Dec 28 12:06:53 Nathan kernel: klogd 1.4.1#20, log source = /proc/kmsg started.
Dec 28 12:06:53 Nathan kernel: Linux version 2.6.16-2-k7 (Debian 2.6.16-1
(fs@debian.org) (gcc version 4.0.4 20060730 (prerelease) (Debian 4.0.3-6)) #1 Fri Aug 18 19:48:42 UTC 2006
Dec 28 12:06:53 Nathan kernel: BIOS-provided physical RAM map:
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 000000001fff0000 - 000000001fff8000 (ACPI data)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 000000001fff8000 - 0000000020000000 (ACPI NVS)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Dec 28 12:06:53 Nathan kernel: BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
Dec 28 12:06:53 Nathan kernel: 0MB HIGHMEM available.
Dec 28 12:06:53 Nathan kernel: 511MB LOWMEM available.
Dec 28 12:06:53 Nathan kernel: On node 0 totalpages: 131056
Dec 28 12:06:53 Nathan kernel: DMA zone: 4096 pages, LIFO batch:0
Dec 28 12:06:53 Nathan kernel: DMA32 zone: 0 pages, LIFO batch:0
Dec 28 12:06:53 Nathan kernel: Normal zone: 126960 pages, LIFO batch:31
Dec 28 12:06:53 Nathan kernel: HighMem zone: 0 pages, LIFO batch:0
Dec 28 12:06:53 Nathan kernel: DMI 2.3 present.
Dec 28 12:06:53 Nathan kernel: ACPI: RSDP (v000 AMI ) @ 0x000fa8a0
Dec 28 12:06:53 Nathan kernel: ACPI: RSDT (v001 AMIINT VIA_K7 0x00000010 MSFT 0x00000097) @ 0x1fff0000
Dec 28 12:06:53 Nathan kernel: ACPI: FADT (v001 AMIINT VIA_K7 0x00000011 MSFT 0x00000097) @ 0x1fff0030
Dec 28 12:06:53 Nathan kernel: ACPI: MADT (v001 AMIINT VIA_K7 0x00000009 MSFT 0x00000097) @ 0x1fff00c0
Dec 28 12:06:53 Nathan kernel: ACPI: DSDT (v001 VIA KT266A 0x00001000 MSFT 0x0100000d) @ 0x00000000
Dec 28 12:06:53 Nathan kernel: ACPI: PM-Timer IO Port: 0x808
Dec 28 12:06:53 Nathan kernel: ACPI: Local APIC address 0xfee00000
Dec 28 12:06:53 Nathan kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Dec 28 12:06:53 Nathan kernel: Processor #0 6:8 APIC version 16
Dec 28 12:06:53 Nathan kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Dec 28 12:06:53 Nathan kernel: IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
Dec 28 12:06:53 Nathan kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 28 12:06:53 Nathan kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Dec 28 12:06:53 Nathan kernel: ACPI: IRQ0 used by override.
Dec 28 12:06:53 Nathan kernel: ACPI: IRQ2 used by override.
Dec 28 12:06:53 Nathan kernel: ACPI: IRQ9 used by override.
Dec 28 12:06:53 Nathan kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Dec 28 12:06:53 Nathan kernel: Using ACPI (MADT) for SMP configuration information
Dec 28 12:06:53 Nathan kernel: Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Dec 28 12:06:53 Nathan kernel: Built 1 zonelists
Dec 28 12:06:53 Nathan kernel: Kernel command line: root=/dev/hdb6 ro ramdisk_size=100000 lang=de apm=power-off nomce vga=791
Dec 28 12:06:53 Nathan kernel: mapped APIC to ffffd000 (fee00000)
Dec 28 12:06:53 Nathan kernel: mapped IOAPIC to ffffc000 (fec00000)
Dec 28 12:06:53 Nathan kernel: Enabling fast FPU save and restore... done.
Dec 28 12:06:53 Nathan kernel: Enabling unmasked SIMD FPU exception support... done.
Dec 28 12:06:53 Nathan kernel: Initializing CPU#0
Dec 28 12:06:53 Nathan kernel: PID hash table entries: 2048 (order: 11, 32768 bytes)
Dec 28 12:06:53 Nathan kernel: Detected 1999.242 MHz processor.
