Linux version 2.6.16.13-4-bigsmp (geeko@buildhost) (gcc version 4.1.0 (SUSE Linux)) #1 SMP Wed May 3 04:53:23 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 00000000bfff0000 (usable)
BIOS-e820: 00000000bfff0000 - 00000000bfff3000 (ACPI NVS)
BIOS-e820: 00000000bfff3000 - 00000000c0000000 (ACPI data)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
2175MB HIGHMEM available.
896MB LOWMEM available.
No mptable found.
On node 0 totalpages: 786416
DMA zone: 4096 pages, LIFO batch:0
DMA32 zone: 0 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 557040 pages, LIFO batch:31
DMI 2.2 present.
Using APIC driver default
ACPI: RSDP (v000 Nvidia ) @ 0x000f75c0
ACPI: RSDT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0xbfff3000
ACPI: FADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0xbfff3040
ACPI: MADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0xbfff74c0
ACPI: DSDT (v001 NVIDIA AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 6:10 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Overriding APIC driver with bigsmp
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: BIOS IRQ0 pin2 override ignored.
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Enabling APIC mode: Physflat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at c4000000 (gap: c0000000:3ec00000)
Built 1 zonelists
Kernel command line: root=/dev/hdb2 vga=0x317 resume=/dev/hdb1 splash=silent
bootsplash: silent mode.
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 65536 bytes)
Detected 1913.359 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 3109376k/3145664k available (1636k kernel code, 35064k reserved, 881k data, 192k init, 2228160k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 3830.83 BogoMIPS (lpj=7661664)
Security Framework v1.0.0 initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Checking 'hlt' instruction... OK.
checking if image is initramfs... it is
Freeing initrd memory: 2334k freed
not found!
CPU0: AMD Athlon(tm) XP 2600+ stepping 00
Leaving ESR disabled.
Total of 1 processors activated (3830.83 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
Brought up 1 CPUs
migration_cost=0
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfb4a0, last bus=2
PCI: Using configuration type 1
ACPI: Subsystem revision 20060127
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI: nForce2 C1 Halt Disconnect fixup
Boot video device is 0000:02:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGPB._PRT]
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 6 *7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LUBA] (IRQs *3 4 5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 6 *7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LAPU] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LACI] (IRQs *3 4 5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LFIR] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [L3CM] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [APC1] (IRQs *16), disabled.
ACPI: PCI Interrupt Link [APC2] (IRQs *17), disabled.
ACPI: PCI Interrupt Link [APC3] (IRQs *18), disabled.
ACPI: PCI Interrupt Link [APC4] (IRQs *19), disabled.
ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCI] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCS] (IRQs *23), disabled.
ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [AP3C] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 16 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
TC classifier action (bugs to [email]netdev@vger.kernel.org[/email] cc [email]hadi@cyberus.ca[/email])
Setting up standard PCI resources
pnp: 00:00: ioport range 0x4000-0x407f could not be reserved
pnp: 00:00: ioport range 0x4080-0x40ff has been reserved
pnp: 00:00: ioport range 0x4400-0x447f has been reserved
pnp: 00:00: ioport range 0x4480-0x44ff could not be reserved
pnp: 00:00: ioport range 0x4200-0x427f has been reserved
pnp: 00:00: ioport range 0x4280-0x42ff has been reserved
pnp: 00:01: ioport range 0x5000-0x503f has been reserved
pnp: 00:01: ioport range 0x5500-0x553f has been reserved
PCI: Bridge: 0000:00:08.0
IO window: d000-dfff
MEM window: e2000000-e3ffffff
PREFETCH window: c4000000-c40fffff
PCI: Bridge: 0000:00:1e.0
IO window: disabled.
