USB-Stick will nicht
P
Pond247
Doppel-As
Ich wollte mir nach diesem Howto den Support für USB-Sticks einrichten. Die entsprechenden Kerneloptionen sind aktiviert.
Leider sagt dmesg "nur"
de: 0, Value: 0
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 8
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: 1
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 0, Code: 0, Value: 0
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 4
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 1
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 2
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 3
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 5
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 7
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 6
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -1
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -2
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -5
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -5
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -9
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -8
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -11
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -13
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -14
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -14
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -15
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -17
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -16
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -15
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -8
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -6
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -4
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -2
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: -3
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 10
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: 2
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: 9
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: 3
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 1, Value: 4
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -3
evbug.c: Event. Dev: isa0060/serio1/input0, Type: 2, Code: 0, Value: -4
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 32
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 32, Value: 1
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 0, Code: 0, Value: 0
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 32, Value: 0
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 50
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 50, Value: 1
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 50, Value: 0
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 201
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 104, Value: 1
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 104, Value: 0
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 4, Code: 4, Value: 28
evbug.c: Event. Dev: isa0060/serio0/input0, Type: 1, Code: 28, Value: 1
und nichts über USB.
lsusb schreibt
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Beim Mounten wird ausgegeben, dass sda1 (probiert bis sde und auch ohne Zahlen) kein Block-Device ist.
Der selbe Fehler tritt auch mit meiner Digitalkamera auf.
Ich nutze den Gentoo-Kernel in der Version 2.6.15-r1 die Funktionen aus dem Howto sind fest einkompiliert und nicht modular.
Weiß jemand wie ich noch herausfinden kann woran es liegt bzw. wie ich den Stick zum Laufen kriege?
Hast'e denn den richtigen Treiber geladen?
Mfg, Lord Kefir
Meinst du damit jetzt UHCI (was bei lspci ausgegeben wird)? Wenn ja ist er geladen, ich hatte testweise auch schon die anderen mit reinkompiliert.
Falls nicht, könntest du Antwort bitte präzisieren?
Einfach mal ACPI ausschalten ('acpi=off noapic' als Boot-Optionen dem Kernel uebergeben). *empfehl* Ist haeufig die Ursache fuer solcherlei Probleme mit USB.
Tip: 'fdisk -l' zeigt dir an, wenn dein USB-Stick erkannt wurde. Damit bekommst du naemlich alle Partitionen (inkl. der von SCSI/USB-Laufwerken) angezeigt.
Der Treiber, den du brauchst, nennt sich uebrigens usb-storage.
Hat leider nichts gebracht (außer das wegen nvidia X nicht gestartet wurde) :(
USB_STORAGE war aktiviertt
wenn es so ein USB-MP3 Player Stick ist, hilft vielleicht einmal unter Windows formatieren? Das musste ich erst machen, seitdem funktioniert es ohne Probleme...
Andrea
Beobachte mal per "tail -f /var/log/syslog" ob es beim Anstecken des USB-Sticks irgendwelche Ausgaben gibt ...
Ich hab auch ne Problem mit dem Erkennen von USB - Sticks gehabt.
Meine Beiten sind in FAT32 formatiert.
meine /etc/fstap sieht wier folgt aus:
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
/dev/hda2       /               ext3    defaults,errors=remount-ro 0       1
/dev/hda5       none            swap    sw              0       0
/dev/hdc        /media/cdrom0   iso9660 ro,user,noauto  0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto  0       0
none		/proc/bus/usb	usbdevfs defaults	0	0
/dev/sda	/mnt/usbhd	auto    defaults        1       2
/dev/sda1  /mnt/usb_stick  vfat  suid,dev,exec  0  0
/dev/sdb1 /mnt/usb_stick   vfat  suid,dev,exec 0 0
Die letzten beiden Einträge ermöglichen, dass ich durch die Befehle "mount /dev/sda1" und "mount /dev/sdb1" die USB - Sticks unter linux nutzen kann.
Vieleicht versuchst du diese Einträge zu übernehmen.
Sorry für die lange Abwesenheit. Das Problem ist, dass der Stick beim Anstecken nicht erkannt wird (mit tail überprüft). Jetzt habe ich mir einen Mp3-Stick geliehen und es mit ihm probiert. Dieser leuchtet nicht auf, obwohl er es unter Windows tut.
Ich hänge mal die kernel-config an, vielleicht fehlt ja was...
