Sich einer Arbeitsgruppe anschließen, wie?
Das passiert, wenn man apt-get statt aptitude nutzt ;)
Kommt jetzt der ursprüngliche Fehler immer noch?
Schon mal den Konqueror von der Konsole gestartet? Schonmal ins syslog oder messages geschaut? Mal per ps oder top geschaut, was er da treibt?
Sieh mal
debian2:/home/michael# konqueror
Xlib: connection to ":0.0" refused by server
Xlib: Invalid MIT-MAGIC-COOKIE-1 key
konqueror: cannot connect to X server :0.0
ps
debian2:/home/michael# ps
  PID TTY          TIME CMD
 4635 pts/1    00:00:00 su
 4636 pts/1    00:00:00 bash
 4654 pts/1    00:00:00 ps
top
debian2:/home/michael# top
top - 23:23:39 up 54 min,  1 user,  load average: 0.61, 0.26, 0.12
Tasks:  93 total,   6 running,  87 sleeping,   0 stopped,   0 zombie
Cpu(s): 14.3%us, 11.7%sy,  0.0%ni, 73.4%id,  0.0%wa,  0.0%hi,  0.6%si,  0.0%st
top - 23:24:22 up 55 min,  1 user,  load average: 0.31, 0.23, 0.12
Tasks:  93 total,   2 running,  91 sleeping,   0 stopped,   0 zombie
Cpu(s):  0.7%us,  0.0%sy,  0.0%ni, 99.0%id,  0.0%wa,  0.0%hi,  0.3%si,  0.0%st
Mem:    516360k total,   308100k used,   208260k free,     7256k buffers
Swap:   755012k total,        0k used,   755012k free,   163552k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 4176 root      15   0 33700  19m 4400 S  0.3  3.9   0:10.26 Xorg
 4611 michael   15   0 34632  16m  13m R  0.3  3.3   0:03.67 konsole
    1 root      15   0  1944  648  556 S  0.0  0.1   0:01.02 init
    2 root      RT   0     0    0    0 S  0.0  0.0   0:00.00 migration/0
    3 root      34  19     0    0    0 S  0.0  0.0   0:00.00 ksoftirqd/0
    4 root      10  -5     0    0    0 S  0.0  0.0   0:00.74 events/0
    5 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 khelper
    6 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kthread
    9 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kblockd/0
   10 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 kacpid
  104 root      10  -5     0    0    0 S  0.0  0.0   0:00.04 kseriod
  140 root      25   0     0    0    0 S  0.0  0.0   0:00.00 pdflush
  141 root      15   0     0    0    0 S  0.0  0.0   0:00.00 pdflush
  142 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 kswapd0
  143 root      20  -5     0    0    0 S  0.0  0.0   0:00.00 aio/0
  596 root      10  -5     0    0    0 S  0.0  0.0   0:00.02 khubd
 1318 root      16  -4  2708 1168  368 S  0.0  0.2   0:00.11 udevd
 1719 root      10  -5     0    0    0 S  0.0  0.0   0:00.00 pccardd
 1753 root      12  -5     0    0    0 S  0.0  0.0   0:00.00 pccardd
 1827 root      17  -5     0    0    0 S  0.0  0.0   0:00.00 kpsmoused
 2208 root      19  -5     0    0    0 S  0.0  0.0   0:00.00 kmirrord
 2831 daemon    15   0  1688  380  284 S  0.0  0.1   0:00.00 portmap
 3147 root      18   0  2560  932  792 S  0.0  0.2   0:00.02 syslogd
 3153 root      20   0  1580  384  312 S  0.0  0.1   0:00.00 klogd
syslog und messages kommt noch
Ein hoffentlich interessanter Teil der syslog.