MEM window: e0000000-e1ffffff
PREFETCH window: d8000000-dfffffff
PCI: Setting latency timer of device 0000:00:08.0 to 64
apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1148420748.576:1): initialized
highmem bounce pool size: 64 pages
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
vesafb: framebuffer at 0xd8000000, mapped to 0xf8880000, using 6144k, total 131072k
vesafb: mode is 1024x768x16, linelength=2048, pages=1
vesafb: protected mode interface info at c000:e340
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 47089 bytes,<6>...found (1024x768, 27542 bytes, v3).
Console: switching to colour frame buffer device 124x44
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 64000K size 1024 blocksize
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard as /class/input/input0
input: ImExPS/2 Generic Explorer Mouse as /class/input/input1
input: PC Speaker as /class/input/input2
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
NET: Registered protocol family 2
IP route cache hash table entries: 131072 (order: 7, 524288 bytes)
TCP established hash table entries: 524288 (order: 10, 4194304 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 524288 bind 65536)
TCP reno registered
Using IPI No-Shortcut mode
ACPI wakeup devices:
HUB0 HUB1 USB0 USB1 USB2 F139 MMAC MMCI UAR1
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 192k freed
Write protecting the kernel read-only data: 290k
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
NFORCE2: IDE controller at PCI slot 0000:00:09.0
NFORCE2: chipset revision 162
NFORCE2: not 100% native mode: will probe irqs later
NFORCE2: BIOS didn't set cable bits correctly. Enabling workaround.
NFORCE2: 0000:00:09.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: IC35L120AVV207-0, ATA DISK drive
hdb: Maxtor 6Y120L0, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 512KiB
hda: 241254720 sectors (123522 MB) w/1821KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 >
hdb: max request size: 128KiB
hdb: 240121728 sectors (122942 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(133)
hdb: cache flushes supported
hdb: hdb1 hdb2 hdb3
Probing IDE interface ide1...
hdc: IDE DVD-ROM 16X, ATAPI CD/DVD-ROM drive
hdd: HL-DT-ST DVDRAM GSA-4163B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Attempting manual resume
ReiserFS: hdb2: found reiserfs format "3.6" with standard journal
ReiserFS: hdb2: using ordered data mode
reiserfs: using flush barriers
ReiserFS: hdb2: journal params: device hdb2, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hdb2: checking transaction log (hdb2)
ReiserFS: hdb2: Using r5 hash to sort names
Adding 1052216k swap on /dev/hdb1. Priority:-1 extents:1 across:1052216k
parport: PnPBIOS parport detected.
parport0: PC-style at 0x278 (0x678), irq 5, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
lp0: using parport0 (interrupt-driven).
r8169 Gigabit Ethernet driver 2.2LK loaded
gameport: NS558 PnP Gameport is pnp00:0f/gameport0, io 0x201, speed 701kHz
ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
ACPI: PCI Interrupt 0000:01:08.0[A] -> Link [APC3] -> GSI 18 (level, high) -> IRQ 177
eth0: Identified chip type is 'RTL8169s/8110s'.