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.16-gentoo-r13
# Sun Jul 23 11:14:28 2006
CONFIG_X86_32=y
CONFIG_SEMAPHORE_SLEEPERS=y
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_DMI=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
# CONFIG_BSD_PROCESS_ACCT is not set
CONFIG_SYSCTL=y
CONFIG_AUDIT=y
CONFIG_AUDITSYSCALL=y
# CONFIG_IKCONFIG is not set
CONFIG_INITRAMFS_SOURCE=""
CONFIG_UID16=y
CONFIG_VM86=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
# CONFIG_EMBEDDED is not set
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SHMEM=y
CONFIG_CC_ALIGN_FUNCTIONS=0
CONFIG_CC_ALIGN_LABELS=0
CONFIG_CC_ALIGN_LOOPS=0
CONFIG_CC_ALIGN_JUMPS=0
CONFIG_SLAB=y
# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
# CONFIG_SLOB is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_OBSOLETE_MODPARM=y
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_KMOD=y
# Block layer
# CONFIG_LBD is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
CONFIG_DEFAULT_AS=y
# CONFIG_DEFAULT_DEADLINE is not set
# CONFIG_DEFAULT_CFQ is not set
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="anticipatory"
# Processor type and features
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
# CONFIG_M686 is not set
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUMM is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
CONFIG_MK7=y
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MEFFICEON is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MGEODEGX1 is not set
# CONFIG_MGEODE_LX is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
# CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_CMPXCHG64=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_USE_3DNOW=y
CONFIG_X86_TSC=y
CONFIG_HPET_TIMER=y
# CONFIG_SMP is not set
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_PREEMPT_BKL=y
# CONFIG_X86_UP_APIC is not set
CONFIG_X86_MCE=y
CONFIG_X86_MCE_NONFATAL=y
# CONFIG_TOSHIBA is not set
# CONFIG_I8K is not set
# CONFIG_X86_REBOOTFIXUPS is not set
# CONFIG_MICROCODE is not set
# CONFIG_X86_MSR is not set
# CONFIG_X86_CPUID is not set
# Firmware Drivers
# CONFIG_EDD is not set
# CONFIG_DELL_RBU is not set
# CONFIG_DCDBAS is not set
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM4G is not set
# CONFIG_HIGHMEM64G is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_SPARSEMEM_STATIC=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
# CONFIG_EFI is not set
# CONFIG_REGPARM is not set
CONFIG_SECCOMP=y
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
# CONFIG_KEXEC is not set
CONFIG_PHYSICAL_START=0x100000
CONFIG_DOUBLEFAULT=y
# Power management options (ACPI, APM)
CONFIG_PM=y
CONFIG_PM_LEGACY=y
CONFIG_PM_DEBUG=y
# CONFIG_SOFTWARE_SUSPEND is not set
# ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI=y
# CONFIG_ACPI_SLEEP is not set
# CONFIG_ACPI_AC is not set
# CONFIG_ACPI_BATTERY is not set
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_VIDEO=y
# CONFIG_ACPI_HOTKEY is not set
CONFIG_ACPI_FAN=y
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_THERMAL=y
# CONFIG_ACPI_ASUS is not set
# CONFIG_ACPI_IBM is not set
# CONFIG_ACPI_TOSHIBA is not set
CONFIG_ACPI_BLACKLIST_YEAR=0
# CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_SYSTEM=y
CONFIG_X86_PM_TIMER=y
# CONFIG_ACPI_CONTAINER is not set
# APM (Advanced Power Management) BIOS Support
# CONFIG_APM is not set
# CPU Frequency scaling
# CONFIG_CPU_FREQ is not set
# Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GOMMCONFIG is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
# CONFIG_PCIEPORTBUS is not set
# CONFIG_PCI_LEGACY_PROC is not set
CONFIG_ISA_DMA_API=y
CONFIG_ISA=y
# CONFIG_EISA is not set
# CONFIG_MCA is not set
# CONFIG_SCx200 is not set
# PCCARD (PCMCIA/CardBus) support
# CONFIG_PCCARD is not set
# PCI Hotplug Support
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_MISC=y
# Networking
CONFIG_NET=y
# Networking options
# CONFIG_NETDEBUG is not set
CONFIG_PACKET=y
# CONFIG_PACKET_MMAP is not set
CONFIG_UNIX=y
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
