Hallo Bonk
Post: OK, Sorry.
demsg ist aber Ellenlang.
Gruss, Werner
Linux version 2.6.9-kanotix-8 (root@Kanotix) (gcc version 3.3.5 (Debian 1:3.3.5-2)) #1 Fri Nov 26 14:51:09 CET 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000d8000 - 00000000000e0000 (reserved)
BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fef0000 (usable)
BIOS-e820: 000000001fef0000 - 000000001feff000 (ACPI data)
BIOS-e820: 000000001feff000 - 000000001ff00000 (ACPI NVS)
BIOS-e820: 000000001ff00000 - 0000000020000000 (reserved)
BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
510MB LOWMEM available.
On node 0 totalpages: 130800
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 126704 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
DMI present.
ACPI: RSDP (v000 PTLTD ) @ 0x000f6d90
ACPI: RSDT (v001 PTLTD RSDT 0x06040000 LTP 0x00000000) @ 0x1fefa663
ACPI: FADT (v001 ALI M1533 0x06040000 PTL 0x000f4240) @ 0x1fefeeaf
ACPI: BOOT (v001 PTLTD $SBFTBL$ 0x06040000 LTP 0x00000001) @ 0x1fefef23
ACPI: SSDT (v001 PTLTD ACPIPST1 0x06040000 LTP 0x00000001) @ 0x1fefef4b
ACPI: DSDT (v001 ALI M1533 0x06040000 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x8008
Built 1 zonelists
Kernel command line: vga=0x317 root=/dev/hda2 ro ramdisk_size=100000 lang=de apm=power-off hda=scsi hdb=scsi hdc=scsi hdd=scsi hde=scsi hdf=scsi hdg=scsi hdh=scsi nomce vga=0x317
ide_setup: hda=scsi
ide_setup: hdb=scsi
ide_setup: hdc=scsi
ide_setup: hdd=scsi
ide_setup: hde=scsi
ide_setup: hdf=scsi
ide_setup: hdg=scsi
ide_setup: hdh=scsi
No local APIC present or hardware disabled
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 32768 bytes)
Detected 1194.971 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 510216k/523200k available (2709k kernel code, 12384k reserved, 1183k data, 264k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 2367.48 BogoMIPS (lpj=1183744)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 3febf9ff 00000000 00000000 00000000
CPU: After vendor identify, caps: 3febf9ff 00000000 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: After all inits, caps: 3febf9ff 00000000 00000000 00000080
CPU: Intel(R) Pentium(R) 4 Mobile CPU 2.00GHz stepping 04
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: Looking for DSDT in initrd... not found.
ACPI: IRQ9 SCI: Edge set to Level Trigger.
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Freeing initrd memory: 3399k freed
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfd58e, last bus=3
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040816
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs *10)
ACPI: PCI Interrupt Link [LNKB] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 10) *11
ACPI: PCI Interrupt Link [LNKD] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 10) *11
ACPI: PCI Interrupt Link [LNKF] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 10) *11
ACPI: PCI Interrupt Link [LNKH] (IRQs 11) *10
ACPI: PCI Interrupt Link [LNKU] (IRQs 10) *11
ACPI: Embedded Controller [EC] (gpe 34)
Linux Plug and Play Support v0.97 (c) Adam Belay
SCSI subsystem initialized
PCI: Using ACPI for IRQ routing
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:06.0[A] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:08.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:0a.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:0b.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:0f.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI interrupt 0000:00:10.0[A]: no GSI
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
ACPI: PCI interrupt 0000:00:13.0[A] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt 0000:00:13.1[A] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt Link [LNKU] enabled at IRQ 10
ACPI: PCI interrupt 0000:00:14.0[A] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 10 (level, low) -> IRQ 10
TC classifier action (bugs to ********** cc **********)
Simple Boot Flag at 0x37 set to 0x1
Machine check exception polling timer started.
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
Activating ISA DMA hang workarounds.
vesafb: framebuffer at 0xe8000000, mapped to 0xe0880000, size 3072k
vesafb: mode is 1024x768x16, linelength=2048, pages=1
vesafb: protected mode interface info at c000:e670
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Generic RTC Driver v1.07
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Using anticipatory io scheduler
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 100000K size 1024 blocksize
loop: AES key scrubbing enabled
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ALI15X3: IDE controller at PCI slot 0000:00:10.0
ALI15X3: chipset revision 196
ALI15X3: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x2480-0x2487, BIOS settings: hda
MA, hdb:pio
ide1: BM-DMA at 0x2488-0x248f, BIOS settings: hdc
MA, hdd:pio
Probing IDE interface ide0...
hda: IC25N040ATCS04-0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: SONY CD-RW/DVD-ROM CRX820E, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
ide2: Wait for ready failed before probe !
Probing IDE interface ide3...
ide3: Wait for ready failed before probe !
Probing IDE interface ide4...
ide4: Wait for ready failed before probe !
Probing IDE interface ide5...
ide5: Wait for ready failed before probe !
hda: max request size: 128KiB
hda: 78140160 sectors (40007 MB) w/1768KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2
ide-cd: passing drive hdc to ide-scsi emulation.
ide-scsi is deprecated for cd burning! Use ide-cd and give dev=/dev/hdX as device
scsi0 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: SONY Model: CD-RW CRX820E Rev: 1.0a
Type: CD-ROM ANSI SCSI revision: 02
3ware Storage Controller device driver for Linux v1.26.00.039.
3w-xxxx: No cards found.