eth0: RTL8169 at 0xf887e000, 00:50:fc:f4:fb:a2, IRQ 177
ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [APCJ] -> GSI 22 (level, high) -> IRQ 185
PCI: Setting latency timer of device 0000:00:06.0 to 64
usbcore: registered new driver usbfs
usbcore: registered new driver hub
hdc: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
intel8x0_measure_ac97_clock: measured 56046 usecs
intel8x0: clocking to 47474
ACPI: PCI Interrupt Link [APCL] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [APCL] -> GSI 21 (level, high) -> IRQ 193
PCI: Setting latency timer of device 0000:00:02.2 to 64
ehci_hcd 0000:00:02.2: EHCI Host Controller
ehci_hcd 0000:00:02.2: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.2
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.2: irq 193, io mem 0xe4003000
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: new device found, idVendor=0000, idProduct=0000
usb usb1: new device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.16.13-4-bigsmp ehci_hcd
usb usb1: SerialNumber: 0000:00:02.2
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 6 ports detected
ACPI: PCI Interrupt Link [APCF] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 20 (level, high) -> IRQ 201
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.0: irq 201, io mem 0xe4001000
usb usb2: new device found, idVendor=0000, idProduct=0000
usb usb2: new device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.16.13-4-bigsmp ohci_hcd
usb usb2: SerialNumber: 0000:00:02.0
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
usb 1-1: new high speed USB device using ehci_hcd and address 2
ACPI: PCI Interrupt Link [APCG] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCG] -> GSI 22 (level, high) -> IRQ 185
PCI: Setting latency timer of device 0000:00:02.1 to 64
ohci_hcd 0000:00:02.1: OHCI Host Controller
ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:02.1: irq 185, io mem 0xe4002000
usb 1-1: new device found, idVendor=04cc, idProduct=1520
usb 1-1: new device strings: Mfr=0, Product=0, SerialNumber=0
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
usb usb3: new device found, idVendor=0000, idProduct=0000
usb usb3: new device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: OHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.16.13-4-bigsmp ohci_hcd
usb usb3: SerialNumber: 0000:00:02.1
hub 1-1:1.0: 4 ports detected
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 3 ports detected
hdd: ATAPI 40X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Linux agpgart interface v0.101 (c) Dave Jones
i2c_adapter i2c-0: nForce2 SMBus adapter at 0x5000
i2c_adapter i2c-1: nForce2 SMBus adapter at 0x5500
agpgart: Detected NVIDIA nForce2 chipset
agpgart: AGP aperture is 128M @ 0xd0000000
usb 1-6: new high speed USB device using ehci_hcd and address 4
usb 1-6: new device found, idVendor=04b4, idProduct=6560
usb 1-6: new device strings: Mfr=0, Product=0, SerialNumber=0
usb 1-6: configuration #1 chosen from 1 choice
hub 1-6:1.0: USB hub found
hub 1-6:1.0: 4 ports detected
ohci_hcd 0000:00:02.0: wakeup
device-mapper: 4.5.0-ioctl (2005-10-04) initialised: [email]dm-devel@redhat.com[/email]
dm-netlink version 0.0.2 loaded
usb 1-1.1: new full speed USB device using ehci_hcd and address 5
usb 1-1.1: new device found, idVendor=0403, idProduct=fc82
usb 1-1.1: new device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: SEMC DSS-20 SyncStation
usb 1-1.1: Manufacturer: Sony Ericsson
usb 1-1.1: SerialNumber: 00007QEX
usb 1-1.1: configuration #1 chosen from 1 choice
usb 1-6.1: new high speed USB device using ehci_hcd and address 6
usb 1-6.1: new device found, idVendor=1660, idProduct=0932
usb 1-6.1: new device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-6.1: Product: USB Hybrid Video Capture
usb 1-6.1: Manufacturer: Conexant
usb 1-6.1: configuration #1 chosen from 1 choice
usb 1-6.2: new low speed USB device using ehci_hcd and address 7
usb 1-6.2: new device found, idVendor=0bc7, idProduct=0006
usb 1-6.2: new device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-6.2: Product: USB Receiver
usb 1-6.2: Manufacturer: X10 Wireless Technology Inc
usb 1-6.2: configuration #1 chosen from 1 choice
usb 1-6.4: new high speed USB device using ehci_hcd and address 8
lirc_dev: module not supported by Novell, setting U taint flag.
lirc_dev: IR Remote Control driver registered, at major 61
lirc_atiusb: module not supported by Novell, setting U taint flag.
lirc_atiusb: USB remote driver for LIRC v0.5
lirc_atiusb: Paul Miller <pmiller9@users.sourceforge.net>
usb 1-6.4: new device found, idVendor=0dda, idProduct=2005
usb 1-6.4: new device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-6.4: Product: 2.0 Card Reader
usb 1-6.4: Manufacturer: USB Reader
usb 1-6.4: SerialNumber: ABCD12345678
usb 1-6.4: configuration #1 chosen from 1 choice
usbcore: registered new driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
SCSI subsystem initialized
Initializing USB Mass Storage driver...