# CONFIG_IP_PNP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_TUNNEL is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_BIC=y
# IP: Virtual Server Configuration
# CONFIG_IP_VS is not set
# CONFIG_IPV6 is not set
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
# Core Netfilter Configuration
# CONFIG_NETFILTER_NETLINK is not set
# CONFIG_NETFILTER_XTABLES is not set
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=y
# CONFIG_IP_NF_CT_ACCT is not set
# CONFIG_IP_NF_CONNTRACK_MARK is not set
# CONFIG_IP_NF_CONNTRACK_EVENTS is not set
# CONFIG_IP_NF_CT_PROTO_SCTP is not set
# CONFIG_IP_NF_FTP is not set
# CONFIG_IP_NF_IRC is not set
# CONFIG_IP_NF_NETBIOS_NS is not set
# CONFIG_IP_NF_TFTP is not set
# CONFIG_IP_NF_AMANDA is not set
# CONFIG_IP_NF_PPTP is not set
CONFIG_IP_NF_QUEUE=y
# DCCP Configuration (EXPERIMENTAL)
# CONFIG_IP_DCCP is not set
# SCTP Configuration (EXPERIMENTAL)
# CONFIG_IP_SCTP is not set
# TIPC Configuration (EXPERIMENTAL)
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_NET_DIVERT is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# QoS and/or fair queueing
# CONFIG_NET_SCHED is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_IEEE80211 is not set
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
# Connector - unified userspace <-> kernelspace linker
# CONFIG_CONNECTOR is not set
# Memory Technology Devices (MTD)
# CONFIG_MTD is not set
# Parallel port support
CONFIG_PARPORT=y
CONFIG_PARPORT_PC=y
# CONFIG_PARPORT_SERIAL is not set
# CONFIG_PARPORT_PC_FIFO is not set
# CONFIG_PARPORT_PC_SUPERIO is not set
# CONFIG_PARPORT_GSC is not set
# CONFIG_PARPORT_1284 is not set
# Plug and Play support
CONFIG_PNP=y
# CONFIG_PNP_DEBUG is not set
# Protocols
# CONFIG_ISAPNP is not set
# CONFIG_PNPBIOS is not set
CONFIG_PNPACPI=y
# Block devices
CONFIG_BLK_DEV_FD=y
# CONFIG_BLK_DEV_XD is not set
# CONFIG_PARIDE is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_SX8 is not set
# CONFIG_BLK_DEV_UB is not set
# CONFIG_BLK_DEV_RAM is not set
CONFIG_BLK_DEV_RAM_COUNT=16
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# ATA/ATAPI/MFM/RLL support
CONFIG_IDE=y
CONFIG_BLK_DEV_IDE=y
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_IDE_SATA is not set
# CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
CONFIG_BLK_DEV_IDECD=y
# CONFIG_BLK_DEV_IDETAPE is not set
CONFIG_BLK_DEV_IDEFLOPPY=y
# CONFIG_BLK_DEV_IDESCSI is not set
# CONFIG_IDE_TASK_IOCTL is not set
# IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=y
CONFIG_BLK_DEV_CMD640=y
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
# CONFIG_BLK_DEV_IDEPNP is not set
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
# CONFIG_BLK_DEV_OFFBOARD is not set
CONFIG_BLK_DEV_GENERIC=y
# CONFIG_BLK_DEV_OPTI621 is not set
# CONFIG_BLK_DEV_RZ1000 is not set
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
# CONFIG_BLK_DEV_AEC62XX is not set
# CONFIG_BLK_DEV_ALI15X3 is not set
# CONFIG_BLK_DEV_AMD74XX is not set
# CONFIG_BLK_DEV_ATIIXP is not set
# CONFIG_BLK_DEV_CMD64X is not set
# CONFIG_BLK_DEV_TRIFLEX is not set
# CONFIG_BLK_DEV_CY82C693 is not set
# CONFIG_BLK_DEV_CS5520 is not set
# CONFIG_BLK_DEV_CS5530 is not set
# CONFIG_BLK_DEV_CS5535 is not set
# CONFIG_BLK_DEV_HPT34X is not set
# CONFIG_BLK_DEV_HPT366 is not set
# CONFIG_BLK_DEV_SC1200 is not set
# CONFIG_BLK_DEV_PIIX is not set
# CONFIG_BLK_DEV_IT821X is not set
# CONFIG_BLK_DEV_NS87415 is not set
# CONFIG_BLK_DEV_PDC202XX_OLD is not set
# CONFIG_BLK_DEV_PDC202XX_NEW is not set
# CONFIG_BLK_DEV_SVWKS is not set
# CONFIG_BLK_DEV_SIIMAGE is not set
# CONFIG_BLK_DEV_SIS5513 is not set
# CONFIG_BLK_DEV_SLC90E66 is not set
# CONFIG_BLK_DEV_TRM290 is not set
CONFIG_BLK_DEV_VIA82CXXX=y
# CONFIG_IDE_ARM is not set
# CONFIG_IDE_CHIPSETS is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_IVB is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
CONFIG_BLK_DEV_SR=y
# CONFIG_BLK_DEV_SR_VENDOR is not set
CONFIG_CHR_DEV_SG=y
# CONFIG_CHR_DEV_SCH is not set
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