3ware 9000 Storage Controller device driver for Linux v2.26.02.001.
libata version 1.02 loaded.
sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
Attached scsi CD-ROM sr0 at scsi0, channel 0, id 0, lun 0
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
Synaptics Touchpad, model: 1
Firmware: 5.8
180 degree mounted touchpad
Sensor: 18
new absolute packet format
Touchpad has extended capability bits
-> 4 multi-buttons, i.e. besides standard buttons
-> multifinger detection
-> palm detection
input: SynPS/2 Synaptics TouchPad on isa0060/serio1
md: linear personality registered as nr 1
md: raid0 personality registered as nr 2
md: raid1 personality registered as nr 3
md: raid10 personality registered as nr 9
md: raid5 personality registered as nr 4
raid5: automatically using best checksumming function: pIII_sse
pIII_sse : 1500.000 MB/sec
raid5: using function: pIII_sse (1500.000 MB/sec)
raid6: int32x1 296 MB/s
raid6: int32x2 433 MB/s
raid6: int32x4 273 MB/s
raid6: int32x8 300 MB/s
raid6: mmxx1 980 MB/s
raid6: mmxx2 1230 MB/s
raid6: sse1x1 628 MB/s
raid6: sse1x2 875 MB/s
raid6: sse2x1 1046 MB/s
raid6: sse2x2 1289 MB/s
raid6: using algorithm sse2x2 (1289 MB/s)
md: raid6 personality registered as nr 8
md: multipath personality registered as nr 7
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: **********
EISA: Probing bus 0 at eisa0
Cannot allocate resource for EISA slot 1
Cannot allocate resource for EISA slot 2
Cannot allocate resource for EISA slot 3
Cannot allocate resource for EISA slot 8
EISA: Detected 0 cards.
NET: Registered protocol family 2
IP: routing cache hash table of 4096 buckets, 32Kbytes
TCP: Hash tables configured (established 32768 bind 65536)
Software Suspend Core.
Software Suspend text mode support loaded.
Software Suspend LZF Compression Driver registered.
Software Suspend Gzip Compression Driver registered.
Software Suspend Device Mapper support registering.
Software Suspend Swap Writer registered.
Software Suspend Checksum Module
ACPI: (supports S0 S3 S4 S5)
ACPI wakeup devices:
SLPB LID MDM CRD0 LAN
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 264k freed
ReiserFS: hda2: found reiserfs format "3.6" with standard journal
ReiserFS: hda2: using ordered data mode
ReiserFS: hda2: journal params: device hda2, size 8192, journal first block 18,max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda2: checking transaction log (hda2)
ReiserFS: hda2: Using r5 hash to sort names
NTFS driver 2.1.20 [Flags: R/W MODULE].
NTFS volume version 3.1.
ACPI: AC Adapter [AC] (on-line)
ACPI: Battery Slot [BAT0] (battery present)
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
ACPI: Processor [CPU0] (supports C1 C2 C3, 8 throttling states)
ACPI: Thermal Zone [THRS] (24 C)
ACPI: Thermal Zone [THRC] (24 C)
Linux Kernel Card Services
options: [pci] [cardbus] [pm]
Yenta: CardBus bridge found at 0000:00:13.0 [1025:102b]
Yenta: ISA IRQ mask 0x04b8, PCI irq 11
Socket status: 30000006
Yenta: CardBus bridge found at 0000:00:13.1 [1025:102b]
Socket status: 30000410
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
ohci_hcd: 2004 Feb 02 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ohci_hcd 0000:00:0f.0: ALi Corporation USB 1.1 Controller
ohci_hcd 0000:00:0f.0: irq 10, pci mem e0c6a000
ohci_hcd 0000:00:0f.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd 0000:00:14.0: ALi Corporation USB 1.1 Controller (#2)
ohci_hcd 0000:00:14.0: irq 10, pci mem e0c6c000
ohci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usb 1-1: new low speed USB device using address 2
input: Logitech USB Mouse on usb-0000:00:0f.0-1
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
usbcore: registered new driver usbmouse
drivers/usb/input/usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
ts: Compaq touchscreen protocol output
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
Serial: 8250/16550 driver $Revision: 1.90 $ 14 ports, IRQ sharing disabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 5
8139too Fast Ethernet driver 0.9.27
eth0: RealTek RTL8139 at 0xe0cd2000, 00:0a:e4:00:18:91, IRQ 10
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
input: PC Speaker
Linux agpgart interface v0.100 (c) Dave Jones
NET: Registered protocol family 17
agpgart: Detected ALi M1671 chipset
agpgart: Maximum main memory to use for agp memory: 438M
agpgart: AGP aperture is 128M @ 0xf0000000
eth0: link down
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
cs: IO port probe 0x0100-0x04ff: excluding 0x200-0x207 0x220-0x22f 0x330-0x337 0x378-0x37f 0x388-0x38f 0x408-0x40f 0x480-0x48f 0x4d0-0x4d7
cs: IO port probe 0x0800-0x08ff: clean.
cs: IO port probe 0x0c00-0x0cff: clean.
cs: IO port probe 0x3000-0x7fff: clean.
cs: IO port probe 0x0a00-0x0aff: clean.
cs: memory probe 0xe0100000-0xe17fffff: excluding 0xe0f60000-0xe17fffff
parport0: PC-style at 0x378 [PCSPP,TRISTATE,EPP]
lp0: using parport0 (polling).
lp0: console ready
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
mtrr: 0xe8000000,0x2000000 overlaps existing 0xe8000000,0x200000
spurious 8259A interrupt: IRQ7.
SMB connection re-established (-5)
