Daten auf CD bringen k3b, gnomebaker, cdtoast und Nautilus
Diskutiere Daten auf CD bringen k3b, gnomebaker, cdtoast und Nautilus im RedHat,Fedora & CentOS Forum im Bereich Linux Distributionen; Daten auf eine CD schreiben bringt nicht das gewuenschte Ergebniss. System ----------------------- K3b Version: 0.12.10 KDE Version:...
  1. #1 intelinsider, 31.03.2006
    intelinsider
    intelinsider coffee addicted
    30.04.2005
    333
    Tor zur Welt [Hamburg/Barmbek]
    System
    KDE Version: 3.5.1-2.3 Red Hat
    QT Version:  3.3.5
    Kernel:      2.6.16-1.2080_FC5smp
    Devices
    TOSHIBA ODD-DVD SD-M1802 1034 (/dev/hdh, ) at  [CD-Rom; DVD-Rom] [DVD-Rom; CD-Rom] [Keine]
    HL-DT-ST DVDRAM GSA-4081B A104 (/dev/hdd, ) at  [CD-R; CD-RW; CD-Rom; DVD-Rom; DVD-Ram; DVD-R; DVD-RW; DVD+R; DVD+RW] [DVD-Rom; DVD-R Sequentiell; DVD-Ram; DVD-RW Eingeschränktes Überbrennen; DVD-RW Sequentiell; DVD+RW; DVD+R; CD-Rom; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96P; SAO/R96R; RAW/R16; RAW/R96P; RAW/R96R; Eingeschränktes Überschreiben]
    LITE-ON LTR-52327S QS0E (/dev/hdc, ) at  [CD-R; CD-RW; CD-Rom] [CD-Rom; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96P; SAO/R96R; RAW/R16; RAW/R96P; RAW/R96R]
    Used versions
    cdrecord: 2.1.1a03
    cdrecord command:
    /usr/bin/cdrecord -v gracetime=2 dev=/dev/hdc speed=52 -tao driveropts=burnfree -eject blank=fast -force
    cdrecord
    /usr/bin/cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2).
    /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns.
    /usr/bin/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
    /usr/bin/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
    scsidev: '/dev/hdc'
    devname: '/dev/hdc'
    scsibus: -2 target: -2 lun: -2
    Error trying to open /dev/hdc exclusively ... retrying in 1 second.
    /usr/bin/cdrecord: Device or resource busy. Cannot open '/dev/hdc'. Cannot open SCSI driver.
    /usr/bin/cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root.
    /usr/bin/cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
    Cdrecord-Clone 2.01.01a03-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2005 Jörg Schilling
    NOTE: This version contains the OSS DVD extensions for cdrtools and thus may
          have bugs related to DVD issues that are not present in the original
          cdrtools. Please send bug reports or support requests to
          http://bugzilla.redhat.com/bugzilla The original cdrtools author should
          not be bothered with problems in this version.
    TOC Type: 1 = CD-ROM
    Das wird mir kurz darauf von nahezu jedem Programm in etwas abgewandelter Form angezeigt, ich kann keine CDR(W)'s loeschen oder bespielen immer wieder haengt es dort, auch "cdrecord --scanbus" brachte nicht den gewuenschten Erfolg
    Hat jemand eine Idee was hier der ausloeser sein koennte?
    mfg ii
  3. #2 hoernchen, 31.03.2006
    hoernchen
    hoernchen UBERgarstiges nagetier
    17.02.2005
    1.081
    naja, er kann nicht aufs laufwerk zugreifen weil es grad was tut. das les ich zumindest raus.
  4. #3 Snowman, 31.03.2006
    Snowman
    Snowman Linux User
    22.03.2006
    58
    Moin,
    wenn ich das richtig lese probiert er über SCSI auf den brenner zuzugreifen.
    Hast du ein scsi Brenner?
    Probier mal das:
    cdrecord --scanbus dev=ATAPI
  5. #4 hoernchen, 31.03.2006
    hoernchen
    17.02.2005
    1.081
    hoppala, stimmt. erst ab 9 sollt ich antworten :-)
  6. #5 Snowman, 31.03.2006
    Snowman
    Snowman Linux User
    22.03.2006
    58
    Ich bin auch noch nicht wach.
  7. #6 intelinsider, 31.03.2006
    intelinsider
    30.04.2005
    333
    kein scsi
    Nein ich habe keinen SCSI Brenner, nicht einmal einen Controller dafuer
    System
    QT Version:  3.3.5
    Devices
    Used versions
    cdrecord: 2.1.1a03
    cdrecord command:
    /usr/bin/cdrecord -v gracetime=2 dev=/dev/hdc speed=52 -tao driveropts=burnfree -eject -overburn blank=fast -force
    cdrecord
    scsidev: '/dev/hdc'
    devname: '/dev/hdc'
    Gibt er mir aus nachdem ich "cdrecord --scanbus dev=ATAPI" eingeben habe
    ich kann also nach wie vor weder schreiben noch loeschen.
    mfg ii
    Lege ich eine CDR ein und bespiele ihn funktioniert lasse ich die letzte Session offen um sie irgendwann fortzusetzen funtkioniert nicht, CDRW loeschen oder fortzsetzen funktioniert nicht ebenso siehts wie mit DVDr und re aus,,,
    Irgendwie laeuft dort etwas mit dem automounten der CDs falsch und den rechten...
    nur momentan finde ich keinen Rat dies zu beheben.
Daten auf CD bringen k3b, gnomebaker, cdtoast und Nautilus - Ähnliche Themen
  1. Python Softwareentwickler (Hintergrundentwicklung und Datenanalyse)
    Python Softwareentwickler (Hintergrundentwicklung und Datenanalyse): Stelle : Software-Entwickler Anzahl : 3 Standort : Manila(Die Philippinen) Dezhong Investment LTD. Unser internationales...
  2. Neue Vision von KDE: Datenschutz, Freiheit, Privatsphäre
    Neue Vision von KDE: Datenschutz, Freiheit, Privatsphäre: Das KDE-Projekt hat sich eine neue Leitlinie gesetzt. Schon immer war es das Ziel des Projektes, mit seiner Arbeit die Welt ein Stückchen besser...
  3. Debian-Projektleiterwahl mit nur einem Kandidaten
    Debian-Projektleiterwahl mit nur einem Kandidaten: Bei der anstehenden jährlichen Debian-Projektleiterwahl tritt nur ein Kandidat an, der Franzose Mehdi Dogguy. Der amtierende Projektleiter Neil...
  4. Deutsche Bahn öffnet Fahrplandaten
    Deutsche Bahn öffnet Fahrplandaten: Über ein API stellt die Deutsche Bahn die aktuellen Fahrplandaten unter einer Creative-Commons-Lizenz allen Interessenten zur Nutzung bereit....
  5. Samba Datentransfer bricht ab
    Samba Datentransfer bricht ab: Hallo zusammen, ich suche seit 2 Tagen im Internet nach einer Lösung, aber ich finde einfach keine brauchbare. Folgendes Szenario: Ich vor einem...