# CONFIG_SCSI_MULTI_LUN is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# SCSI Transport Attributes
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# SCSI low-level drivers
# CONFIG_ISCSI_TCP is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_7000FASST is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AHA152X is not set
# CONFIG_SCSI_AHA1542 is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC7XXX_OLD is not set
# CONFIG_SCSI_AIC79XX is not set
CONFIG_SCSI_DPT_I2O=m
# CONFIG_SCSI_IN2000 is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_MEGARAID_SAS is not set
CONFIG_SCSI_SATA=y
# CONFIG_SCSI_SATA_AHCI is not set
# CONFIG_SCSI_SATA_SVW is not set
CONFIG_SCSI_ATA_PIIX=y
# CONFIG_SCSI_SATA_MV is not set
# CONFIG_SCSI_SATA_NV is not set
# CONFIG_SCSI_PDC_ADMA is not set
# CONFIG_SCSI_SATA_QSTOR is not set
# CONFIG_SCSI_SATA_PROMISE is not set
CONFIG_SCSI_SATA_SX4=m
# CONFIG_SCSI_SATA_SIL is not set
# CONFIG_SCSI_SATA_SIL24 is not set
CONFIG_SCSI_SATA_SIS=m
# CONFIG_SCSI_SATA_ULI is not set
# CONFIG_SCSI_SATA_VIA is not set
# CONFIG_SCSI_SATA_VITESSE is not set
CONFIG_SCSI_SATA_INTEL_COMBINED=y
# CONFIG_SCSI_BUSLOGIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_DTC3280 is not set
# CONFIG_SCSI_EATA is not set
# CONFIG_SCSI_FUTURE_DOMAIN is not set
# CONFIG_SCSI_GDTH is not set
# CONFIG_SCSI_GENERIC_NCR5380 is not set
# CONFIG_SCSI_GENERIC_NCR5380_MMIO is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_PPA is not set
# CONFIG_SCSI_IMM is not set
# CONFIG_SCSI_NCR53C406A is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
CONFIG_SCSI_IPR=m
# CONFIG_SCSI_IPR_TRACE is not set
# CONFIG_SCSI_IPR_DUMP is not set
# CONFIG_SCSI_PAS16 is not set
# CONFIG_SCSI_PSI240I is not set
# CONFIG_SCSI_QLOGIC_FAS is not set
# CONFIG_SCSI_QLOGIC_FC is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_FC is not set
# CONFIG_SCSI_LPFC is not set
# CONFIG_SCSI_SYM53C416 is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_DC390T is not set
# CONFIG_SCSI_T128 is not set
# CONFIG_SCSI_U14_34F is not set
# CONFIG_SCSI_ULTRASTOR is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_DEBUG is not set
# Old CD-ROM drivers (not SCSI, not IDE)
# CONFIG_CD_NO_IDESCSI is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# Fusion MPT device support
# CONFIG_FUSION is not set
# CONFIG_FUSION_SPI is not set
# CONFIG_FUSION_FC is not set
# CONFIG_FUSION_SAS is not set
# IEEE 1394 (FireWire) support
# CONFIG_IEEE1394 is not set
# I2O device support
# CONFIG_I2O is not set
# Network device support
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_NET_SB1000 is not set
# ARCnet devices
# CONFIG_ARCNET is not set
# PHY device support
# CONFIG_PHYLIB is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_NET_VENDOR_RACAL is not set
# Tulip family network device support
# CONFIG_NET_TULIP is not set
# CONFIG_AT1700 is not set
# CONFIG_DEPCA is not set
# CONFIG_HP100 is not set
# CONFIG_NET_ISA is not set
CONFIG_NET_PCI=y
# CONFIG_PCNET32 is not set
# CONFIG_AMD8111_ETH is not set
# CONFIG_ADAPTEC_STARFIRE is not set
# CONFIG_AC3200 is not set
# CONFIG_APRICOT is not set
# CONFIG_B44 is not set
# CONFIG_FORCEDETH is not set
# CONFIG_CS89x0 is not set
# CONFIG_DGRS is not set
# CONFIG_EEPRO100 is not set
# CONFIG_E100 is not set
# CONFIG_FEALNX is not set
# CONFIG_NATSEMI is not set
CONFIG_NE2K_PCI=y
CONFIG_8139CP=y
CONFIG_8139TOO=y
# CONFIG_8139TOO_PIO is not set
# CONFIG_8139TOO_TUNE_TWISTER is not set
# CONFIG_8139TOO_8129 is not set
# CONFIG_8139_OLD_RX_RESET is not set
# CONFIG_SIS900 is not set
# CONFIG_EPIC100 is not set
# CONFIG_SUNDANCE is not set
# CONFIG_TLAN is not set
# CONFIG_VIA_RHINE is not set
# CONFIG_NET_POCKET is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_E1000 is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_R8169 is not set
# CONFIG_SIS190 is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
# CONFIG_SK98LIN is not set
# CONFIG_VIA_VELOCITY is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2 is not set
# Ethernet (10000 Mbit)
# CONFIG_CHELSIO_T1 is not set
# CONFIG_IXGB is not set
# CONFIG_S2IO is not set
# Token Ring devices
# CONFIG_TR is not set
# Wireless LAN (non-hamradio)
# CONFIG_NET_RADIO is not set
# Wan interfaces
# CONFIG_WAN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
# CONFIG_PLIP is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_NET_FC is not set
# CONFIG_SHAPER is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# ISDN subsystem
# CONFIG_ISDN is not set
# Telephony Support
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1280
