nxserver von außen erreichen, macht probleme
Diskutiere nxserver von außen erreichen, macht probleme im Debian/Ubuntu/Knoppix Forum im Bereich Linux Distributionen; # # General FreeNX directives # ######################################################################### # # # The host name which is...
  1. #1 seeadler, 11.08.2006
    seeadler
    seeadler Tripel-As
    06.11.2005
    175
    # The host name which is used by NX server. It's should be used if it's
    # different than the default hostname (as returned by `hostname`)
    #SERVER_NAME="$(hostname)"
    # The port number where local 'sshd' is listening.
    #SSHD_PORT=22
    # Authentication / Security directives
    # Authentication directives
    # This adds the usermode to the possible authentication methods
    # Usermode means that a user can start the nxserver as his shell
    # and connect directly to the right server via a custom client.
    #ENABLE_USERMODE_AUTHENTICATION="0"
    # This adds the passdb to the possible authentication methods
    #ENABLE_PASSDB_AUTHENTICATION="1"
    # This adds SSH to the possible authentication methods. For it to work sshd
    # must be set up at localhost accepting password authentication.
    #ENABLE_SSH_AUTHENTICATION="1"
    # This adds SU to the possible authentication methods. For it to work the
    # "nx" user must be in the wheel (RedHat, Fedora) or the users group (SUSE)
    # and the user logging in must have a valid shell that accepts the -c
    # parameter.
    #ENABLE_SU_AUTHENTICATION="0"
    # Require all users to be in the passdb, regardless of authentication method
    #ENABLE_USER_DB="0"
    # If enabled forces the user to use encryption. This will bail out
    # if the user does not have encryption enabled.
    #ENABLE_FORCE_ENCRYPTION="0"
    # Refuse the NX client connection if SSHD does not export the
    # SSH_CONNECTION and SSH_CLIENT variables in the environment
    # passed to the NX server.
    # 1: Will check the remote IP and will not accept the
    # connection if it can't be determined.
    # 0: Will accept the connection even if the remote IP
    # is not provided.
    #SSHD_CHECK_IP="0"
    # If set to greater zero, nxserver will timeout after that many seconds
    # before authentication succeeds.
    #NX_SERVER_TIMEOUT="10"
    # Restriction directives
    # The base display number from which sessions are started.
    #DISPLAY_BASE=1000
    # The maximum number of contemporary sessions that can be run on FreeNX
    #SESSION_LIMIT=200
    # The maximum number of contemporary sessions that a single user can run
    # on FreeNX. Defaults to the value of SESSION_LIMIT.
    #SESSION_USER_LIMIT=200
    # The number of displays reserved for sessions, it has to be greater or equal
    # to the maximum number of contemporary sessions that a server can run.
    #DISPLAY_LIMIT=200
    # User for which sessions should be persistent. Either the keyword "all" or a
    # comma-separated list of usernames or groups in the @groupname syntax.
    #ENABLE_PERSISTENT_SESSION="all"
    # Users and groups for whom persistent sessions should be disabled.
    # Especially useful if ENABLE_PERSISTENT_SESSION="all"
    #DISABLE_PERSISTENT_SESSION=""
    # Logging directives
    # This directives controls the verbosity of the server-wide log.
    # 0: No Logging
    # 1: Errors
    # 2: Warnings
    # 3: Important information
    # 4: Server - Client communication
    # 5: Information
    # 6: Debugging information
    # 7: stderror of some applications
    #NX_LOG_LEVEL=0
  3. hehejo
    hehejo blöder Purist
    12.10.2003
    1.280
    Stein (Mittelfranken)
    Lern doch bitte erstmal deine Frage zu stellen.
    Wir sind hier ja willig zu helfen.
    Aber das schießt doch eindeutig den Vogel ab!
  4. #3 Wolfgang, 11.08.2006
    Wolfgang
    Wolfgang Foren Gott
    24.04.2005
    3.978
    Erfurt
    Problem zu verstehen macht Probleme
    :D
    Was willst du fragen?
    Aber Jeder hat eine zweite Chance. :devil:
    Debian oder Ubuntu?
    Wolfgang
  5. #4 seeadler, 12.08.2006
    seeadler
    seeadler Tripel-As
    06.11.2005
    175
    sorry, tut mir leid;
    system: debian etch
    meine ddclient konfiguration
    # Configuration file for ddclient generated by debconf
    # /etc/ddclient.conf
    id=/var/run/ddclient.pid
    protocol=dyndns2
    use=web
    server=members.dyndns.org
    login=xxxxx
    password='xxxx'
    xxxxx.dyndns.org
    wenn ich mich nun mit dem nxclient von einer windows machine mit dem nxserver auf debian verbinden möchte, wird folgende meldung ausgegeben:
    neoiating failure
    meine nxserver konfiguration:
    #SSHD_PORT=22
    # parameter.
    #ENABLE_USER_DB="0"
    # is not provided.
    #SSHD_CHECK_IP="0"
    #DISPLAY_BASE=1000
    #SESSION_LIMIT=200
    #DISPLAY_LIMIT=200
    # 0: No Logging
    # 1: Errors
    # 2: Warnings
    # 5: Information
    #NX_LOG_LEVEL=0
    aus im lan erreiche ich meinen server ohne probleme
    welche konfiguration muss ich vornehmen, damit ich auch meinen nxserver von außen erreiche?
  6. #5 Nemesis, 12.08.2006
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
    stichwort "portforwarding" am router
    editier mal bitte die posts und setz den code in
    -tags
  7. #6 seeadler, 12.08.2006
    seeadler
    seeadler Tripel-As
    06.11.2005
    175
    haben den port 22 am router geforwardet
    tcp 22/22
  8. #7 Nemesis, 12.08.2006
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
    und jetzt kommst du nich via ssh auf den pc?
  9. Anzeige
  10. #8 seeadler, 12.08.2006
    seeadler
    seeadler Tripel-As
    06.11.2005
    175
    wenn ich das programm putty auf dem windows - rechner habe und ich mit diesem auf den linux server verbinden möchte,
    ist diese Verbindung dann auch verschlüsselt?
  11. #9 Nemesis, 13.08.2006
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
nxserver von außen erreichen, macht probleme - Ähnliche Themen
  1. NxServer von außen erreichen
    NxServer von außen erreichen: Hallo Leute, ich habe einen Sarge Server laufen folgende Dienste laufen bereits NxServer, ich möchte mich jedoch von einem Client aus der...
  2. CentOS - nxserver - keyboard problem
    CentOS - nxserver - keyboard problem: :hilfe2: Hallo zusammen. Zuerst mal Angaben zum System: CentOS release 5.5 (final) nxserver, client und node von der Homepage (gestern...
  3. kann nxserver nicht konfigurieren
    kann nxserver nicht konfigurieren: hallo, nutze neben opensuse 10.3 noch debiann etch 4.0 habe wie folgt den nxserver installiert dpkg -i nxclient_3.0.0-89_i386.deb dpkg -i...
  4. Als root am NXServer anmelden?
    Als root am NXServer anmelden?: Halli Hallo! Habe gerade NXServer auf meinem Linux/Debian Server inkl. NXClient auf meiner Windows Maschine installiert. Mein Hauptaccount...
  5. nxserver konfiguration
    nxserver konfiguration: hallo, ich habe folgendes problem: ich habe nxserver installiert, nun starte ich nxsetup. welche .config verwendet nxsetup?...
