[sav@moerb ~]$ strace screen
execve("/usr/bin/screen", ["screen"], [/* 20 vars */]) = 0
brk(0) = 0x80a7000
uname({sys="Linux", node="CHANGED!", ...}) = 0
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=20894, ...}) = 0
old_mmap(NULL, 20894, PROT_READ, MAP_PRIVATE, 3, 0) = 0x4001c000
close(3) = 0
open("/usr/lib/libncurses.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\343"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=984028, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40022000
old_mmap(NULL, 290348, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40023000
old_mmap(0x40061000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3d000) = 0x40061000
close(3) = 0
open("/usr/lib/libutempter.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0d\6\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=9267, ...}) = 0
old_mmap(NULL, 6980, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x4006a000
old_mmap(0x4006b000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0x4006b000
close(3) = 0
open("/lib/libutil.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\f\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=13380, ...}) = 0
old_mmap(NULL, 12432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x4006c000
old_mmap(0x4006e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x4006e000
close(3) = 0
open("/lib/libcrypt.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360\7\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=25960, ...}) = 0
old_mmap(NULL, 184604, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x40070000
old_mmap(0x40075000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x40075000
old_mmap(0x40077000, 155932, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40077000
close(3) = 0
open("/lib/libpam.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\27"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=34044, ...}) = 0
old_mmap(NULL, 36864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x4009e000
old_mmap(0x400a6000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x400a6000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\212N\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1482536, ...}) = 0
old_mmap(NULL, 1215452, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x400a7000
old_mmap(0x401ca000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x123000) = 0x401ca000
old_mmap(0x401ce000, 7132, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x401ce000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\f\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=14504, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x401d0000
old_mmap(NULL, 12408, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401d1000
old_mmap(0x401d3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x401d3000
close(3) = 0
open("/lib/libaudit.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260R\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=57820, ...}) = 0
old_mmap(NULL, 56616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401d5000
old_mmap(0x401df000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x401df000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x401e3000
set_thread_area({entry_number:-1 -> 6, base_addr:0x401e36c0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
mprotect(0x401d3000, 4096, PROT_READ) = 0
mprotect(0x401ca000, 8192, PROT_READ) = 0
mprotect(0x40075000, 4096, PROT_READ) = 0
mprotect(0x4006e000, 4096, PROT_READ) = 0
mprotect(0x4001a000, 4096, PROT_READ) = 0
munmap(0x4001c000, 20894) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
close(1023) = -1 EBADF (Bad file descriptor)
close(1022) = -1 EBADF (Bad file descriptor)
close(1021) = -1 EBADF (Bad file descriptor)
close(1020) = -1 EBADF (Bad file descriptor)
close(1019) = -1 EBADF (Bad file descriptor)
close(1018) = -1 EBADF (Bad file descriptor)
close(1017) = -1 EBADF (Bad file descriptor)
close(1016) = -1 EBADF (Bad file descriptor)
close(1015) = -1 EBADF (Bad file descriptor)
close(1014) = -1 EBADF (Bad file descriptor)
close(1013) = -1 EBADF (Bad file descriptor)
close(1012) = -1 EBADF (Bad file descriptor)
close(1011) = -1 EBADF (Bad file descriptor)
close(1010) = -1 EBADF (Bad file descriptor)
close(1009) = -1 EBADF (Bad file descriptor)
close(1008) = -1 EBADF (Bad file descriptor)
close(1007) = -1 EBADF (Bad file descriptor)
close(1006) = -1 EBADF (Bad file descriptor)
close(1005) = -1 EBADF (Bad file descriptor)
close(1004) = -1 EBADF (Bad file descriptor)
close(1003) = -1 EBADF (Bad file descriptor)
close(1002) = -1 EBADF (Bad file descriptor)
close(1001) = -1 EBADF (Bad file descriptor)
close(1000) = -1 EBADF (Bad file descriptor)
close(999) = -1 EBADF (Bad file descriptor)
close(998) = -1 EBADF (Bad file descriptor)
close(997) = -1 EBADF (Bad file descriptor)
close(996) = -1 EBADF (Bad file descriptor)
close(995) = -1 EBADF (Bad file descriptor)
close(994) = -1 EBADF (Bad file descriptor)
close(993) = -1 EBADF (Bad file descriptor)
close(992) = -1 EBADF (Bad file descriptor)
close(991) = -1 EBADF (Bad file descriptor)
close(990) = -1 EBADF (Bad file descriptor)
close(989) = -1 EBADF (Bad file descriptor)
close(988) = -1 EBADF (Bad file descriptor)
close(987) = -1 EBADF (Bad file descriptor)
close(986) = -1 EBADF (Bad file descriptor)
close(985) = -1 EBADF (Bad file descriptor)
close(984) = -1 EBADF (Bad file descriptor)
close(983) = -1 EBADF (Bad file descriptor)
close(982) = -1 EBADF (Bad file descriptor)
close(981) = -1 EBADF (Bad file descriptor)
close(980) = -1 EBADF (Bad file descriptor)
close(979) = -1 EBADF (Bad file descriptor)
close(978) = -1 EBADF (Bad file descriptor)
close(977) = -1 EBADF (Bad file descriptor)
close(976) = -1 EBADF (Bad file descriptor)
close(975) = -1 EBADF (Bad file descriptor)