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/fault.c:fault_report(41)
Jun  4 16:02:34 localhost nmbd[5208]:   ===============================================================
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/fault.c:fault_report(42)
Jun  4 16:02:34 localhost nmbd[5208]:   INTERNAL ERROR: Signal 11 in pid 5208 (3.0.24)
Jun  4 16:02:34 localhost nmbd[5208]:   Please read the Trouble-Shooting section of the Samba3-HOWTO
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/fault.c:fault_report(44)
Jun  4 16:02:34 localhost nmbd[5208]:   From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/fault.c:fault_report(45)
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/util.c:smb_panic(1599)
Jun  4 16:02:34 localhost nmbd[5208]:   PANIC (pid 5208): internal error
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/util.c:log_stack_trace(1706)
Jun  4 16:02:34 localhost nmbd[5208]:   BACKTRACE: 8 stack frames:
Jun  4 16:02:34 localhost nmbd[5208]:    #0 /usr/sbin/nmbd(log_stack_trace+0x23) [0x80d4b33]
Jun  4 16:02:34 localhost nmbd[5208]:    #1 /usr/sbin/nmbd(smb_panic+0x46) [0x80d4c26]
Jun  4 16:02:34 localhost nmbd[5208]:    #2 /usr/sbin/nmbd [0x80c2dfa]
Jun  4 16:02:34 localhost nmbd[5208]:    #3 [0xb7fe5420]
Jun  4 16:02:34 localhost nmbd[5208]:    #4 /usr/sbin/nmbd(announce_remote+0x147) [0x8075ee7]
Jun  4 16:02:34 localhost nmbd[5208]:    #5 /usr/sbin/nmbd(main+0x795) [0x80637c5]
Jun  4 16:02:34 localhost nmbd[5208]:    #6 /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xc8) [0xb7d41ea8]
Jun  4 16:02:34 localhost nmbd[5208]:    #7 /usr/sbin/nmbd [0x8061ee1]
Jun  4 16:02:34 localhost nmbd[5208]: [2007/06/04 16:02:34, 0] lib/fault.c:dump_core(173)
Jun  4 16:02:34 localhost nmbd[5208]:   dumping core in /var/log/samba/cores/nmbd
Wenn du einen bestimmten Bereich sehen willst, sag mir einfach welchen.
starte mal den Konqi nicht als root.
sondern als normaler nutzer, oder mit einem su davor für rootrechte
Ich hab das mal getan, wenn ich auch keine Ahnung hatte wieso.
Was hast du dir davon erhofft??????
Ich hab das Gefühl, das meine gesamte Netzwerkkonfiguration im Eimer ist.
Wie muss ich denn Vorgehen, wenn alles noch von Anfang an neu machen will.
Der Dump deutet irgendwie darauf hin, dass sich libc6 und samba nicht vertragen ... (oder der Kernel)
apt-cache policy libc6 samba
und auch gleich mal das samba-Paket reinstallieren ...
Sonst irgendwelche Probleme mit dem System?
So nebenbei, was hat es auf sich mit apt-get und aptitude?
aptitude deinstalliert im Gegensatz zu apt auch die Abhängigkeiten mit.
Wenn du also immer apt genutzt hast, und mit aptitude etwas deinstallierst, kann es sein, dass dir Pakete flöten gehen, die du eigentlich noch brauchst.
Aptitude weiss in dem Fall nämlich nicht, dass du die Pakete installiert hast, und will sie demzufolge löschen.
http://wiki.debianforum.de/SoftwareVerwalten/AptitudeVsAptGet?highlight=(aptitude)
debian2:/home/michael# apt-cache policy libc6 samba
libc6:
  Installiert:2.3.6.ds1-13
  Mögliche Pakete:2.3.6.ds1-13
  Versions-Tabelle:
 *** 2.3.6.ds1-13 0
        500 http://ftp.de.debian.org etch/main Packages
        500 http://ftp-stud.fht-esslingen.de etch/main Packages
        100 /var/lib/dpkg/status
samba:
  Installiert:3.0.24-6etch2
  Mögliche Pakete:3.0.24-6etch4
  Versions-Tabelle:
     3.0.24-6etch4 0
        500 http://security.debian.org etch/updates/main Packages
 *** 3.0.24-6etch2 0
     3.0.24-6 0
Ansonsten läuft alles rund.
Installier mal die korrigiert Samba Version (3.0.24-6etch4) ... upgrade oder dist-upgrade sollte da helfen ...
Hab ich gemacht. Doch das Problem besteht weiterhin. Siehe Anhang.
Hab das Gefühl, dass an meiner gesamten Netzwerkkonfiguration was nicht stimmt.
Kaufberatung?
Komplizierteres Netzwerkproblem (Zwei Rechner, ein Router)
Ein komplizierteres Thema: Samba Server - XP-Pro Clients - wlan lan und und und
Siemens SE361 Router - DNS auflösung ?
Routing funktioniert nicht mehr nach dem Start der Firewall
