smb.conf does not work on a reinstalled system
W
wizardofOz
Hi everyone!
Since I searched the internet for an answer to my problem, for three days, I
though it might be a good idea to make the question in this forum.
My Samba Server is a really simple one, only serving files. My smb.conf is
at the absolute minimum (ok, no really absolute;-)):
[global]
workgroup=Univerum
netbios name= saturn
server String= Universum/Saturn
[public]
path= /var/public
guest ok= no
read only= no
That's it. It works before. Windows XP prompts for username and password. I
used a user and a password that was valid in my linux system. I can use it to log in from the shell or per ssh. Now I
reinstalled my system. The same conf file does not work now. I have no idea
what I should do, since it worked before with nothing else more. The only
strange thing is, that Windows transformed my username to <win_pc_name>\<username> while logging in that was not the case before. My distribution is and was Gentoo.
I would be very glad for any help.
Thanks,
Danny
Did you used smbpasswd to set a valid user for you samba users ?
Hi.
Welcome to the UB.
Here my smb.conf:
# smb.conf is the main Samba configuration file. You find a full commented
# version at /usr/share/doc/packages/samba/examples/smb.conf.SUSE if the
# samba-doc package is installed.
# Date: 2005-09-13
[global]
	workgroup = SIM4000
	printcap name = cups
	cups options = raw
	map to guest = Bad User
	include = /etc/samba/dhcp.conf
	logon path = \\%L\profiles\.msprofile
	logon home = \\%L\%U\.9xprofile
	logon drive = P:
	add machine script = /usr/sbin/useradd  -c Machine -d /var/lib/nobody -s /bin/false %m$
	domain logons = Yes
	domain master = Yes
	security = user
	local master = Yes
	os level = 65
	preferred master = Yes
[homes]
	comment = Home Directories
	valid users = %S
	browseable = No
	read only = No
	inherit acls = Yes
[profiles]
	comment = Network Profiles Service
	path = %H
	read only = No
	store dos attributes = Yes
	create mask = 0600
	directory mask = 0700
[users]
	comment = All users
	path = /home
	read only = No
	inherit acls = Yes
	veto files = /aquota.user/groups/shares/
[groups]
	comment = All groups
	path = /home/groups
	read only = No
	inherit acls = Yes
[printers]
	comment = All Printers
	path = /var/tmp
	printable = Yes
	create mask = 0600
	browseable = No
[print$]
	comment = Printer Drivers
	path = /var/lib/samba/drivers
	write list = @ntadmin root
	force group = ntadmin
	create mask = 0664
	directory mask = 0775
[netlogon]
	comment = Network Logon Service
	path = /var/lib/samba/netlogon
	write list = root
	path = /
	guest ok = yes
I use SuSE 10.0. For File Transfer to a XP system.
What says the Logfile from your samba?
Yours sincerely, sim4000.
PS: I'm not a great Englishspeaker / writer. :brav:
Thanks for your feedback.
Since I reinstalled by system I forgot that I have to run the command smbpasswd. My How-To did only metion everthing about installing and configuring samba, but not how to install users. So I assumed that all system user automaticlly are known by samba. What was not the case.
This was the only thing I had to do!
Bye until my next newbie question ;-)
Danny
NGINX bietet intern abgerufene Seiten nur zum Download an, extern geht's
Email via script via Exchange Server (SASL)
Samba-Server mit Univention Corporate Server