close(974) = -1 EBADF (Bad file descriptor)
close(973) = -1 EBADF (Bad file descriptor)
close(972) = -1 EBADF (Bad file descriptor)
close(971) = -1 EBADF (Bad file descriptor)
close(970) = -1 EBADF (Bad file descriptor)
close(969) = -1 EBADF (Bad file descriptor)
close(968) = -1 EBADF (Bad file descriptor)
close(967) = -1 EBADF (Bad file descriptor)
close(966) = -1 EBADF (Bad file descriptor)
close(965) = -1 EBADF (Bad file descriptor)
close(964) = -1 EBADF (Bad file descriptor)
close(963) = -1 EBADF (Bad file descriptor)
close(962) = -1 EBADF (Bad file descriptor)
close(961) = -1 EBADF (Bad file descriptor)
close(960) = -1 EBADF (Bad file descriptor)
close(959) = -1 EBADF (Bad file descriptor)
close(958) = -1 EBADF (Bad file descriptor)
close(957) = -1 EBADF (Bad file descriptor)
close(956) = -1 EBADF (Bad file descriptor)
close(955) = -1 EBADF (Bad file descriptor)
close(954) = -1 EBADF (Bad file descriptor)
close(953) = -1 EBADF (Bad file descriptor)
close(952) = -1 EBADF (Bad file descriptor)
close(951) = -1 EBADF (Bad file descriptor)
close(950) = -1 EBADF (Bad file descriptor)
close(949) = -1 EBADF (Bad file descriptor)
close(948) = -1 EBADF (Bad file descriptor)
close(947) = -1 EBADF (Bad file descriptor)
close(946) = -1 EBADF (Bad file descriptor)
close(945) = -1 EBADF (Bad file descriptor)
close(944) = -1 EBADF (Bad file descriptor)
close(943) = -1 EBADF (Bad file descriptor)
close(942) = -1 EBADF (Bad file descriptor)
close(941) = -1 EBADF (Bad file descriptor)
close(940) = -1 EBADF (Bad file descriptor)
close(939) = -1 EBADF (Bad file descriptor)
close(938) = -1 EBADF (Bad file descriptor)
close(937) = -1 EBADF (Bad file descriptor)
close(936) = -1 EBADF (Bad file descriptor)
close(935) = -1 EBADF (Bad file descriptor)
close(934) = -1 EBADF (Bad file descriptor)
close(933) = -1 EBADF (Bad file descriptor)
close(932) = -1 EBADF (Bad file descriptor)
close(931) = -1 EBADF (Bad file descriptor)
close(930) = -1 EBADF (Bad file descriptor)
close(929) = -1 EBADF (Bad file descriptor)
close(928) = -1 EBADF (Bad file descriptor)
close(927) = -1 EBADF (Bad file descriptor)
close(926) = -1 EBADF (Bad file descriptor)
close(925) = -1 EBADF (Bad file descriptor)
close(924) = -1 EBADF (Bad file descriptor)
close(923) = -1 EBADF (Bad file descriptor)
close(922) = -1 EBADF (Bad file descriptor)
close(921) = -1 EBADF (Bad file descriptor)
close(920) = -1 EBADF (Bad file descriptor)
close(919) = -1 EBADF (Bad file descriptor)
close(918) = -1 EBADF (Bad file descriptor)
close(917) = -1 EBADF (Bad file descriptor)
close(916) = -1 EBADF (Bad file descriptor)
close(915) = -1 EBADF (Bad file descriptor)
close(914) = -1 EBADF (Bad file descriptor)
close(913) = -1 EBADF (Bad file descriptor)
close(912) = -1 EBADF (Bad file descriptor)
close(911) = -1 EBADF (Bad file descriptor)
close(910) = -1 EBADF (Bad file descriptor)
close(909) = -1 EBADF (Bad file descriptor)
close(908) = -1 EBADF (Bad file descriptor)
close(907) = -1 EBADF (Bad file descriptor)
close(906) = -1 EBADF (Bad file descriptor)
close(905) = -1 EBADF (Bad file descriptor)
close(904) = -1 EBADF (Bad file descriptor)
close(903) = -1 EBADF (Bad file descriptor)
close(902) = -1 EBADF (Bad file descriptor)
close(901) = -1 EBADF (Bad file descriptor)
close(900) = -1 EBADF (Bad file descriptor)
close(899) = -1 EBADF (Bad file descriptor)
close(898) = -1 EBADF (Bad file descriptor)
close(897) = -1 EBADF (Bad file descriptor)
close(896) = -1 EBADF (Bad file descriptor)
close(895) = -1 EBADF (Bad file descriptor)
close(894) = -1 EBADF (Bad file descriptor)
close(893) = -1 EBADF (Bad file descriptor)
close(892) = -1 EBADF (Bad file descriptor)
close(891) = -1 EBADF (Bad file descriptor)
close(890) = -1 EBADF (Bad file descriptor)
close(889) = -1 EBADF (Bad file descriptor)
close(888) = -1 EBADF (Bad file descriptor)
close(887) = -1 EBADF (Bad file descriptor)
close(886) = -1 EBADF (Bad file descriptor)
close(885) = -1 EBADF (Bad file descriptor)
close(884) = -1 EBADF (Bad file descriptor)
close(883) = -1 EBADF (Bad file descriptor)
close(882) = -1 EBADF (Bad file descriptor)
close(881) = -1 EBADF (Bad file descriptor)
close(880) = -1 EBADF (Bad file descriptor)
close(879) = -1 EBADF (Bad file descriptor)
close(878) = -1 EBADF (Bad file descriptor)
close(877) = -1 EBADF (Bad file descriptor)
close(876) = -1 EBADF (Bad file descriptor)
close(875) = -1 EBADF (Bad file descriptor)
close(874) = -1 EBADF (Bad file descriptor)
close(873) = -1 EBADF (Bad file descriptor)
close(872) = -1 EBADF (Bad file descriptor)
close(871) = -1 EBADF (Bad file descriptor)
close(870) = -1 EBADF (Bad file descriptor)
close(869) = -1 EBADF (Bad file descriptor)
close(868) = -1 EBADF (Bad file descriptor)
close(867) = -1 EBADF (Bad file descriptor)
close(866) = -1 EBADF (Bad file descriptor)
close(865) = -1 EBADF (Bad file descriptor)
close(864) = -1 EBADF (Bad file descriptor)
close(863) = -1 EBADF (Bad file descriptor)
close(862) = -1 EBADF (Bad file descriptor)
close(861) = -1 EBADF (Bad file descriptor)
close(860) = -1 EBADF (Bad file descriptor)
close(859) = -1 EBADF (Bad file descriptor)
close(858) = -1 EBADF (Bad file descriptor)
close(857) = -1 EBADF (Bad file descriptor)
close(856) = -1 EBADF (Bad file descriptor)
close(855) = -1 EBADF (Bad file descriptor)
close(854) = -1 EBADF (Bad file descriptor)
close(853) = -1 EBADF (Bad file descriptor)
close(852) = -1 EBADF (Bad file descriptor)
close(851) = -1 EBADF (Bad file descriptor)
close(850) = -1 EBADF (Bad file descriptor)
close(849) = -1 EBADF (Bad file descriptor)
close(848) = -1 EBADF (Bad file descriptor)
close(847) = -1 EBADF (Bad file descriptor)
close(846) = -1 EBADF (Bad file descriptor)
close(845) = -1 EBADF (Bad file descriptor)
close(844) = -1 EBADF (Bad file descriptor)
