Problem beim emergen (xml parser)
Diskutiere Problem beim emergen (xml parser) im Gentoo Forum im Bereich Linux Distributionen; Hallo ich hab seit kurzen bei zwei verschiedenen ebuilds beim compilieren folgende fehlermeldung bekommen: >>> Unpacking source... >>>...
  1. #1 karloff, 09.01.2008
    karloff
    karloff Routinier
    09.07.2007
    317
    >>> Unpacking source...
    >>> Unpacking GConf-2.20.1.tar.bz2 to /var/tmp/portage/gnome-base/gconf-2.20.1/work
     * Fixing OMF Makefiles ...
      [ ok ]
     * Running elibtoolize in: GConf-2.20.1
     *   Applying portage-1.5.10.patch ...
     *   Applying sed-1.5.6.patch ...
    >>> Source unpacked.
    >>> Compiling source in /var/tmp/portage/gnome-base/gconf-2.20.1/work/GConf-2.20.1 ...
     * econf: updating GConf-2.20.1/config.sub with /usr/share/gnuconfig/config.sub
     * econf: updating GConf-2.20.1/config.guess with /usr/share/gnuconfig/config.guess
    ./configure --prefix=/usr --host=i686-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --enable-gtk --disable-debug --disable-gtk-doc --build=i686-pc-linux-gnu
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether to enable maintainer-specific portions of Makefiles... no
    checking build system type... i686-pc-linux-gnu
    checking host system type... i686-pc-linux-gnu
    checking for i686-pc-linux-gnu-gcc... i686-pc-linux-gnu-gcc
    checking for C compiler default output file name... a.out
    checking whether the C compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether i686-pc-linux-gnu-gcc accepts -g... yes
    checking for i686-pc-linux-gnu-gcc option to accept ISO C89... none needed
    checking for style of include used by make... GNU
    checking dependency style of i686-pc-linux-gnu-gcc... gcc3
    checking for i686-pc-linux-gnu-g++... i686-pc-linux-gnu-g++
    checking whether we are using the GNU C++ compiler... yes
    checking whether i686-pc-linux-gnu-g++ accepts -g... yes
    checking dependency style of i686-pc-linux-gnu-g++... gcc3
    checking for library containing strerror... none required
    checking for i686-pc-linux-gnu-gcc... (cached) i686-pc-linux-gnu-gcc
    checking whether we are using the GNU C compiler... (cached) yes
    checking whether i686-pc-linux-gnu-gcc accepts -g... (cached) yes
    checking for i686-pc-linux-gnu-gcc option to accept ISO C89... (cached) none needed
    checking dependency style of i686-pc-linux-gnu-gcc... (cached) gcc3
    checking how to run the C preprocessor... i686-pc-linux-gnu-gcc -E
    checking for grep that handles long lines and -e... /bin/grep
    checking for egrep... /bin/grep -E
    checking for ANSI C header files... yes
    checking for a sed that does not truncate output... /bin/sed
    checking for ld used by i686-pc-linux-gnu-gcc... /usr/i686-pc-linux-gnu/bin/ld
    checking if the linker (/usr/i686-pc-linux-gnu/bin/ld) is GNU ld... yes
    checking for /usr/i686-pc-linux-gnu/bin/ld option to reload object files... -r
    checking for BSD-compatible nm... /usr/bin/nm -B
    checking whether ln -s works... yes
    checking how to recognize dependent libraries... pass_all
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking dlfcn.h usability... yes
    checking dlfcn.h presence... yes
    checking for dlfcn.h... yes
    checking how to run the C++ preprocessor... i686-pc-linux-gnu-g++ -E
    checking for i686-pc-linux-gnu-g77... no
    checking for i686-pc-linux-gnu-xlf... no
    checking for i686-pc-linux-gnu-f77... no
    checking for i686-pc-linux-gnu-frt... no
    checking for i686-pc-linux-gnu-pgf77... no
    checking for i686-pc-linux-gnu-cf77... no
    checking for i686-pc-linux-gnu-fort77... no
    checking for i686-pc-linux-gnu-fl32... no
    checking for i686-pc-linux-gnu-af77... no
    checking for i686-pc-linux-gnu-xlf90... no
    checking for i686-pc-linux-gnu-f90... no
    checking for i686-pc-linux-gnu-pgf90... no
    checking for i686-pc-linux-gnu-pghpf... no
    checking for i686-pc-linux-gnu-epcf90... no
    checking for i686-pc-linux-gnu-gfortran... i686-pc-linux-gnu-gfortran
    checking whether we are using the GNU Fortran 77 compiler... yes
    checking whether i686-pc-linux-gnu-gfortran accepts -g... yes
    checking the maximum length of command line arguments... 98304
    checking command to parse /usr/bin/nm -B output from i686-pc-linux-gnu-gcc object... ok
    checking for objdir... .libs
    checking for i686-pc-linux-gnu-ar... i686-pc-linux-gnu-ar
    checking for i686-pc-linux-gnu-ranlib... i686-pc-linux-gnu-ranlib
    checking for i686-pc-linux-gnu-strip... i686-pc-linux-gnu-strip
    checking if i686-pc-linux-gnu-gcc supports -fno-rtti -fno-exceptions... no
    checking for i686-pc-linux-gnu-gcc option to produce PIC... -fPIC
    checking if i686-pc-linux-gnu-gcc PIC flag -fPIC works... yes
    checking if i686-pc-linux-gnu-gcc static flag -static works... yes
    checking if i686-pc-linux-gnu-gcc supports -c -o file.o... yes