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=1024
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_TSDEV is not set
# CONFIG_INPUT_EVDEV is not set
CONFIG_INPUT_EVBUG=y
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_INPORT is not set
# CONFIG_MOUSE_LOGIBM is not set
# CONFIG_MOUSE_PC110PAD is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_CT82C710 is not set
# CONFIG_SERIO_PARKBD is not set
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
CONFIG_GAMEPORT=y
# CONFIG_GAMEPORT_NS558 is not set
# CONFIG_GAMEPORT_L4 is not set
# CONFIG_GAMEPORT_EMU10K1 is not set
CONFIG_GAMEPORT_FM801=y
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
CONFIG_SERIAL_8250=y
# CONFIG_SERIAL_8250_CONSOLE is not set
# CONFIG_SERIAL_8250_ACPI is not set
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
# CONFIG_SERIAL_8250_EXTENDED is not set
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
# CONFIG_SERIAL_JSM is not set
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_PRINTER=y
# CONFIG_LP_CONSOLE is not set
# CONFIG_PPDEV is not set
# CONFIG_TIPAR is not set
# IPMI
# CONFIG_IPMI_HANDLER is not set
# Watchdog Cards
# CONFIG_WATCHDOG is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
# CONFIG_GEN_RTC is not set
# CONFIG_DTLK is not set
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_SONYPI is not set
# Ftape, the floppy tape device driver
# CONFIG_FTAPE is not set
# CONFIG_AGP is not set
# CONFIG_DRM is not set
# CONFIG_MWAVE is not set
# CONFIG_CS5535_GPIO is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_HPET is not set
# CONFIG_HANGCHECK_TIMER is not set
# TPM devices
# CONFIG_TCG_TPM is not set
# CONFIG_TELCLOCK is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_CHARDEV=y
# I2C Algorithms
CONFIG_I2C_ALGOBIT=y
CONFIG_I2C_ALGOPCF=y
CONFIG_I2C_ALGOPCA=y
# I2C Hardware Bus support
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_ELEKTOR is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_I810 is not set
# CONFIG_I2C_PIIX4 is not set
CONFIG_I2C_ISA=y
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_PARPORT is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_PROSAVAGE is not set
# CONFIG_I2C_SAVAGE4 is not set
# CONFIG_SCx200_ACB is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_VIA is not set
CONFIG_I2C_VIAPRO=y
# CONFIG_I2C_VOODOO3 is not set
# CONFIG_I2C_PCA_ISA is not set
# Miscellaneous I2C Chip support
# CONFIG_SENSORS_DS1337 is not set
# CONFIG_SENSORS_DS1374 is not set
CONFIG_SENSORS_EEPROM=y
# CONFIG_SENSORS_PCF8574 is not set
# CONFIG_SENSORS_PCA9539 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_SENSORS_RTC8564 is not set
# CONFIG_SENSORS_MAX6875 is not set
# CONFIG_RTC_X1205_I2C is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# SPI support
# CONFIG_SPI is not set
# CONFIG_SPI_MASTER is not set
# Dallas's 1-wire bus
# CONFIG_W1 is not set
# Hardware Monitoring support
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ASB100 is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_FSCHER is not set
# CONFIG_SENSORS_FSCPOS is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_SIS5595 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
CONFIG_SENSORS_VIA686A=y
# CONFIG_SENSORS_VT8231 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
# CONFIG_SENSORS_HDAPS is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Misc devices
# CONFIG_IBM_ASM is not set
# Multimedia Capabilities Port drivers
# Multimedia devices
CONFIG_VIDEO_DEV=y
# Video For Linux
# Video Adapters
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_BT848 is not set