close(843) = -1 EBADF (Bad file descriptor)
close(842) = -1 EBADF (Bad file descriptor)
close(841) = -1 EBADF (Bad file descriptor)
close(840) = -1 EBADF (Bad file descriptor)
close(839) = -1 EBADF (Bad file descriptor)
close(838) = -1 EBADF (Bad file descriptor)
close(837) = -1 EBADF (Bad file descriptor)
close(836) = -1 EBADF (Bad file descriptor)
close(835) = -1 EBADF (Bad file descriptor)
close(834) = -1 EBADF (Bad file descriptor)
close(833) = -1 EBADF (Bad file descriptor)
close(832) = -1 EBADF (Bad file descriptor)
close(831) = -1 EBADF (Bad file descriptor)
close(830) = -1 EBADF (Bad file descriptor)
close(829) = -1 EBADF (Bad file descriptor)
close(828) = -1 EBADF (Bad file descriptor)
close(827) = -1 EBADF (Bad file descriptor)
close(826) = -1 EBADF (Bad file descriptor)
close(825) = -1 EBADF (Bad file descriptor)
close(824) = -1 EBADF (Bad file descriptor)
close(823) = -1 EBADF (Bad file descriptor)
close(822) = -1 EBADF (Bad file descriptor)
close(821) = -1 EBADF (Bad file descriptor)
close(820) = -1 EBADF (Bad file descriptor)
close(819) = -1 EBADF (Bad file descriptor)
close(818) = -1 EBADF (Bad file descriptor)
close(817) = -1 EBADF (Bad file descriptor)
close(816) = -1 EBADF (Bad file descriptor)
close(815) = -1 EBADF (Bad file descriptor)
close(814) = -1 EBADF (Bad file descriptor)
close(813) = -1 EBADF (Bad file descriptor)
close(812) = -1 EBADF (Bad file descriptor)
close(811) = -1 EBADF (Bad file descriptor)
close(810) = -1 EBADF (Bad file descriptor)
close(809) = -1 EBADF (Bad file descriptor)
close(808) = -1 EBADF (Bad file descriptor)
close(807) = -1 EBADF (Bad file descriptor)
close(806) = -1 EBADF (Bad file descriptor)
close(805) = -1 EBADF (Bad file descriptor)
close(804) = -1 EBADF (Bad file descriptor)
close(803) = -1 EBADF (Bad file descriptor)
close(802) = -1 EBADF (Bad file descriptor)
close(801) = -1 EBADF (Bad file descriptor)
close(800) = -1 EBADF (Bad file descriptor)
close(799) = -1 EBADF (Bad file descriptor)
close(798) = -1 EBADF (Bad file descriptor)
close(797) = -1 EBADF (Bad file descriptor)
close(796) = -1 EBADF (Bad file descriptor)
close(795) = -1 EBADF (Bad file descriptor)
close(794) = -1 EBADF (Bad file descriptor)
close(793) = -1 EBADF (Bad file descriptor)
close(792) = -1 EBADF (Bad file descriptor)
close(791) = -1 EBADF (Bad file descriptor)
close(790) = -1 EBADF (Bad file descriptor)
close(789) = -1 EBADF (Bad file descriptor)
close(788) = -1 EBADF (Bad file descriptor)
close(787) = -1 EBADF (Bad file descriptor)
close(786) = -1 EBADF (Bad file descriptor)
close(785) = -1 EBADF (Bad file descriptor)
close(784) = -1 EBADF (Bad file descriptor)
close(783) = -1 EBADF (Bad file descriptor)
close(782) = -1 EBADF (Bad file descriptor)
close(781) = -1 EBADF (Bad file descriptor)
close(780) = -1 EBADF (Bad file descriptor)
close(779) = -1 EBADF (Bad file descriptor)
close(778) = -1 EBADF (Bad file descriptor)
close(777) = -1 EBADF (Bad file descriptor)
close(776) = -1 EBADF (Bad file descriptor)
close(775) = -1 EBADF (Bad file descriptor)
close(774) = -1 EBADF (Bad file descriptor)
close(773) = -1 EBADF (Bad file descriptor)
close(772) = -1 EBADF (Bad file descriptor)
close(771) = -1 EBADF (Bad file descriptor)
close(770) = -1 EBADF (Bad file descriptor)
close(769) = -1 EBADF (Bad file descriptor)
close(768) = -1 EBADF (Bad file descriptor)
close(767) = -1 EBADF (Bad file descriptor)
close(766) = -1 EBADF (Bad file descriptor)
close(765) = -1 EBADF (Bad file descriptor)
close(764) = -1 EBADF (Bad file descriptor)
close(763) = -1 EBADF (Bad file descriptor)
close(762) = -1 EBADF (Bad file descriptor)
close(761) = -1 EBADF (Bad file descriptor)
close(760) = -1 EBADF (Bad file descriptor)
close(759) = -1 EBADF (Bad file descriptor)
close(758) = -1 EBADF (Bad file descriptor)
close(757) = -1 EBADF (Bad file descriptor)
close(756) = -1 EBADF (Bad file descriptor)
close(755) = -1 EBADF (Bad file descriptor)
close(754) = -1 EBADF (Bad file descriptor)
close(753) = -1 EBADF (Bad file descriptor)
close(752) = -1 EBADF (Bad file descriptor)
close(751) = -1 EBADF (Bad file descriptor)
close(750) = -1 EBADF (Bad file descriptor)
close(749) = -1 EBADF (Bad file descriptor)
close(748) = -1 EBADF (Bad file descriptor)
close(747) = -1 EBADF (Bad file descriptor)
close(746) = -1 EBADF (Bad file descriptor)
close(745) = -1 EBADF (Bad file descriptor)
close(744) = -1 EBADF (Bad file descriptor)
close(743) = -1 EBADF (Bad file descriptor)
close(742) = -1 EBADF (Bad file descriptor)
close(741) = -1 EBADF (Bad file descriptor)
close(740) = -1 EBADF (Bad file descriptor)
close(739) = -1 EBADF (Bad file descriptor)
close(738) = -1 EBADF (Bad file descriptor)
close(737) = -1 EBADF (Bad file descriptor)
close(736) = -1 EBADF (Bad file descriptor)
close(735) = -1 EBADF (Bad file descriptor)
close(734) = -1 EBADF (Bad file descriptor)
close(733) = -1 EBADF (Bad file descriptor)
close(732) = -1 EBADF (Bad file descriptor)
close(731) = -1 EBADF (Bad file descriptor)
close(730) = -1 EBADF (Bad file descriptor)
close(729) = -1 EBADF (Bad file descriptor)
close(728) = -1 EBADF (Bad file descriptor)
close(727) = -1 EBADF (Bad file descriptor)
close(726) = -1 EBADF (Bad file descriptor)
close(725) = -1 EBADF (Bad file descriptor)
close(724) = -1 EBADF (Bad file descriptor)
close(723) = -1 EBADF (Bad file descriptor)
close(722) = -1 EBADF (Bad file descriptor)
close(721) = -1 EBADF (Bad file descriptor)
close(720) = -1 EBADF (Bad file descriptor)
close(719) = -1 EBADF (Bad file descriptor)
close(718) = -1 EBADF (Bad file descriptor)
close(717) = -1 EBADF (Bad file descriptor)
close(716) = -1 EBADF (Bad file descriptor)
close(715) = -1 EBADF (Bad file descriptor)
close(714) = -1 EBADF (Bad file descriptor)
close(713) = -1 EBADF (Bad file descriptor)
