Xorg Widescreen Problem
espo
espo
On the dark side
Hallo zusammen,
wenn ich diese Xorg config verwende:
Section "ServerLayout"
    Identifier     "single head configuration"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
    ModulePath   "/usr/lib/xorg/modules"
    RgbPath    "/usr/share/X11/rgb"
    FontPath    "/usr/share/fonts/misc"
    FontPath    "/usr/share/fonts/TTF"
    FontPath    "/usr/share/fonts/Type1"
    FontPath    "/usr/share/fonts/100dpi"
    FontPath    "/usr/share/fonts/75dpi"
    FontPath    "/usr/share/fonts/encodings"
    FontPath    "/usr/share/fonts/util"
    FontPath    "/usr/share/fonts/artwiz-fonts"
EndSection
Section "Module"
    Load  "dbe"
    Load  "extmod"
    Load  "glx"
    Load  "freetype"
    Load  "dri"
EndSection
Section "InputDevice"
    Identifier  "Keyboard0"
    Driver      "kbd"
    Option      "XkbModel" "pc105"
    Option      "XkbLayout" "us"
EndSection
    Identifier  "Mouse0"
    Driver      "mouse"
    Option      "Protocol" "IMPS/2"
    Option      "Device" "/dev/input/mice"
    Option      "ZAxisMapping" "4 5"
    Option      "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
    Identifier   "Monitor0"
    VendorName   "Samsung"
    ModelName    "SyncMaster 205BW"
    Modeline    "1680x1050_75.00"  188.07  1680 1800 1984 2288 1050 1051 1054 1096  -HSync +Vsync
    Option       "dpms"
    # Important. At least on my setup it doesn't detect the size
    # If not specified, the fonts may look very tiny.
    # Numbers found on a random web site using Google.
    DisplaySize  430 270
    # Those are the magic values that make it all work.
    HorizSync    30.0 - 75.0
    VertRefresh  56.0 - 80.0
    ## This allowed for resolutions in the 19AAxBBBB
    ## See also the Virtual directive in Display subsection below
    #VertRefresh 56.0 - 83.0
EndSection
Section "Device"
    Identifier  "Device0"
    # Other important bit. The radeon driver is mature enough, as been said in #xorg
    Driver      "savage"
    VendorName  "Savage"
    BoardName   "S3 Savage MX"
    #Option "UseBIOS" "Off"
    Option "NoAccel" "True"
    BusID       "PCI:1:0:0"
    VideoRam    16000
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Device0"
    Monitor    "Monitor0"
    DefaultDepth     16
    SubSection "Display"
        Viewport    0 0
        # Fix the viewable area to 1680x1050, or something
    Modes "1680x1050"
    #Virtual     1680 1050
        Depth       16
    EndSubSection
EndSection
Section "DRI"
    Group       0
    Mode        0666
EndSection
nimmt er immer automatisch die aufloesung 1600x1200 nur leider ist der TFT darauf nicht optimiert und dementsprechend bescheiden sieht das ergebnis dann aus.
Vielleicht kann mir einer von euch helfen.
Gruss
eSpo
probier doch mal diese Screen Section:
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 16
Viewport 0 0
Depth 16
Modes ">> Deine Auflösung bsp: 1024x768 <<"
EndSubSection
EndSection
Mfg
sebi
Ich hatte das gleiche Problem, als ich Knoppix mal starten wollte. Vielleicht mal beim Booten ein paar Optionen übergeben, so z.B. bei Knoppix:
knoppix screen=1440x900
MfG, Hardcoder.
xorg.conf fuer samsung syncmaster 205bw
hallo, habe hier die loesung,
meine xorg.conf funktioniert, ubuntu 6.10, ati radeon 9250, DVI-connected, fglrx-driver enabled... alles geht, entscheidend war am ende die ModeLine unter section monitor,,,,
hier die xorg.conf:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "Files"
# path to defoma fonts
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbLayout" "de"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ExplorerPS/2"
Option "Emulate3Buttons" "true"
EndSection
# /dev/input/event
# for USB
Identifier "stylus"
Driver "wacom"
Option "Device" "/dev/wacom" # Change to
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
# /dev/input/event
# for USB
Identifier "eraser"
Driver "wacom"
Option "Type" "eraser"
EndSection
# /dev/input/event
# for USB
Identifier "cursor"
Driver "wacom"
Option "Type" "cursor"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
DisplaySize 433 270
HorizSync 30.0 - 81.0
VertRefresh 56.0 - 75.0
Option "DPMS" "true"
ModeLine "1680x1050" 146.8 1680 1784 1960 2240 1050 1053 1059 1089
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. RV280 [Radeon 9200 PRO]"
Driver "fglrx"
Option "ForceMonitors" "tmds1"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "ATI Technologies, Inc. RV280 [Radeon 9200 PRO]"
Monitor "SyncMaster"
DefaultDepth 24
Viewport 0 0
Depth 24
Modes "1680x1050"
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
X startet nichtmehr
Zweiter Monitor geht bei Vollbildspielen aus.
