingloadtool.con: #...
  1. #1 Lanz0101, 08.06.2008
    Lanz0101
    Lanz0101 Tripel-As
    21.04.2008
    163
    # This is a StreamingLoadTool config file
    #player user agent name
    player gmp4player
    # Use the "clienttype" directive to specify whether StreamingLoadTool should make
    # RTSP / UDP connections or RTSP / HTTP connections or . Say "http" for
    # the latter, "udp" for the former. Say "reliableudp" for reliable UDP.
    # Say "http" for straight interleaved RTSP / RTP
    clienttype tcp
    # If doing RTSP / HTTP, set droppost to "yes" if you would like StreamingLoadTool
    # to drop the POST half of each RTSP / HTTP connection after sending the
    # PLAY. "yes" best emulates the "real" client behavior.
    droppost yes
    # Set this to the # of concurrent clients you would like StreamingLoadTool to maintain
    concurrentclients	10
    # Specify a connection port for each connection
    port		554
    # Specify a proxy IP address in dotted-decimal form. If 0, StreamingLoadTool
    # will not use a proxy to connect
    proxyip		0
    # Client window (size of UDP socket buffers).
    # For reliable UDP, this affects packet loss and the server's
    # retransmission algorithm
    clientwindow 32768
    # StreamingLoadTool should send a TEARDOWN after streaming for this # of seconds
    movielength	40
    # If runforever is set to "no", StreamingLoadTool will quit after finishing the
    # list of URLs provided below. If "yes" StreamingLoadTool will loop forever.
    runforever yes
    # Each instance of StreamingLoadTool must have a unique httpcookie value. This
    # can also be specified on the command-line (see usage by doing StreamingLoadTool -v)
    httpcookie	1
    # Set to "yes" if you would like StreamingLoadTool to generate a connection log
    shouldlog	yes
    # Append junk data after each DESCRIBE request
    appendjunk	no
    # Location to place the connection log
    logpath		streamingloadtool.log
    # Interval in milliseconds between attempts to read media data. For acking
    # udp clients, this is also the interval between acks.
    readinterval 1
    # how late should packets be allowed to be sent? Value is in seconds.
    # 0 = no late tolerance will be specified at all
    latetolerance 0
    # The "Packet-Range" header is used as an alternative to the standard "Range"
    # header on a Play request for specifying a range of packets. Leave
    # this line blank to issue a standard play, specify a packet range header
    # here to send that instead of standard Range header.
    packetplayheader
    # The overbuffer window size is the number of K bytes the server can send
    # ahead of time. This applies to all transports except "udp".
    overbufferwindowsize 5192
    # Set this to be the value of the x-RTP-Meta-Info header sent to the server.
    # If it is empty, no x-RTP-Meta-Info header will be sent. Otherwise, specify
    # the fields you would like to receive
    # rtpmetainfo tt;ft;pn;fd;md;sq
    # Set this to be the speed you want the streams at (1 = normal speed, 2 = 2x normal speed, etc)
    speed	2
    # Enable this to have StreamingLoadTool randomly thumb around
    randomthumb yes
    # Set sendoptions "yes" to send an OPTIONS request before executing each DESCRIBE request
    sendoptions yes
    # Set requestrandomdata "yes" to send an OPTIONS request with a random data request header before executing each DESCRIBE request
    requestrandomdata yes
    # How many random bytes the server should send in the body of the OPTIONS response
    randomdatasize 100
    # List of rtsp URLs for StreamingLoadTool to execute
    url rtsp://t-vision.berkom.de/sample_100kbit.mp4
    und wenn ich das ding nu starte zeigt er mir folgendes in der Kommandozeile an:
    [root@localhost DarwinStreamingSrvrlinux-Linux]# ./StreamingLoadTool
    Checking for 'streamingloadtool.mov' on the target servers
    Done checking for 'streamingloadtool.mov' on all servers
    StreamingLoadTool test in progress.
    Config file: streamingloadtool.conf. Client type: RTSP/TCP client. Num clients: 10.
    Movie length: 40. Run forever: 1. HTTP cookie: 1000010. Port: 554
    Writing StreamingLoadTool log at: streamingloadtool.log
    Active Playing Attempts Success Errors Failed Bitrate
       10      2       10      0      0      0         7k
       10      7       10      0      0      0       346k
       10     10       10      0      0      0       371k
       10      7       11      0      0      1       295k
       10      8       14      0      0      4       337k
       10      7       15      0      0      5       329k
       10      5       17      0      0      9       320k
       10      6       20      0      0     10       319k
       10      7       22      0      0     12       342k
    Sending TEARDOWNs.
    Speicherzugriffsfehler
    jetzt sind ja in der conf 10 Verbindungen vorgegegben, warum stehen aber bei Attempt mehr als 10? Und was ist der unterschied zwischen Error und Failed? Vielleicht versteh ich die wirkungsweise des Stresstools ned richtig?
    Hat jemand Ahnung?
Problem mit Stresstool? Versteht ihr wie das gemeint ist? - Ähnliche Themen
  1. Virtualboxproblem
  4. Probleme mit YUM