close(712) = -1 EBADF (Bad file descriptor)
close(711) = -1 EBADF (Bad file descriptor)
close(710) = -1 EBADF (Bad file descriptor)
close(709) = -1 EBADF (Bad file descriptor)
close(708) = -1 EBADF (Bad file descriptor)
close(707) = -1 EBADF (Bad file descriptor)
close(706) = -1 EBADF (Bad file descriptor)
close(705) = -1 EBADF (Bad file descriptor)
close(704) = -1 EBADF (Bad file descriptor)
close(703) = -1 EBADF (Bad file descriptor)
close(702) = -1 EBADF (Bad file descriptor)
close(701) = -1 EBADF (Bad file descriptor)
close(700) = -1 EBADF (Bad file descriptor)
close(699) = -1 EBADF (Bad file descriptor)
close(698) = -1 EBADF (Bad file descriptor)
close(697) = -1 EBADF (Bad file descriptor)
close(696) = -1 EBADF (Bad file descriptor)
close(695) = -1 EBADF (Bad file descriptor)
close(694) = -1 EBADF (Bad file descriptor)
close(693) = -1 EBADF (Bad file descriptor)
close(692) = -1 EBADF (Bad file descriptor)
close(691) = -1 EBADF (Bad file descriptor)
close(690) = -1 EBADF (Bad file descriptor)
close(689) = -1 EBADF (Bad file descriptor)
close(688) = -1 EBADF (Bad file descriptor)
close(687) = -1 EBADF (Bad file descriptor)
close(686) = -1 EBADF (Bad file descriptor)
close(685) = -1 EBADF (Bad file descriptor)
close(684) = -1 EBADF (Bad file descriptor)
close(683) = -1 EBADF (Bad file descriptor)
close(682) = -1 EBADF (Bad file descriptor)
close(681) = -1 EBADF (Bad file descriptor)
close(680) = -1 EBADF (Bad file descriptor)
close(679) = -1 EBADF (Bad file descriptor)
close(678) = -1 EBADF (Bad file descriptor)
close(677) = -1 EBADF (Bad file descriptor)
close(676) = -1 EBADF (Bad file descriptor)
close(675) = -1 EBADF (Bad file descriptor)
close(674) = -1 EBADF (Bad file descriptor)
close(673) = -1 EBADF (Bad file descriptor)
close(672) = -1 EBADF (Bad file descriptor)
close(671) = -1 EBADF (Bad file descriptor)
close(670) = -1 EBADF (Bad file descriptor)
close(669) = -1 EBADF (Bad file descriptor)
close(668) = -1 EBADF (Bad file descriptor)
close(667) = -1 EBADF (Bad file descriptor)
close(666) = -1 EBADF (Bad file descriptor)
close(665) = -1 EBADF (Bad file descriptor)
close(664) = -1 EBADF (Bad file descriptor)
close(663) = -1 EBADF (Bad file descriptor)
close(662) = -1 EBADF (Bad file descriptor)
close(661) = -1 EBADF (Bad file descriptor)
close(660) = -1 EBADF (Bad file descriptor)
close(659) = -1 EBADF (Bad file descriptor)
close(658) = -1 EBADF (Bad file descriptor)
close(657) = -1 EBADF (Bad file descriptor)
close(656) = -1 EBADF (Bad file descriptor)
close(655) = -1 EBADF (Bad file descriptor)
close(654) = -1 EBADF (Bad file descriptor)
close(653) = -1 EBADF (Bad file descriptor)
close(652) = -1 EBADF (Bad file descriptor)
close(651) = -1 EBADF (Bad file descriptor)
close(650) = -1 EBADF (Bad file descriptor)
close(649) = -1 EBADF (Bad file descriptor)
close(648) = -1 EBADF (Bad file descriptor)
close(647) = -1 EBADF (Bad file descriptor)
close(646) = -1 EBADF (Bad file descriptor)
close(645) = -1 EBADF (Bad file descriptor)
close(644) = -1 EBADF (Bad file descriptor)
close(643) = -1 EBADF (Bad file descriptor)
close(642) = -1 EBADF (Bad file descriptor)
close(641) = -1 EBADF (Bad file descriptor)
close(640) = -1 EBADF (Bad file descriptor)
close(639) = -1 EBADF (Bad file descriptor)
close(638) = -1 EBADF (Bad file descriptor)
close(637) = -1 EBADF (Bad file descriptor)
close(636) = -1 EBADF (Bad file descriptor)
close(635) = -1 EBADF (Bad file descriptor)
close(634) = -1 EBADF (Bad file descriptor)
close(633) = -1 EBADF (Bad file descriptor)
close(632) = -1 EBADF (Bad file descriptor)
close(631) = -1 EBADF (Bad file descriptor)
close(630) = -1 EBADF (Bad file descriptor)
close(629) = -1 EBADF (Bad file descriptor)
close(628) = -1 EBADF (Bad file descriptor)
close(627) = -1 EBADF (Bad file descriptor)
close(626) = -1 EBADF (Bad file descriptor)
close(625) = -1 EBADF (Bad file descriptor)
close(624) = -1 EBADF (Bad file descriptor)
close(623) = -1 EBADF (Bad file descriptor)
close(622) = -1 EBADF (Bad file descriptor)
close(621) = -1 EBADF (Bad file descriptor)
close(620) = -1 EBADF (Bad file descriptor)
close(619) = -1 EBADF (Bad file descriptor)
close(618) = -1 EBADF (Bad file descriptor)
close(617) = -1 EBADF (Bad file descriptor)
close(616) = -1 EBADF (Bad file descriptor)
close(615) = -1 EBADF (Bad file descriptor)
close(614) = -1 EBADF (Bad file descriptor)
close(613) = -1 EBADF (Bad file descriptor)
close(612) = -1 EBADF (Bad file descriptor)
close(611) = -1 EBADF (Bad file descriptor)
close(610) = -1 EBADF (Bad file descriptor)
close(609) = -1 EBADF (Bad file descriptor)
close(608) = -1 EBADF (Bad file descriptor)
close(607) = -1 EBADF (Bad file descriptor)
close(606) = -1 EBADF (Bad file descriptor)
close(605) = -1 EBADF (Bad file descriptor)
close(604) = -1 EBADF (Bad file descriptor)
close(603) = -1 EBADF (Bad file descriptor)
close(602) = -1 EBADF (Bad file descriptor)
close(601) = -1 EBADF (Bad file descriptor)
close(600) = -1 EBADF (Bad file descriptor)
close(599) = -1 EBADF (Bad file descriptor)
close(598) = -1 EBADF (Bad file descriptor)
close(597) = -1 EBADF (Bad file descriptor)
close(596) = -1 EBADF (Bad file descriptor)
close(595) = -1 EBADF (Bad file descriptor)
close(594) = -1 EBADF (Bad file descriptor)
close(593) = -1 EBADF (Bad file descriptor)
close(592) = -1 EBADF (Bad file descriptor)
close(591) = -1 EBADF (Bad file descriptor)
close(590) = -1 EBADF (Bad file descriptor)
close(589) = -1 EBADF (Bad file descriptor)
close(588) = -1 EBADF (Bad file descriptor)
close(587) = -1 EBADF (Bad file descriptor)
close(586) = -1 EBADF (Bad file descriptor)
close(585) = -1 EBADF (Bad file descriptor)
close(584) = -1 EBADF (Bad file descriptor)
close(583) = -1 EBADF (Bad file descriptor)
close(582) = -1 EBADF (Bad file descriptor)
close(581) = -1 EBADF (Bad file descriptor)