Dec 28 12:06:53 Nathan kernel: Using pmtmr for high-res timesource
Dec 28 12:06:53 Nathan kernel: Console: colour dummy device 80x25
Dec 28 12:06:53 Nathan kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Dec 28 12:06:53 Nathan kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 28 12:06:53 Nathan kernel: Memory: 511544k/524224k available (1421k kernel code, 12092k reserved, 537k data, 144k init, 0k highmem)
Dec 28 12:06:53 Nathan kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Dec 28 12:06:53 Nathan kernel: Calibrating delay using timer specific routine.. 4004.80 BogoMIPS (lpj=8009617)
Dec 28 12:06:53 Nathan kernel: Security Framework v1.0.0 initialized
Dec 28 12:06:53 Nathan kernel: SELinux: Disabled at boot.
Dec 28 12:06:53 Nathan kernel: Capability LSM initialized
Dec 28 12:06:53 Nathan kernel: Mount-cache hash table entries: 512
Dec 28 12:06:53 Nathan kernel: CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
Dec 28 12:06:53 Nathan kernel: CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
Dec 28 12:06:53 Nathan kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Dec 28 12:06:53 Nathan kernel: CPU: L2 Cache: 256K (64 bytes/line)
Dec 28 12:06:53 Nathan kernel: CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000
Dec 28 12:06:53 Nathan kernel: CPU: AMD Athlon(tm) XP 2400+ stepping 01
Dec 28 12:06:53 Nathan kernel: Checking 'hlt' instruction... OK.
Dec 28 12:06:53 Nathan kernel: ENABLING IO-APIC IRQs
Dec 28 12:06:53 Nathan kernel: ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
Dec 28 12:06:53 Nathan kernel: checking if image is initramfs... it is
Dec 28 12:06:53 Nathan kernel: Freeing initrd memory: 4803k freed
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 16
Dec 28 12:06:53 Nathan kernel: ACPI: bus type pci registered
Dec 28 12:06:53 Nathan kernel: PCI: PCI BIOS revision 2.10 entry at 0xfdae1, last bus=1
Dec 28 12:06:53 Nathan kernel: PCI: Using configuration type 1
Dec 28 12:06:53 Nathan kernel: ACPI: Subsystem revision 20060127
Dec 28 12:06:53 Nathan kernel: ACPI: Interpreter enabled
Dec 28 12:06:53 Nathan kernel: ACPI: Using IOAPIC for interrupt routing
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Dec 28 12:06:53 Nathan kernel: PCI: Probing PCI hardware (bus 00)
Dec 28 12:06:53 Nathan kernel: PCI quirk: region 0800-087f claimed by vt8235 PM
Dec 28 12:06:53 Nathan kernel: PCI quirk: region 0400-040f claimed by vt8235 SMB
Dec 28 12:06:53 Nathan kernel: Boot video device is 0000:01:00.0
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Dec 28 12:06:53 Nathan kernel: ACPI: Power Resource [URP1] (off)
Dec 28 12:06:53 Nathan kernel: ACPI: Power Resource [URP2] (off)
Dec 28 12:06:53 Nathan kernel: ACPI: Power Resource [FDDP] (off)
Dec 28 12:06:53 Nathan kernel: ACPI: Power Resource [LPTP] (off)
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 10 11 12 14 15)
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Dec 28 12:06:53 Nathan kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Dec 28 12:06:53 Nathan kernel: pnp: PnP ACPI init
Dec 28 12:06:53 Nathan kernel: pnp: PnP ACPI: found 12 devices
Dec 28 12:06:53 Nathan kernel: PnPBIOS: Disabled by ACPI PNP
Dec 28 12:06:53 Nathan kernel: PCI: Using ACPI for IRQ routing
Dec 28 12:06:53 Nathan kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Dec 28 12:06:53 Nathan kernel: PCI: Bridge: 0000:00:01.0
Dec 28 12:06:53 Nathan kernel: IO window: c000-cfff
Dec 28 12:06:53 Nathan kernel: MEM window: dfa00000-dfafffff
Dec 28 12:06:53 Nathan kernel: PREFETCH window: cf900000-df8fffff
Dec 28 12:06:53 Nathan kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
Dec 28 12:06:53 Nathan kernel: audit: initializing netlink socket (disabled)