    checking whether the i686-pc-linux-gnu-gcc linker (/usr/i686-pc-linux-gnu/bin/ld) supports shared libraries... yes
    checking whether -lc should be explicitly linked in... no
    checking dynamic linker characteristics... GNU/Linux ld.so
    checking how to hardcode library paths into programs... immediate
    checking whether stripping libraries is possible... yes
    checking if libtool supports shared libraries... yes
    checking whether to build shared libraries... yes
    checking whether to build static libraries... yes
    configure: creating libtool
    appending configuration tag "CXX" to libtool
    checking for ld used by i686-pc-linux-gnu-g++... /usr/i686-pc-linux-gnu/bin/ld
    checking whether the i686-pc-linux-gnu-g++ linker (/usr/i686-pc-linux-gnu/bin/ld) supports shared libraries... yes
    checking for i686-pc-linux-gnu-g++ option to produce PIC... -fPIC
    checking if i686-pc-linux-gnu-g++ PIC flag -fPIC works... yes
    checking if i686-pc-linux-gnu-g++ static flag -static works... yes
    checking if i686-pc-linux-gnu-g++ supports -c -o file.o... yes
    appending configuration tag "F77" to libtool
    checking for i686-pc-linux-gnu-gfortran option to produce PIC... -fPIC
    checking if i686-pc-linux-gnu-gfortran PIC flag -fPIC works... yes
    checking if i686-pc-linux-gnu-gfortran static flag -static works... yes
    checking if i686-pc-linux-gnu-gfortran supports -c -o file.o... yes
    checking whether the i686-pc-linux-gnu-gfortran linker (/usr/i686-pc-linux-gnu/bin/ld) supports shared libraries... yes
    checking for glib-genmarshal... /usr/bin/glib-genmarshal
    FYI:  Will build without *any* debugging code
    checking for i686-pc-linux-gnu-pkg-config... no
    checking for pkg-config... /usr/bin/pkg-config
    checking pkg-config is at least version 0.9.0... yes
    checking for DEPENDENT... yes
    checking for DEPENDENT_WITH_XML... yes
    checking for DEPENDENT_WITH_GTK... yes
    checking for DEPENDENT_WITH_XML_AND_GTK... yes
    checking pthread.h usability... yes
    checking pthread.h presence... yes
    checking for pthread.h... yes
    checking syslog.h usability... yes
    checking syslog.h presence... yes
    checking for syslog.h... yes
    checking sys/wait.h usability... yes
    checking sys/wait.h presence... yes
    checking for sys/wait.h... yes
    checking for getuid... yes
    checking for sigaction... yes
    checking for fsync... yes
    checking for fchmod... yes
    checking for fdwalk... no
    checking ldap.h usability... no
    checking ldap.h presence... no
    checking for ldap.h... no
    checking for ldap_ntlm_bind... no
    checking for intltool >= 0.35.0... 0.36.2 found
    checking for perl... /usr/bin/perl
    checking for XML::Parser... configure: error: XML::Parser perl module is required for intltool
    !!! Please attach the following file when filing a report to bugs.gentoo.org:
    !!! /var/tmp/portage/gnome-base/gconf-2.20.1/work/GConf-2.20.1/config.log
     * ERROR: gnome-base/gconf-2.20.1 failed.
     * Call stack:
     *       ebuild.sh, line 1701:  Called dyn_compile
     *       ebuild.sh, line 1039:  Called qa_call 'src_compile'
     *       ebuild.sh, line   44:  Called src_compile
     *       ebuild.sh, line 1383:  Called gnome2_src_compile
     *   gnome2.eclass, line   70:  Called gnome2_src_configure
     *   gnome2.eclass, line   66:  Called econf '--enable-gtk' '--disable-debug' '--disable-gtk-doc'
     *       ebuild.sh, line  638:  Called die
     * The specific snippet of code:
     *   			die "econf failed"
     *  The die message:
     *   econf failed
     * If you need support, post the topmost build error, and the call stack if relevant.
     * A complete build log is located at '/var/tmp/portage/gnome-base/gconf-2.20.1/temp/build.log'.
    also meiner Meinung nach befindet sich mein Sys durchaus im Besitzt eines XML Parsers
    dev-perl/XML-Parser ist emerged ... weiß vielleicht jemand woran es liegt und wie man es ggf. fixen kann?
  3. #2 supersucker, 10.01.2008
    supersucker
    supersucker Foren Gott
    21.02.2005
    3.873
    Ja, und was soll das nun "deiner Meinung" nach heißen?
    Installiert oder nicht?
    Was sagt
    eix dev-perl/XML-Parser
  4. #3 karloff, 10.01.2008
    karloff
    karloff Routinier
    09.07.2007
    317
    karloff@****** ~ $ eix dev-perl/XML-Parser
    [I] dev-perl/XML-Parser
         Available versions:  2.34 2.34-r1
         Installed versions:  2.34-r1(21:58:12 01/09/08)
         Homepage:            http://search.cpan.org/~msergeant/
         Description:         A Perl extension interface to James Clark's XML parser, expat
  5. #4 supersucker, 10.01.2008
    supersucker
    21.02.2005
    3.873
    Ich tippe mal stark auf libexpat und würde wetten, das das was hier steht:
    Klick mich
    auch bei dir der Fall ist.
    Also:
    -> Link komplett lesen
    -> verstehen
    -> probieren
    -> melden wenn du nicht weiterkommst
Problem beim emergen (xml parser) - Ähnliche Themen
  1. Probleme beim installieren