close(580) = -1 EBADF (Bad file descriptor)
close(579) = -1 EBADF (Bad file descriptor)
close(578) = -1 EBADF (Bad file descriptor)
close(577) = -1 EBADF (Bad file descriptor)
close(576) = -1 EBADF (Bad file descriptor)
close(575) = -1 EBADF (Bad file descriptor)
close(574) = -1 EBADF (Bad file descriptor)
close(573) = -1 EBADF (Bad file descriptor)
close(572) = -1 EBADF (Bad file descriptor)
close(571) = -1 EBADF (Bad file descriptor)
close(570) = -1 EBADF (Bad file descriptor)
close(569) = -1 EBADF (Bad file descriptor)
close(568) = -1 EBADF (Bad file descriptor)
close(567) = -1 EBADF (Bad file descriptor)
close(566) = -1 EBADF (Bad file descriptor)
close(565) = -1 EBADF (Bad file descriptor)
close(564) = -1 EBADF (Bad file descriptor)
close(563) = -1 EBADF (Bad file descriptor)
close(562) = -1 EBADF (Bad file descriptor)
close(561) = -1 EBADF (Bad file descriptor)
close(560) = -1 EBADF (Bad file descriptor)
close(559) = -1 EBADF (Bad file descriptor)
close(558) = -1 EBADF (Bad file descriptor)
close(557) = -1 EBADF (Bad file descriptor)
close(556) = -1 EBADF (Bad file descriptor)
close(555) = -1 EBADF (Bad file descriptor)
close(554) = -1 EBADF (Bad file descriptor)
close(553) = -1 EBADF (Bad file descriptor)
close(552) = -1 EBADF (Bad file descriptor)
close(551) = -1 EBADF (Bad file descriptor)
close(550) = -1 EBADF (Bad file descriptor)
close(549) = -1 EBADF (Bad file descriptor)
close(548) = -1 EBADF (Bad file descriptor)
close(547) = -1 EBADF (Bad file descriptor)
close(546) = -1 EBADF (Bad file descriptor)
close(545) = -1 EBADF (Bad file descriptor)
close(544) = -1 EBADF (Bad file descriptor)
close(543) = -1 EBADF (Bad file descriptor)
close(542) = -1 EBADF (Bad file descriptor)
close(541) = -1 EBADF (Bad file descriptor)
close(540) = -1 EBADF (Bad file descriptor)
close(539) = -1 EBADF (Bad file descriptor)
close(538) = -1 EBADF (Bad file descriptor)
close(537) = -1 EBADF (Bad file descriptor)
close(536) = -1 EBADF (Bad file descriptor)
close(535) = -1 EBADF (Bad file descriptor)
close(534) = -1 EBADF (Bad file descriptor)
close(533) = -1 EBADF (Bad file descriptor)
close(532) = -1 EBADF (Bad file descriptor)
close(531) = -1 EBADF (Bad file descriptor)
close(530) = -1 EBADF (Bad file descriptor)
close(529) = -1 EBADF (Bad file descriptor)
close(528) = -1 EBADF (Bad file descriptor)
close(527) = -1 EBADF (Bad file descriptor)
close(526) = -1 EBADF (Bad file descriptor)
close(525) = -1 EBADF (Bad file descriptor)
close(524) = -1 EBADF (Bad file descriptor)
close(523) = -1 EBADF (Bad file descriptor)
close(522) = -1 EBADF (Bad file descriptor)
close(521) = -1 EBADF (Bad file descriptor)
close(520) = -1 EBADF (Bad file descriptor)
close(519) = -1 EBADF (Bad file descriptor)
close(518) = -1 EBADF (Bad file descriptor)
close(517) = -1 EBADF (Bad file descriptor)
close(516) = -1 EBADF (Bad file descriptor)
close(515) = -1 EBADF (Bad file descriptor)
close(514) = -1 EBADF (Bad file descriptor)
close(513) = -1 EBADF (Bad file descriptor)
close(512) = -1 EBADF (Bad file descriptor)
close(511) = -1 EBADF (Bad file descriptor)
close(510) = -1 EBADF (Bad file descriptor)
close(509) = -1 EBADF (Bad file descriptor)
close(508) = -1 EBADF (Bad file descriptor)
close(507) = -1 EBADF (Bad file descriptor)
close(506) = -1 EBADF (Bad file descriptor)
close(505) = -1 EBADF (Bad file descriptor)
close(504) = -1 EBADF (Bad file descriptor)
close(503) = -1 EBADF (Bad file descriptor)
close(502) = -1 EBADF (Bad file descriptor)
close(501) = -1 EBADF (Bad file descriptor)
close(500) = -1 EBADF (Bad file descriptor)
close(499) = -1 EBADF (Bad file descriptor)
close(498) = -1 EBADF (Bad file descriptor)
close(497) = -1 EBADF (Bad file descriptor)
close(496) = -1 EBADF (Bad file descriptor)
close(495) = -1 EBADF (Bad file descriptor)
close(494) = -1 EBADF (Bad file descriptor)
close(493) = -1 EBADF (Bad file descriptor)
close(492) = -1 EBADF (Bad file descriptor)
close(491) = -1 EBADF (Bad file descriptor)
close(490) = -1 EBADF (Bad file descriptor)
close(489) = -1 EBADF (Bad file descriptor)
close(488) = -1 EBADF (Bad file descriptor)
close(487) = -1 EBADF (Bad file descriptor)
close(486) = -1 EBADF (Bad file descriptor)
close(485) = -1 EBADF (Bad file descriptor)
close(484) = -1 EBADF (Bad file descriptor)
close(483) = -1 EBADF (Bad file descriptor)
close(482) = -1 EBADF (Bad file descriptor)
close(481) = -1 EBADF (Bad file descriptor)
close(480) = -1 EBADF (Bad file descriptor)
close(479) = -1 EBADF (Bad file descriptor)
close(478) = -1 EBADF (Bad file descriptor)
close(477) = -1 EBADF (Bad file descriptor)
close(476) = -1 EBADF (Bad file descriptor)
close(475) = -1 EBADF (Bad file descriptor)
close(474) = -1 EBADF (Bad file descriptor)
close(473) = -1 EBADF (Bad file descriptor)
close(472) = -1 EBADF (Bad file descriptor)
close(471) = -1 EBADF (Bad file descriptor)
close(470) = -1 EBADF (Bad file descriptor)
close(469) = -1 EBADF (Bad file descriptor)
close(468) = -1 EBADF (Bad file descriptor)
close(467) = -1 EBADF (Bad file descriptor)
close(466) = -1 EBADF (Bad file descriptor)
close(465) = -1 EBADF (Bad file descriptor)
close(464) = -1 EBADF (Bad file descriptor)
close(463) = -1 EBADF (Bad file descriptor)
close(462) = -1 EBADF (Bad file descriptor)
close(461) = -1 EBADF (Bad file descriptor)
close(460) = -1 EBADF (Bad file descriptor)
close(459) = -1 EBADF (Bad file descriptor)
close(458) = -1 EBADF (Bad file descriptor)
close(457) = -1 EBADF (Bad file descriptor)
close(456) = -1 EBADF (Bad file descriptor)
close(455) = -1 EBADF (Bad file descriptor)
close(454) = -1 EBADF (Bad file descriptor)
close(453) = -1 EBADF (Bad file descriptor)
close(452) = -1 EBADF (Bad file descriptor)
close(451) = -1 EBADF (Bad file descriptor)
close(450) = -1 EBADF (Bad file descriptor)