# CONFIG_VIDEO_PMS is not set
# CONFIG_VIDEO_BWQCAM is not set
# CONFIG_VIDEO_CQCAM is not set
# CONFIG_VIDEO_CPIA is not set
# CONFIG_VIDEO_SAA5246A is not set
# CONFIG_VIDEO_SAA5249 is not set
# CONFIG_TUNER_3036 is not set
# CONFIG_VIDEO_STRADIS is not set
# CONFIG_VIDEO_ZORAN is not set
# CONFIG_VIDEO_SAA7134 is not set
# CONFIG_VIDEO_MXB is not set
# CONFIG_VIDEO_DPC is not set
# CONFIG_VIDEO_HEXIUM_ORION is not set
# CONFIG_VIDEO_HEXIUM_GEMINI is not set
# CONFIG_VIDEO_CX88 is not set
# CONFIG_VIDEO_EM28XX is not set
# CONFIG_VIDEO_OVCAMCHIP is not set
# CONFIG_VIDEO_AUDIO_DECODER is not set
# CONFIG_VIDEO_DECODER is not set
# Radio Adapters
# CONFIG_RADIO_CADET is not set
# CONFIG_RADIO_RTRACK is not set
# CONFIG_RADIO_RTRACK2 is not set
# CONFIG_RADIO_AZTECH is not set
# CONFIG_RADIO_GEMTEK is not set
# CONFIG_RADIO_GEMTEK_PCI is not set
# CONFIG_RADIO_MAXIRADIO is not set
# CONFIG_RADIO_MAESTRO is not set
# CONFIG_RADIO_SF16FMI is not set
# CONFIG_RADIO_SF16FMR2 is not set
# CONFIG_RADIO_TERRATEC is not set
# CONFIG_RADIO_TRUST is not set
# CONFIG_RADIO_TYPHOON is not set
# CONFIG_RADIO_ZOLTRIX is not set
# Digital Video Broadcasting Devices
# CONFIG_DVB is not set
# Graphics support
CONFIG_FB=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_MACMODES is not set
CONFIG_FB_MODE_HELPERS=y
# CONFIG_FB_TILEBLITTING is not set
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ARC is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_VGA16 is not set
CONFIG_FB_VESA=y
# CONFIG_FB_VESA_STD is not set
CONFIG_FB_VESA_TNG=y
CONFIG_FB_VESA_DEFAULT_MODE="1280X1024@75"
# CONFIG_VIDEO_SELECT is not set
# CONFIG_FB_HGA is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_NVIDIA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I810 is not set
# CONFIG_FB_INTEL is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON_OLD is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_CYBLA is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_GEODE is not set
# CONFIG_FB_VIRTUAL is not set
# Console display driver support
CONFIG_VGA_CONSOLE=y
# CONFIG_MDA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# Logo configuration
# CONFIG_LOGO is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
CONFIG_FB_SPLASH=y
# Speakup console speech
# CONFIG_SPEAKUP is not set
CONFIG_SPEAKUP_DEFAULT="none"
# Sound
CONFIG_SOUND=y
# Advanced Linux Sound Architecture
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_HWDEP=y
CONFIG_SND_RAWMIDI=y
CONFIG_SND_SEQUENCER=y
# CONFIG_SND_SEQ_DUMMY is not set
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=y
CONFIG_SND_PCM_OSS=y
CONFIG_SND_SEQUENCER_OSS=y
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# Generic devices
CONFIG_SND_MPU401_UART=y
CONFIG_SND_OPL3_LIB=y
CONFIG_SND_AC97_CODEC=y
CONFIG_SND_AC97_BUS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_VIRMIDI is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# ISA devices
# CONFIG_SND_AD1816A is not set
# CONFIG_SND_AD1848 is not set
# CONFIG_SND_ALS100 is not set
# CONFIG_SND_AZT2320 is not set
# CONFIG_SND_CMI8330 is not set
# CONFIG_SND_CS4231 is not set
# CONFIG_SND_CS4232 is not set
# CONFIG_SND_CS4236 is not set
# CONFIG_SND_DT019X is not set
# CONFIG_SND_ES968 is not set
# CONFIG_SND_ES1688 is not set
# CONFIG_SND_ES18XX is not set
# CONFIG_SND_GUSCLASSIC is not set
# CONFIG_SND_GUSEXTREME is not set
# CONFIG_SND_GUSMAX is not set
# CONFIG_SND_INTERWAVE is not set
# CONFIG_SND_INTERWAVE_STB is not set
# CONFIG_SND_OPL3SA2 is not set
# CONFIG_SND_OPTI92X_AD1848 is not set
# CONFIG_SND_OPTI92X_CS4231 is not set
# CONFIG_SND_OPTI93X is not set
# CONFIG_SND_SB8 is not set
# CONFIG_SND_SB16 is not set
# CONFIG_SND_SBAWE is not set
# CONFIG_SND_SGALAXY is not set
# CONFIG_SND_SSCAPE is not set
# CONFIG_SND_WAVEFRONT is not set
# PCI devices
# CONFIG_SND_AD1889 is not set
# CONFIG_SND_ALS4000 is not set
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CS5535AUDIO is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
CONFIG_SND_FM801=y
CONFIG_SND_FM801_TEA575X=y