Dec 28 12:06:53 Nathan kernel: audit(1167307584.476:1): initialized
Dec 28 12:06:53 Nathan kernel: VFS: Disk quotas dquot_6.5.1
Dec 28 12:06:53 Nathan kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Dec 28 12:06:53 Nathan kernel: Initializing Cryptographic API
Dec 28 12:06:53 Nathan kernel: io scheduler noop registered
Dec 28 12:06:53 Nathan kernel: io scheduler anticipatory registered (default)
Dec 28 12:06:53 Nathan kernel: io scheduler deadline registered
Dec 28 12:06:53 Nathan kernel: io scheduler cfq registered
Dec 28 12:06:53 Nathan kernel: vesafb: framebuffer at 0xd0000000, mapped to 0xd0880000, using 3072k, total 65536k
Dec 28 12:06:53 Nathan kernel: vesafb: mode is 1024x768x16, linelength=2048, pages=41
Dec 28 12:06:53 Nathan kernel: vesafb: protected mode interface info at c000:549e
Dec 28 12:06:53 Nathan kernel: vesafb: scrolling: redraw
Dec 28 12:06:53 Nathan kernel: vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
Dec 28 12:06:53 Nathan kernel: Console: switching to colour frame buffer device 128x48
Dec 28 12:06:53 Nathan kernel: fb0: VESA VGA frame buffer device
Dec 28 12:06:53 Nathan kernel: isapnp: Scanning for PnP cards...
Dec 28 12:06:53 Nathan kernel: isapnp: No Plug & Play device found
Dec 28 12:06:53 Nathan kernel: PNP: PS/2 Controller [PNP0303
S2K,PNP0f13
S2M] at 0x60,0x64 irq 1,12
Dec 28 12:06:53 Nathan kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Dec 28 12:06:53 Nathan kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Dec 28 12:06:53 Nathan kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Dec 28 12:06:53 Nathan kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Dec 28 12:06:53 Nathan kernel: 00:02: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Dec 28 12:06:53 Nathan kernel: RAMDISK driver initialized: 16 RAM disks of 100000K size 1024 blocksize
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 2
Dec 28 12:06:53 Nathan kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Dec 28 12:06:53 Nathan kernel: IP route cache hash table entries: 8192 (order: 3, 32768 bytes)
Dec 28 12:06:53 Nathan kernel: TCP established hash table entries: 32768 (order: 5, 131072 bytes)
Dec 28 12:06:53 Nathan kernel: TCP bind hash table entries: 32768 (order: 5, 131072 bytes)
Dec 28 12:06:53 Nathan kernel: TCP: Hash tables configured (established 32768 bind 3276
Dec 28 12:06:53 Nathan kernel: TCP reno registered
Dec 28 12:06:53 Nathan kernel: TCP bic registered
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 17
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 8
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 20
Dec 28 12:06:53 Nathan kernel: Using IPI Shortcut mode
Dec 28 12:06:53 Nathan kernel: ACPI wakeup devices:
Dec 28 12:06:53 Nathan kernel: PCI0 UAR1 USB1 USB2 USB3 EHCI PS2M PS2K AC9 MC9 ILAN SLPB
Dec 28 12:06:53 Nathan kernel: ACPI: (supports S0 S1 S4 S5)
Dec 28 12:06:53 Nathan kernel: Freeing unused kernel memory: 144k freed
Dec 28 12:06:53 Nathan kernel: SCSI subsystem initialized
Dec 28 12:06:53 Nathan kernel: dc395x: Tekram DC395(U/UW/F), DC315(U) - ASIC TRM-S1040 v2.05, 2004/03/08
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 169
Dec 28 12:06:53 Nathan kernel: e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
Dec 28 12:06:53 Nathan kernel: e100: Copyright(c) 1999-2005 Intel Corporation
Dec 28 12:06:53 Nathan kernel: usbcore: registered new driver usbfs
Dec 28 12:06:53 Nathan kernel: usbcore: registered new driver hub
Dec 28 12:06:53 Nathan kernel: dc395x: Used settings: AdapterID=07, Speed=0(20.0MHz), dev_mode=0x7f
Dec 28 12:06:53 Nathan kernel: dc395x: AdaptMode=0xbf, Tags=4(16), DelayReset=1s