usb 2-2: new full speed USB device using ohci_hcd and address 2
usb 2-2: new device found, idVendor=04a7, idProduct=0331
usb 2-2: new device strings: Mfr=4, Product=7, SerialNumber=0
usb 2-2: Product: OneTouch 8600 EPP/USB
usb 2-2: Manufacturer: Visioneer
usb 2-2: configuration #1 chosen from 1 choice
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
lirc_dev: lirc_register_plugin: sample_rate: 0
lirc_atiusb[7]: X10 Wireless Technology Inc USB Receiver on usb1:7
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new driver lirc_atiusb
scsi0 : SCSI emulation for USB Mass Storage devices
ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
drivers/usb/serial/ftdi_sio.c: Detected FT232BM
usb-storage: device found at 8
usb-storage: waiting for device to settle before scanning
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
usbcore: registered new driver ati_remote
drivers/usb/input/ati_remote.c: Registered USB driver ATI/X10 RF USB Remote Control v. 2.2.1
usbcore: registered new driver ftdi_sio
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
Vendor: USB Read Model: CF Card CF Rev: 1.8D
Type: Direct-Access ANSI SCSI revision: 00
Vendor: USB Read Model: MS card MS Rev: 1.8D
Driver 'sd' needs updating - please use bus_type methods
Vendor: USB Read Model: SD card MMC/SD Rev: 1.8D
Vendor: USB Read Model: SM card SM Rev: 1.8D
sd 0:0:0:0: Attached scsi removable disk sda
sd 0:0:0:1: Attached scsi removable disk sdb
usb-storage: device scan complete
SCSI device sdc: 1000448 512-byte hdwr sectors (512 MB)
sdc: Write Protect is off
sdc: Mode Sense: 4b 00 00 08
sdc: assuming drive cache: write through
sdc: sdc1
sd 0:0:0:2: Attached scsi removable disk sdc
sd 0:0:0:3: Attached scsi removable disk sdd
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:1: Attached scsi generic sg1 type 0
sd 0:0:0:2: Attached scsi generic sg2 type 0
sd 0:0:0:3: Attached scsi generic sg3 type 0
loop: loaded (max 8 devices)
ReiserFS: hdb3: found reiserfs format "3.6" with standard journal
ReiserFS: hdb3: using ordered data mode
ReiserFS: hdb3: journal params: device hdb3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hdb3: checking transaction log (hdb3)
ReiserFS: hdb3: Using r5 hash to sort names
NTFS driver 2.1.26 [Flags: R/W MODULE].
NTFS volume version 3.1.
AppArmor: AppArmor (version 2.0-19.43r6320) initialized
audit(1148420780.182:2): AppArmor (version 2.0-19.43r6320) initialized
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
ip6_tables: (C) 2000-2006 Netfilter Core Team
ip_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (8192 buckets, 65536 max) - 216 bytes per conntrack
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
BIOS EDD facility v0.16 2004-Jun-25, 2 devices found
r8169: eth0: link up
powernow-k8: Processor cpuid 6a0 not supported
eth0: no IPv6 routers present
vmmon: module not supported by Novell, setting U taint flag.
vmmon: module license 'unspecified' taints kernel.
/dev/vmmon[3860]: Module vmmon: registered with major=10 minor=165
/dev/vmmon[3860]: Module vmmon: initialized
vmnet: module not supported by Novell, setting U taint flag.
/dev/vmnet: open called by PID 3896 (vmnet-bridge)
/dev/vmnet: hub 0 does not exist, allocating memory.
/dev/vmnet: port on hub 0 successfully opened
bridge-eth0: enabling the bridge
bridge-eth0: up
bridge-eth0: already up
bridge-eth0: attached
novfs: module not supported by Novell, setting U taint flag.
bootsplash: status on console 0 changed to on
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.15.7 DST=224.0.0.251 LEN=109 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=89
Linux video capture interface: v1.00
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
st: Version 20050830, fixed bufsize 32768, s/g segs 256