close(449) = -1 EBADF (Bad file descriptor)
close(448) = -1 EBADF (Bad file descriptor)
close(447) = -1 EBADF (Bad file descriptor)
close(446) = -1 EBADF (Bad file descriptor)
close(445) = -1 EBADF (Bad file descriptor)
close(444) = -1 EBADF (Bad file descriptor)
close(443) = -1 EBADF (Bad file descriptor)
close(442) = -1 EBADF (Bad file descriptor)
close(441) = -1 EBADF (Bad file descriptor)
close(440) = -1 EBADF (Bad file descriptor)
close(439) = -1 EBADF (Bad file descriptor)
close(438) = -1 EBADF (Bad file descriptor)
close(437) = -1 EBADF (Bad file descriptor)
close(436) = -1 EBADF (Bad file descriptor)
close(435) = -1 EBADF (Bad file descriptor)
close(434) = -1 EBADF (Bad file descriptor)
close(433) = -1 EBADF (Bad file descriptor)
close(432) = -1 EBADF (Bad file descriptor)
close(431) = -1 EBADF (Bad file descriptor)
close(430) = -1 EBADF (Bad file descriptor)
close(429) = -1 EBADF (Bad file descriptor)
close(428) = -1 EBADF (Bad file descriptor)
close(427) = -1 EBADF (Bad file descriptor)
close(426) = -1 EBADF (Bad file descriptor)
close(425) = -1 EBADF (Bad file descriptor)
close(424) = -1 EBADF (Bad file descriptor)
close(423) = -1 EBADF (Bad file descriptor)
close(422) = -1 EBADF (Bad file descriptor)
close(421) = -1 EBADF (Bad file descriptor)
close(420) = -1 EBADF (Bad file descriptor)
close(419) = -1 EBADF (Bad file descriptor)
close(418) = -1 EBADF (Bad file descriptor)
close(417) = -1 EBADF (Bad file descriptor)
close(416) = -1 EBADF (Bad file descriptor)
close(415) = -1 EBADF (Bad file descriptor)
close(414) = -1 EBADF (Bad file descriptor)
close(413) = -1 EBADF (Bad file descriptor)
close(412) = -1 EBADF (Bad file descriptor)
close(411) = -1 EBADF (Bad file descriptor)
close(410) = -1 EBADF (Bad file descriptor)
close(409) = -1 EBADF (Bad file descriptor)
close(408) = -1 EBADF (Bad file descriptor)
close(407) = -1 EBADF (Bad file descriptor)
close(406) = -1 EBADF (Bad file descriptor)
close(405) = -1 EBADF (Bad file descriptor)
close(404) = -1 EBADF (Bad file descriptor)
close(403) = -1 EBADF (Bad file descriptor)
close(402) = -1 EBADF (Bad file descriptor)
close(401) = -1 EBADF (Bad file descriptor)
close(400) = -1 EBADF (Bad file descriptor)
close(399) = -1 EBADF (Bad file descriptor)
close(398) = -1 EBADF (Bad file descriptor)
close(397) = -1 EBADF (Bad file descriptor)
close(396) = -1 EBADF (Bad file descriptor)
close(395) = -1 EBADF (Bad file descriptor)
close(394) = -1 EBADF (Bad file descriptor)
close(393) = -1 EBADF (Bad file descriptor)
close(392) = -1 EBADF (Bad file descriptor)
close(391) = -1 EBADF (Bad file descriptor)
close(390) = -1 EBADF (Bad file descriptor)
close(389) = -1 EBADF (Bad file descriptor)
close(388) = -1 EBADF (Bad file descriptor)
close(387) = -1 EBADF (Bad file descriptor)
close(386) = -1 EBADF (Bad file descriptor)
close(385) = -1 EBADF (Bad file descriptor)
close(384) = -1 EBADF (Bad file descriptor)
close(383) = -1 EBADF (Bad file descriptor)
close(382) = -1 EBADF (Bad file descriptor)
close(381) = -1 EBADF (Bad file descriptor)
close(380) = -1 EBADF (Bad file descriptor)
close(379) = -1 EBADF (Bad file descriptor)
close(378) = -1 EBADF (Bad file descriptor)
close(377) = -1 EBADF (Bad file descriptor)
close(376) = -1 EBADF (Bad file descriptor)
close(375) = -1 EBADF (Bad file descriptor)
close(374) = -1 EBADF (Bad file descriptor)
close(373) = -1 EBADF (Bad file descriptor)
close(372) = -1 EBADF (Bad file descriptor)
close(371) = -1 EBADF (Bad file descriptor)
close(370) = -1 EBADF (Bad file descriptor)
close(369) = -1 EBADF (Bad file descriptor)
close(368) = -1 EBADF (Bad file descriptor)
close(367) = -1 EBADF (Bad file descriptor)
close(366) = -1 EBADF (Bad file descriptor)
close(365) = -1 EBADF (Bad file descriptor)
close(364) = -1 EBADF (Bad file descriptor)
close(363) = -1 EBADF (Bad file descriptor)
close(362) = -1 EBADF (Bad file descriptor)
close(361) = -1 EBADF (Bad file descriptor)
close(360) = -1 EBADF (Bad file descriptor)
close(359) = -1 EBADF (Bad file descriptor)
close(358) = -1 EBADF (Bad file descriptor)
close(357) = -1 EBADF (Bad file descriptor)
close(356) = -1 EBADF (Bad file descriptor)
close(355) = -1 EBADF (Bad file descriptor)
close(354) = -1 EBADF (Bad file descriptor)
close(353) = -1 EBADF (Bad file descriptor)
close(352) = -1 EBADF (Bad file descriptor)
close(351) = -1 EBADF (Bad file descriptor)
close(350) = -1 EBADF (Bad file descriptor)
close(349) = -1 EBADF (Bad file descriptor)
close(348) = -1 EBADF (Bad file descriptor)
close(347) = -1 EBADF (Bad file descriptor)
close(346) = -1 EBADF (Bad file descriptor)
close(345) = -1 EBADF (Bad file descriptor)
close(344) = -1 EBADF (Bad file descriptor)
close(343) = -1 EBADF (Bad file descriptor)
close(342) = -1 EBADF (Bad file descriptor)
close(341) = -1 EBADF (Bad file descriptor)
close(340) = -1 EBADF (Bad file descriptor)
close(339) = -1 EBADF (Bad file descriptor)
close(338) = -1 EBADF (Bad file descriptor)
close(337) = -1 EBADF (Bad file descriptor)
close(336) = -1 EBADF (Bad file descriptor)
close(335) = -1 EBADF (Bad file descriptor)
close(334) = -1 EBADF (Bad file descriptor)
close(333) = -1 EBADF (Bad file descriptor)
close(332) = -1 EBADF (Bad file descriptor)
close(331) = -1 EBADF (Bad file descriptor)
close(330) = -1 EBADF (Bad file descriptor)
close(329) = -1 EBADF (Bad file descriptor)
close(328) = -1 EBADF (Bad file descriptor)
close(327) = -1 EBADF (Bad file descriptor)
close(326) = -1 EBADF (Bad file descriptor)
close(325) = -1 EBADF (Bad file descriptor)
close(324) = -1 EBADF (Bad file descriptor)
close(323) = -1 EBADF (Bad file descriptor)
close(322) = -1 EBADF (Bad file descriptor)
close(321) = -1 EBADF (Bad file descriptor)
close(320) = -1 EBADF (Bad file descriptor)
close(319) = -1 EBADF (Bad file descriptor)