Dec 28 12:06:53 Nathan kernel: dc395x: Connectors: int50 Termination: Auto Low High
Dec 28 12:06:53 Nathan kernel: dc395x: Performing initial SCSI bus reset
Dec 28 12:06:53 Nathan kernel: scsi0 : Tekram DC395(U/UW/F), DC315(U) - ASIC TRM-S1040 v2.05, 2004/03/08
Dec 28 12:06:53 Nathan kernel: USB Universal Host Controller Interface driver v2.3
Dec 28 12:06:53 Nathan kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Dec 28 12:06:53 Nathan kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Dec 28 12:06:53 Nathan kernel: dc395x: Target 03: Sync: 48ns Offset 15 (20.8 MB/s)
Dec 28 12:06:53 Nathan kernel: Vendor: PLEXTOR Model: CD-ROM PX-40TS Rev: 1.13
Dec 28 12:06:53 Nathan kernel: Type: CD-ROM ANSI SCSI revision: 02
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 177
Dec 28 12:06:53 Nathan kernel: PCI: VIA IRQ fixup for 0000:00:10.0, from 11 to 1
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.0: UHCI Host Controller
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.0: irq 177, io base 0x0000d800
Dec 28 12:06:53 Nathan kernel: usb usb1: configuration #1 chosen from 1 choice
Dec 28 12:06:53 Nathan kernel: hub 1-0:1.0: USB hub found
Dec 28 12:06:53 Nathan kernel: hub 1-0:1.0: 2 ports detected
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:10.1
Dec 28 12:06:53 Nathan kernel: PCI: VIA IRQ fixup for 0000:00:10.1, from 3 to 1
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.1: UHCI Host Controller
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.1: irq 177, io base 0x0000dc00
Dec 28 12:06:53 Nathan kernel: usb usb2: configuration #1 chosen from 1 choice
Dec 28 12:06:53 Nathan kernel: hub 2-0:1.0: USB hub found
Dec 28 12:06:53 Nathan kernel: hub 2-0:1.0: 2 ports detected
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:10.2[C] -> GSI 21 (level, low) -> IRQ 177
Dec 28 12:06:53 Nathan kernel: PCI: VIA IRQ fixup for 0000:00:10.2, from 10 to 1
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.2: UHCI Host Controller
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
Dec 28 12:06:53 Nathan kernel: uhci_hcd 0000:00:10.2: irq 177, io base 0x0000e000
Dec 28 12:06:53 Nathan kernel: usb usb3: configuration #1 chosen from 1 choice
Dec 28 12:06:53 Nathan kernel: hub 3-0:1.0: USB hub found
Dec 28 12:06:53 Nathan kernel: hub 3-0:1.0: 2 ports detected
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:0d.0[A] -> GSI 17 (level, low) -> IRQ 185
Dec 28 12:06:53 Nathan kernel: e100: eth0: e100_probe: addr 0xdf9ff000, irq 185, MAC addr 00:A0:C9:9F:25:83
Dec 28 12:06:53 Nathan kernel: VP_IDE: IDE controller at PCI slot 0000:00:11.1
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:11.1[A]: no GSI
Dec 28 12:06:53 Nathan kernel: PCI: VIA IRQ fixup for 0000:00:11.1, from 255 to 15
Dec 28 12:06:53 Nathan kernel: VP_IDE: chipset revision 6
Dec 28 12:06:53 Nathan kernel: VP_IDE: not 100%% native mode: will probe irqs later
Dec 28 12:06:53 Nathan kernel: VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci0000:00:11.1
Dec 28 12:06:53 Nathan kernel: ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hdaMA, hdbMA
Dec 28 12:06:53 Nathan kernel: ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdcMA, hddMA
Dec 28 12:06:53 Nathan kernel: Probing IDE interface ide0...
Dec 28 12:06:53 Nathan kernel: usb 1-2: new full speed USB device using uhci_hcd and address 2
Dec 28 12:06:53 Nathan kernel: usb 1-2: configuration #1 chosen from 1 choice
Dec 28 12:06:53 Nathan kernel: hda: SAMSUNG SP1213N, ATA DISK drive
Dec 28 12:06:53 Nathan kernel: hdb: SAMSUNG SP1604N, ATA DISK drive
Dec 28 12:06:53 Nathan kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Dec 28 12:06:53 Nathan kernel: Probing IDE interface ide1...
