SSH mit Public Key "und" Passwort
P
pitcare
Hallo zusammen,
ich habe SSH auf meinen Suse Linux Server mit einem Private key ausgestattet. Das funktioniert auch prima, ich kann mich also ohne Angabe eines PW an dem Server anmelden.
Nun möchte ich aber, das er beim Login, Schlüssel und Passwort erfragt.
Das funktioniert leider überhaupt nicht.
Hier meine Config,
# $OpenBSD: sshd_config,v 1.81 2009/10/08 14:03:41 markus Exp $
# This is the sshd server system-wide configuration file. See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented. Uncommented options change a
# default value.
Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# The default requires explicit activation of protocol 1
Protocol 2
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 1024
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
PermitRootLogin yes
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile .ssh/authorized_keys
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#RhostsRSAAuthentication no
# similar for protocol version 2
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
PasswordAuthentication yes
#PermitEmptyPasswords no
# Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Set this to 'yes' to enable support for the deprecated 'gssapi' authentication
# mechanism to OpenSSH 3.8p1. The newer 'gssapi-with-mic' mechanism is included
# in this release. The use of 'gssapi' is deprecated due to the presence of
# potential man-in-the-middle attacks, which 'gssapi-with-mic' is not susceptible to.
#GSSAPIEnableMITMAttack no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM no
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
#PermitTunnel no
#ChrootDirectory none
# no default banner path
#Banner none
# override default of no subsystems
Subsystem sftp /usr/lib64/ssh/sftp-server
# This enables accepting locale enviroment variables LC_* LANG, see sshd_config(5).
AcceptEnv LANG LC_CTYPE LC_NUMERIC LC_TIME LC_COLLATE LC_MONETARY LC_MESSAGES
AcceptEnv LC_PAPER LC_NAME LC_ADDRESS LC_TELEPHONE LC_MEASUREMENT
AcceptEnv LC_IDENTIFICATION LC_ALL
# Example of overriding settings on a per-user basis
#Match User anoncvs
# X11Forwarding no
# AllowTcpForwarding no
# ForceCommand cvs server
Ich habe jetzt an der Config schon ein bisschen zu viel rumgedoktert und sehe wahrscheinlich den Wald vor lauter Bäumen nicht mehr.
Hmm, so wie ich sshd verstanden habe, geht es so nicht.
Entweder erlaubt man auf dem Server
hostbased, private/public key oder passwort authentifizierung.
Wenn eine davon erfolgreich ist, wird der Zugang gewährt.
Du kannst den privatekey natürlich mit einem Passwort verschlüsseln, dann muss dieses Passwort beim login angegeben werden, welches nicht das gleiche sein muss, wie das nis/ldap/passwd passwort.
Ich verstehe die Fragestellung gar nicht..
mit PAM laesst sich das vielleicht regeln, dann muesste das ssh-login nach erfolg eben noch pw-login nutzen..
ich seh nicht den sinn dahinter, aber mkay
Aaahh jetzt habe ich es verstanden. Die richtige Antwort lautet mach es nicht so. Wenn der User den Key hat, dann ist er legitimiert, dafür ist das da. Du kannst/solltest den Key mit einem Kennwort schützen, damit er nicht einfach entwendet werden kann. Ein Kennwort zusätzlich zum Key klingt nicht sinnvoll. Warum willst du das?
configure schlägt bei X fehl
NGINX bietet intern abgerufene Seiten nur zum Download an, extern geht's
Samba-Server mit Univention Corporate Server