close(318) = -1 EBADF (Bad file descriptor)
close(317) = -1 EBADF (Bad file descriptor)
close(316) = -1 EBADF (Bad file descriptor)
close(315) = -1 EBADF (Bad file descriptor)
close(314) = -1 EBADF (Bad file descriptor)
close(313) = -1 EBADF (Bad file descriptor)
close(312) = -1 EBADF (Bad file descriptor)
close(311) = -1 EBADF (Bad file descriptor)
close(310) = -1 EBADF (Bad file descriptor)
close(309) = -1 EBADF (Bad file descriptor)
close(308) = -1 EBADF (Bad file descriptor)
close(307) = -1 EBADF (Bad file descriptor)
close(306) = -1 EBADF (Bad file descriptor)
close(305) = -1 EBADF (Bad file descriptor)
close(304) = -1 EBADF (Bad file descriptor)
close(303) = -1 EBADF (Bad file descriptor)
close(302) = -1 EBADF (Bad file descriptor)
close(301) = -1 EBADF (Bad file descriptor)
close(300) = -1 EBADF (Bad file descriptor)
close(299) = -1 EBADF (Bad file descriptor)
close(298) = -1 EBADF (Bad file descriptor)
close(297) = -1 EBADF (Bad file descriptor)
close(296) = -1 EBADF (Bad file descriptor)
close(295) = -1 EBADF (Bad file descriptor)
close(294) = -1 EBADF (Bad file descriptor)
close(293) = -1 EBADF (Bad file descriptor)
close(292) = -1 EBADF (Bad file descriptor)
close(291) = -1 EBADF (Bad file descriptor)
close(290) = -1 EBADF (Bad file descriptor)
close(289) = -1 EBADF (Bad file descriptor)
close(288) = -1 EBADF (Bad file descriptor)
close(287) = -1 EBADF (Bad file descriptor)
close(286) = -1 EBADF (Bad file descriptor)
close(285) = -1 EBADF (Bad file descriptor)
close(284) = -1 EBADF (Bad file descriptor)
close(283) = -1 EBADF (Bad file descriptor)
close(282) = -1 EBADF (Bad file descriptor)
close(281) = -1 EBADF (Bad file descriptor)
close(280) = -1 EBADF (Bad file descriptor)
close(279) = -1 EBADF (Bad file descriptor)
close(278) = -1 EBADF (Bad file descriptor)
close(277) = -1 EBADF (Bad file descriptor)
close(276) = -1 EBADF (Bad file descriptor)
close(275) = -1 EBADF (Bad file descriptor)
close(274) = -1 EBADF (Bad file descriptor)
close(273) = -1 EBADF (Bad file descriptor)
close(272) = -1 EBADF (Bad file descriptor)
close(271) = -1 EBADF (Bad file descriptor)
close(270) = -1 EBADF (Bad file descriptor)
close(269) = -1 EBADF (Bad file descriptor)
close(268) = -1 EBADF (Bad file descriptor)
close(267) = -1 EBADF (Bad file descriptor)
close(266) = -1 EBADF (Bad file descriptor)
close(265) = -1 EBADF (Bad file descriptor)
close(264) = -1 EBADF (Bad file descriptor)
close(263) = -1 EBADF (Bad file descriptor)
close(262) = -1 EBADF (Bad file descriptor)
close(261) = -1 EBADF (Bad file descriptor)
close(260) = -1 EBADF (Bad file descriptor)
close(259) = -1 EBADF (Bad file descriptor)
close(258) = -1 EBADF (Bad file descriptor)
close(257) = -1 EBADF (Bad file descriptor)
close(256) = -1 EBADF (Bad file descriptor)
close(255) = -1 EBADF (Bad file descriptor)
close(254) = -1 EBADF (Bad file descriptor)
close(253) = -1 EBADF (Bad file descriptor)
close(252) = -1 EBADF (Bad file descriptor)
close(251) = -1 EBADF (Bad file descriptor)
close(250) = -1 EBADF (Bad file descriptor)
close(249) = -1 EBADF (Bad file descriptor)
close(248) = -1 EBADF (Bad file descriptor)
close(247) = -1 EBADF (Bad file descriptor)
close(246) = -1 EBADF (Bad file descriptor)
close(245) = -1 EBADF (Bad file descriptor)
close(244) = -1 EBADF (Bad file descriptor)
close(243) = -1 EBADF (Bad file descriptor)
close(242) = -1 EBADF (Bad file descriptor)
close(241) = -1 EBADF (Bad file descriptor)
close(240) = -1 EBADF (Bad file descriptor)
close(239) = -1 EBADF (Bad file descriptor)
close(238) = -1 EBADF (Bad file descriptor)
close(237) = -1 EBADF (Bad file descriptor)
close(236) = -1 EBADF (Bad file descriptor)
close(235) = -1 EBADF (Bad file descriptor)
close(234) = -1 EBADF (Bad file descriptor)
close(233) = -1 EBADF (Bad file descriptor)
close(232) = -1 EBADF (Bad file descriptor)
close(231) = -1 EBADF (Bad file descriptor)
close(230) = -1 EBADF (Bad file descriptor)
close(229) = -1 EBADF (Bad file descriptor)
close(228) = -1 EBADF (Bad file descriptor)
close(227) = -1 EBADF (Bad file descriptor)
close(226) = -1 EBADF (Bad file descriptor)
close(225) = -1 EBADF (Bad file descriptor)
close(224) = -1 EBADF (Bad file descriptor)
close(223) = -1 EBADF (Bad file descriptor)
close(222) = -1 EBADF (Bad file descriptor)
close(221) = -1 EBADF (Bad file descriptor)
close(220) = -1 EBADF (Bad file descriptor)
close(219) = -1 EBADF (Bad file descriptor)
close(218) = -1 EBADF (Bad file descriptor)
close(217) = -1 EBADF (Bad file descriptor)
close(216) = -1 EBADF (Bad file descriptor)
close(215) = -1 EBADF (Bad file descriptor)
close(214) = -1 EBADF (Bad file descriptor)
close(213) = -1 EBADF (Bad file descriptor)
close(212) = -1 EBADF (Bad file descriptor)
close(211) = -1 EBADF (Bad file descriptor)
close(210) = -1 EBADF (Bad file descriptor)
close(209) = -1 EBADF (Bad file descriptor)
close(208) = -1 EBADF (Bad file descriptor)
close(207) = -1 EBADF (Bad file descriptor)
close(206) = -1 EBADF (Bad file descriptor)
close(205) = -1 EBADF (Bad file descriptor)
close(204) = -1 EBADF (Bad file descriptor)
close(203) = -1 EBADF (Bad file descriptor)
close(202) = -1 EBADF (Bad file descriptor)
close(201) = -1 EBADF (Bad file descriptor)
close(200) = -1 EBADF (Bad file descriptor)
close(199) = -1 EBADF (Bad file descriptor)
close(198) = -1 EBADF (Bad file descriptor)
close(197) = -1 EBADF (Bad file descriptor)
close(196) = -1 EBADF (Bad file descriptor)
close(195) = -1 EBADF (Bad file descriptor)
close(194) = -1 EBADF (Bad file descriptor)
close(193) = -1 EBADF (Bad file descriptor)
close(192) = -1 EBADF (Bad file descriptor)
close(191) = -1 EBADF (Bad file descriptor)
close(190) = -1 EBADF (Bad file descriptor)
close(189) = -1 EBADF (Bad file descriptor)
close(188) = -1 EBADF (Bad file descriptor)
close(187) = -1 EBADF (Bad file descriptor)