Dec 28 12:06:53 Nathan kernel: hdc: TOSHIBA DVD-ROM SD-M1912, ATAPI CD/DVD-ROM drive
Dec 28 12:06:53 Nathan kernel: hdd: HL-DT-ST DVDRAM GSA-4163B, ATAPI CD/DVD-ROM drive
Dec 28 12:06:53 Nathan kernel: ide1 at 0x170-0x177,0x376 on irq 15
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:10.3[D] -> GSI 21 (level, low) -> IRQ 177
Dec 28 12:06:53 Nathan kernel: ehci_hcd 0000:00:10.3: EHCI Host Controller
Dec 28 12:06:53 Nathan kernel: ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
Dec 28 12:06:53 Nathan kernel: ehci_hcd 0000:00:10.3: irq 177, io mem 0xdfffef00
Dec 28 12:06:53 Nathan kernel: ehci_hcd 0000:00:10.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Dec 28 12:06:53 Nathan kernel: usb usb4: configuration #1 chosen from 1 choice
Dec 28 12:06:53 Nathan kernel: hub 4-0:1.0: USB hub found
Dec 28 12:06:53 Nathan kernel: hub 4-0:1.0: 6 ports detected
Dec 28 12:06:53 Nathan kernel: usb 1-2: can't set config #1, error -84
Dec 28 12:06:53 Nathan kernel: hda: max request size: 512KiB
Dec 28 12:06:53 Nathan kernel: hda: 234493056 sectors (120060 MB) w/8192KiB Cache, CHS=16383/255/63, UDMA(100)
Dec 28 12:06:53 Nathan kernel: hda: cache flushes supported
Dec 28 12:06:53 Nathan kernel: hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 hda10 hda11 hda12 hda13 hda14 >
Dec 28 12:06:53 Nathan kernel: hdb: max request size: 512KiB
Dec 28 12:06:53 Nathan kernel: hdb: 312581808 sectors (160041 MB) w/2048KiB Cache, CHS=19457/255/63, UDMA(100)
Dec 28 12:06:53 Nathan kernel: hdb: cache flushes supported
Dec 28 12:06:53 Nathan kernel: hdb: hdb1 hdb2 < hdb5 hdb6 hdb7 hdb8<6>usb 1-2: USB disconnect, address 2
Dec 28 12:06:53 Nathan kernel: hdb9 hdb10 hdb11 hdb12 hdb13 hdb14 >
Dec 28 12:06:53 Nathan kernel: hdc: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Dec 28 12:06:53 Nathan kernel: Uniform CD-ROM driver Revision: 3.20
Dec 28 12:06:53 Nathan kernel: hdd: ATAPI 40X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Dec 28 12:06:53 Nathan kernel: usb 1-2: new full speed USB device using uhci_hcd and address 3
Dec 28 12:06:53 Nathan kernel: device-mapper: 4.5.0-ioctl (2005-10-04) initialised: **********
Dec 28 12:06:53 Nathan kernel: kjournald starting. Commit interval 5 seconds
Dec 28 12:06:53 Nathan kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec 28 12:06:53 Nathan kernel: sr0: scsi-1 drive
Dec 28 12:06:53 Nathan kernel: sr 0:0:3:0: Attached scsi CD-ROM sr0
Dec 28 12:06:53 Nathan kernel: sr 0:0:3:0: Attached scsi generic sg0 type 5
Dec 28 12:06:53 Nathan kernel: Linux agpgart interface v0.101 (c) Dave Jones
Dec 28 12:06:53 Nathan kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Dec 28 12:06:53 Nathan kernel: agpgart: Detected VIA KT266/KY266x/KT333 chipset
Dec 28 12:06:53 Nathan kernel: agpgart: AGP aperture is 64M @ 0xe0000000
Dec 28 12:06:53 Nathan kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 28 12:06:53 Nathan kernel: parport: PnPBIOS parport detected.