# CONFIG_SND_HDA_INTEL is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_HDSPM is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
# CONFIG_SND_INTEL8X0 is not set
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_PCXHR is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VX222 is not set
# CONFIG_SND_YMFPCI is not set
# USB devices
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_USX2Y is not set
# Open Sound System
# CONFIG_SOUND_PRIME is not set
# USB support
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
# CONFIG_USB_BANDWIDTH is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_SUSPEND is not set
# CONFIG_USB_OTG is not set
# USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_SPLIT_ISO is not set
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
# CONFIG_USB_ISP116X_HCD is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_BIG_ENDIAN is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_UHCI_HCD=y
# CONFIG_USB_SL811_HCD is not set
# USB Device Class drivers
# CONFIG_OBSOLETE_OSS_USB_DRIVER is not set
# CONFIG_USB_ACM is not set
CONFIG_USB_PRINTER=y
# NOTE: USB_STORAGE enables SCSI, and 'SCSI disk support'
# may also be needed; see USB_STORAGE Help for more information
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_LIBUSUAL is not set
# USB Input Devices
CONFIG_USB_HID=y
CONFIG_USB_HIDINPUT=y
# CONFIG_USB_HIDINPUT_POWERBOOK is not set
# CONFIG_HID_FF is not set
# CONFIG_USB_HIDDEV is not set
# CONFIG_USB_AIPTEK is not set
# CONFIG_USB_WACOM is not set
# CONFIG_USB_ACECAD is not set
# CONFIG_USB_KBTAB is not set
# CONFIG_USB_POWERMATE is not set
# CONFIG_USB_MTOUCH is not set
# CONFIG_USB_ITMTOUCH is not set
# CONFIG_USB_EGALAX is not set
# CONFIG_USB_YEALINK is not set
# CONFIG_USB_XPAD is not set
# CONFIG_USB_ATI_REMOTE is not set
# CONFIG_USB_ATI_REMOTE2 is not set
# CONFIG_USB_KEYSPAN_REMOTE is not set
# CONFIG_USB_APPLETOUCH is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB Multimedia devices
# CONFIG_USB_DABUSB is not set
# CONFIG_USB_VICAM is not set
# CONFIG_USB_DSBR is not set
# CONFIG_USB_ET61X251 is not set
# CONFIG_USB_IBMCAM is not set
# CONFIG_USB_KONICAWC is not set
# CONFIG_USB_OV511 is not set
# CONFIG_USB_SE401 is not set
# CONFIG_USB_SN9C102 is not set
# CONFIG_USB_STV680 is not set
# CONFIG_USB_PWC is not set
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_MON is not set
# USB port drivers
# CONFIG_USB_USS720 is not set
# USB Serial Converter support
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_AUERSWALD is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_PHIDGETKIT is not set
# CONFIG_USB_PHIDGETSERVO is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TEST is not set
# USB DSL modem support
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# MMC/SD Card support
# CONFIG_MMC is not set
# InfiniBand support
# CONFIG_INFINIBAND is not set
# EDAC - error detection and reporting (RAS) (EXPERIMENTAL)
# CONFIG_EDAC is not set
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT2_FS_XIP=y
CONFIG_FS_XIP=y
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
CONFIG_FS_POSIX_ACL=y
# CONFIG_XFS_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_ROMFS_FS is not set
CONFIG_INOTIFY=y
# CONFIG_QUOTA is not set
CONFIG_DNOTIFY=y
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=y
# CONFIG_FUSE_FS is not set
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=y
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_ZISOFS_FS=y
CONFIG_UDF_FS=y
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=y
# CONFIG_NTFS_DEBUG is not set
# CONFIG_NTFS_RW is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# CONFIG_RELAYFS_FS is not set
# CONFIG_CONFIGFS_FS is not set
# Miscellaneous filesystems
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# Network File Systems
CONFIG_NFS_FS=y
# CONFIG_NFS_V3 is not set
# CONFIG_NFS_V4 is not set
# CONFIG_NFS_DIRECTIO is not set
CONFIG_NFSD=y
# CONFIG_NFSD_V3 is not set
CONFIG_NFSD_TCP=y
CONFIG_LOCKD=y
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
CONFIG_SMB_FS=y
# CONFIG_SMB_NLS_DEFAULT is not set
CONFIG_CIFS=y
# CONFIG_CIFS_STATS is not set
# CONFIG_CIFS_XATTR is not set
# CONFIG_CIFS_EXPERIMENTAL is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# CONFIG_9P_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=y
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Instrumentation Support
CONFIG_PROFILING=y
CONFIG_OPROFILE=y
# CONFIG_KPROBES is not set
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_DEBUG_KERNEL is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_EARLY_PRINTK=y
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# Cryptographic options
# CONFIG_CRYPTO is not set
# Hardware crypto devices
# Library routines
# CONFIG_CRC_CCITT is not set
# CONFIG_CRC16 is not set
CONFIG_CRC32=y
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_X86_BIOS_REBOOT=y
CONFIG_KTIME_SCALAR=y
Du glaubst wirklich, dass jetzt jemand deine Kernel-Konfiguration durchschaut? Und uebrigens gibt es hier einen Code-Block, der nicht gleich 20 A4-Seiten einnimmt. Ich wuesste auch nicht wen du mit deiner Kernel-Config zitierst. Ausserdem waere der Output, den du in der /var/log/messages bekommst, wenn du den Stick ansteckst, wesentlich besser zur Fehleranalyse geeignet als diese Kernel-Konfiguration. Nimm einfach den Default-Kernel deiner Distro, da ist Unterstuetzung fuer USB-Speichermedien ganz sicher drin (sonst haettest du 'ne ziemlich verkorkste Distro und solltest schnellstmoeglich wechseln). Und versuch einfach mal das evbug-Modul nicht zu laden. Das wird den Fehler-Output auf das beschraenken was wichtig ist.
Also hotplug ist installiert und sollte aktiviert sein, es klappt aber schon mit Coldplug nicht.
@theton
Ich wusste nicht, dass der Codeblock sichvon QUOTE unterscheidet (ich hab es genommen, weil das Zitat im Direkt-Antwort-Dialog zur Wahl stand)
Die Konfiguration steht da, falls jemand nach Modulen fragt und /var/log/messages stand im Anfangspost (-> keine Reaktion darauf, evbug hab ich inzwischen unabhängig davon deaktiviert)
"Mein USB-Drecksgeraffel will nicht blabla" 105698 Auflage. Schmeiß mal die SuFu an. Is schon 1003mal erklärt worden hier.
Sorry das ich hier wieder reinschreib,
aber ich hab die Suchfunktion benutzt aber leider nix mehr gefunden......
mein USB Stick geht auch nicht.....
"usb-storage" is geladen und beim Einstecken bringt er mir bei "tail -f /var/log/messages/":
usb 3-1: new full speed USB device using uhci_hcd and address 9
usb 3-1: device not accepting address 9, error -110
usb 3-1: new full speed USB device using uhci_hcd and address 10
usb 3-1: device not accepting address 10, error -110
usb 3-1: new full speed USB device using uhci_hcd and address 11
usb 3-1: device not accepting address 11, error -110
usb 3-1: new full speed USB device using uhci_hcd and address 12
usb 3-1: device not accepting address 12, error -110
usb 3-1: new full speed USB device using uhci_hcd and address 13
usb 3-1: device not accepting address 13, error -110
die Dateil fstap hab ich shcon wie oben beschrieben editiert,
und beom mounten schreibt er:
mount: /dev/sda1 is not a vaild block device.
zur Info ich hab noch suse 9.3 drauf.
Danke für Hilfe!
Ueblicherweise kommen solche Fehler, wenn der USB-Stick sich nicht mit dem System "unterhaelt", also defekt ist. Schonmal an einen anderen Rechner gesteckt (z.B. mit Windows oder einem anderen System) und geschaut, ob er dort nutzbar ist?
Also unter Windows funktioniert er (auch wenn es nur das 2. mal war)
und bei nem anderen Stick bringt er:
usb 5-5: new high speed USB device using ehci_hcd and address 6
ehci_hcd 0000:001d.7: Unlink after no-IRQ? Controller is probably using the wrong IRQ
und dann die gleichen error -110 meldungen
dmesg |grep usb
und
/sbin/lsusb
helfen vllt weiter?
Oder das Teil unter MS-Windows mal neu formatieren. Manchmal wirkt das wunder.
Also ich hab endlich USB zum laufen bekommen!!!!
und zwar durch ein Bios reset!!!!!
ez geht mommentan alles einwandfrei!
Raspberry Pi als Spielkonsole: Lakka 4.3 mit RetroArch für Mini-Retro-PCs erschienen
Raspberry Pi als Spielkonsole: Lakka 4.3 mit RetroArch für Mini-Retro-PCs erschienen (Update)
E/A-Fehler (.snapshots is not a btrfs subvolume).
ip6tables Problem