Dec 28 12:06:53 Nathan kernel: parport0: PC-style at 0x378 (0x77, irq 7, dma 0 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
Dec 28 12:06:53 Nathan kernel: usb 1-2: can't set config #1, error -110
Dec 28 12:06:53 Nathan kernel: irda_init()
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 23
Dec 28 12:06:53 Nathan kernel: Real Time Clock Driver v1.12ac
Dec 28 12:06:53 Nathan kernel: Floppy drive(s): fd0 is 1.44M
Dec 28 12:06:53 Nathan kernel: FDC 0 is a post-1991 82077
Dec 28 12:06:53 Nathan kernel: ACPI: PCI Interrupt 0000:00:0b.0[A] -> GSI 19 (level, low) -> IRQ 193
Dec 28 12:06:53 Nathan kernel: es1968: not attempting power management.
Dec 28 12:06:53 Nathan kernel: input: ImPS/2 Generic Wheel Mouse as /class/input/input1
Dec 28 12:06:53 Nathan kernel: input: PC Speaker as /class/input/input2
Dec 28 12:06:53 Nathan kernel: es1968: clocking to 48000
Dec 28 12:06:53 Nathan kernel: ts: Compaq touchscreen protocol output
Dec 28 12:06:53 Nathan kernel: Linux video capture interface: v1.00
Dec 28 12:06:53 Nathan kernel: mice: PS/2 mouse device common for all mice
Dec 28 12:06:53 Nathan kernel: Adding 1052216k swap on /dev/hda8. Priority:-1 extents:1 across:1052216k
Dec 28 12:06:53 Nathan kernel: Adding 1574328k swap on /dev/hdb9. Priority:-2 extents:1 across:1574328k
Dec 28 12:06:53 Nathan kernel: EXT3 FS on hdb6, internal journal
Dec 28 12:06:53 Nathan kernel: JFS: nTxBlock = 4036, nTxLock = 32293
Dec 28 12:06:53 Nathan kernel: EXT3 FS on hdb8, internal journal
Dec 28 12:06:53 Nathan kernel: ReiserFS: hdb13: found reiserfs format "3.6" with standard journal
Dec 28 12:06:53 Nathan kernel: ReiserFS: hdb13: using ordered data mode
Dec 28 12:06:53 Nathan kernel: ReiserFS: hdb13: journal params: device hdb13, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Dec 28 12:06:53 Nathan kernel: ReiserFS: hdb13: checking transaction log (hdb13)
Dec 28 12:06:53 Nathan kernel: ReiserFS: hdb13: Using r5 hash to sort names
Dec 28 12:06:53 Nathan kernel: SGI XFS with ACLs, security attributes, realtime, large block numbers, no debug enabled
Dec 28 12:06:53 Nathan kernel: SGI XFS Quota Management subsystem
Dec 28 12:06:53 Nathan kernel: XFS mounting filesystem dm-0
Dec 28 12:06:53 Nathan kernel: Ending clean XFS mount for filesystem: dm-0
Dec 28 12:06:53 Nathan kernel: EXT3 FS on hda11, internal journal
Dec 28 12:06:53 Nathan kernel: e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
Dec 28 12:06:53 Nathan kernel: CSLIP: code copyright 1989 Regents of the University of California
Dec 28 12:06:53 Nathan kernel: PPP generic driver version 2.4.2
Dec 28 12:06:53 Nathan kernel: NET: Registered protocol family 10
Dec 28 12:06:53 Nathan kernel: lo: Disabled Privacy Extensions
Dec 28 12:06:53 Nathan kernel: IPv6 over IPv4 tunneling driver
Dec 28 12:06:55 Nathan pppd[3903]: PPP session is 677
Dec 28 12:06:55 Nathan kernel: NET: Registered protocol family 24
Dec 28 12:06:55 Nathan pppd[3903]: Using interface ppp0
Dec 28 12:06:55 Nathan pppd[3903]: Connect: ppp0 <--> eth0
Dec 28 12:06:56 Nathan pppd[3903]: PAP authentication succeeded
Dec 28 12:06:56 Nathan pppd[3903]: peer from calling number 00:90:1A:41:7B:AE authorized
Dec 28 12:06:56 Nathan pppd[3903]: Cannot determine ethernet address for proxy ARP
Dec 28 12:06:56 Nathan pppd[3903]: local IP address 80.137.63.154