close(186) = -1 EBADF (Bad file descriptor)
close(185) = -1 EBADF (Bad file descriptor)
close(184) = -1 EBADF (Bad file descriptor)
close(183) = -1 EBADF (Bad file descriptor)
close(182) = -1 EBADF (Bad file descriptor)
close(181) = -1 EBADF (Bad file descriptor)
close(180) = -1 EBADF (Bad file descriptor)
close(179) = -1 EBADF (Bad file descriptor)
close(178) = -1 EBADF (Bad file descriptor)
close(177) = -1 EBADF (Bad file descriptor)
close(176) = -1 EBADF (Bad file descriptor)
close(175) = -1 EBADF (Bad file descriptor)
close(174) = -1 EBADF (Bad file descriptor)
close(173) = -1 EBADF (Bad file descriptor)
close(172) = -1 EBADF (Bad file descriptor)
close(171) = -1 EBADF (Bad file descriptor)
close(170) = -1 EBADF (Bad file descriptor)
close(169) = -1 EBADF (Bad file descriptor)
close(168) = -1 EBADF (Bad file descriptor)
close(167) = -1 EBADF (Bad file descriptor)
close(166) = -1 EBADF (Bad file descriptor)
close(165) = -1 EBADF (Bad file descriptor)
close(164) = -1 EBADF (Bad file descriptor)
close(163) = -1 EBADF (Bad file descriptor)
close(162) = -1 EBADF (Bad file descriptor)
close(161) = -1 EBADF (Bad file descriptor)
close(160) = -1 EBADF (Bad file descriptor)
close(159) = -1 EBADF (Bad file descriptor)
close(158) = -1 EBADF (Bad file descriptor)
close(157) = -1 EBADF (Bad file descriptor)
close(156) = -1 EBADF (Bad file descriptor)
close(155) = -1 EBADF (Bad file descriptor)
close(154) = -1 EBADF (Bad file descriptor)
close(153) = -1 EBADF (Bad file descriptor)
close(152) = -1 EBADF (Bad file descriptor)
close(151) = -1 EBADF (Bad file descriptor)
close(150) = -1 EBADF (Bad file descriptor)
close(149) = -1 EBADF (Bad file descriptor)
close(148) = -1 EBADF (Bad file descriptor)
close(147) = -1 EBADF (Bad file descriptor)
close(146) = -1 EBADF (Bad file descriptor)
close(145) = -1 EBADF (Bad file descriptor)
close(144) = -1 EBADF (Bad file descriptor)
close(143) = -1 EBADF (Bad file descriptor)
close(142) = -1 EBADF (Bad file descriptor)
close(141) = -1 EBADF (Bad file descriptor)
close(140) = -1 EBADF (Bad file descriptor)
close(139) = -1 EBADF (Bad file descriptor)
close(138) = -1 EBADF (Bad file descriptor)
close(137) = -1 EBADF (Bad file descriptor)
close(136) = -1 EBADF (Bad file descriptor)
close(135) = -1 EBADF (Bad file descriptor)
close(134) = -1 EBADF (Bad file descriptor)
close(133) = -1 EBADF (Bad file descriptor)
close(132) = -1 EBADF (Bad file descriptor)
close(131) = -1 EBADF (Bad file descriptor)
close(130) = -1 EBADF (Bad file descriptor)
close(129) = -1 EBADF (Bad file descriptor)
close(128) = -1 EBADF (Bad file descriptor)
close(127) = -1 EBADF (Bad file descriptor)
close(126) = -1 EBADF (Bad file descriptor)
close(125) = -1 EBADF (Bad file descriptor)
close(124) = -1 EBADF (Bad file descriptor)
close(123) = -1 EBADF (Bad file descriptor)
close(122) = -1 EBADF (Bad file descriptor)
close(121) = -1 EBADF (Bad file descriptor)
close(120) = -1 EBADF (Bad file descriptor)
close(119) = -1 EBADF (Bad file descriptor)
close(118) = -1 EBADF (Bad file descriptor)
close(117) = -1 EBADF (Bad file descriptor)
close(116) = -1 EBADF (Bad file descriptor)
close(115) = -1 EBADF (Bad file descriptor)
close(114) = -1 EBADF (Bad file descriptor)
close(113) = -1 EBADF (Bad file descriptor)
close(112) = -1 EBADF (Bad file descriptor)
close(111) = -1 EBADF (Bad file descriptor)
close(110) = -1 EBADF (Bad file descriptor)
close(109) = -1 EBADF (Bad file descriptor)
close(108) = -1 EBADF (Bad file descriptor)
close(107) = -1 EBADF (Bad file descriptor)
close(106) = -1 EBADF (Bad file descriptor)
close(105) = -1 EBADF (Bad file descriptor)
close(104) = -1 EBADF (Bad file descriptor)
close(103) = -1 EBADF (Bad file descriptor)
close(102) = -1 EBADF (Bad file descriptor)
close(101) = -1 EBADF (Bad file descriptor)
close(100) = -1 EBADF (Bad file descriptor)
close(99) = -1 EBADF (Bad file descriptor)
close(98) = -1 EBADF (Bad file descriptor)
close(97) = -1 EBADF (Bad file descriptor)
close(96) = -1 EBADF (Bad file descriptor)
close(95) = -1 EBADF (Bad file descriptor)
close(94) = -1 EBADF (Bad file descriptor)
close(93) = -1 EBADF (Bad file descriptor)
close(92) = -1 EBADF (Bad file descriptor)
close(91) = -1 EBADF (Bad file descriptor)
close(90) = -1 EBADF (Bad file descriptor)
close(89) = -1 EBADF (Bad file descriptor)
close(88) = -1 EBADF (Bad file descriptor)
close(87) = -1 EBADF (Bad file descriptor)
close(86) = -1 EBADF (Bad file descriptor)
close(85) = -1 EBADF (Bad file descriptor)
close(84) = -1 EBADF (Bad file descriptor)
close(83) = -1 EBADF (Bad file descriptor)
close(82) = -1 EBADF (Bad file descriptor)
close(81) = -1 EBADF (Bad file descriptor)
close(80) = -1 EBADF (Bad file descriptor)
close(79) = -1 EBADF (Bad file descriptor)
close(78) = -1 EBADF (Bad file descriptor)
close(77) = -1 EBADF (Bad file descriptor)
close(76) = -1 EBADF (Bad file descriptor)
close(75) = -1 EBADF (Bad file descriptor)
close(74) = -1 EBADF (Bad file descriptor)
close(73) = -1 EBADF (Bad file descriptor)
close(72) = -1 EBADF (Bad file descriptor)
close(71) = -1 EBADF (Bad file descriptor)
close(70) = -1 EBADF (Bad file descriptor)
close(69) = -1 EBADF (Bad file descriptor)
close(68) = -1 EBADF (Bad file descriptor)
close(67) = -1 EBADF (Bad file descriptor)
close(66) = -1 EBADF (Bad file descriptor)
close(65) = -1 EBADF (Bad file descriptor)
close(64) = -1 EBADF (Bad file descriptor)
close(63) = -1 EBADF (Bad file descriptor)
close(62) = -1 EBADF (Bad file descriptor)
close(61) = -1 EBADF (Bad file descriptor)
close(60) = -1 EBADF (Bad file descriptor)
close(59) = -1 EBADF (Bad file descriptor)
close(58) = -1 EBADF (Bad file descriptor)
close(57) = -1 EBADF (Bad file descriptor)
close(56) = -1 EBADF (Bad file descriptor)
close(55) = -1 EBADF (Bad file descriptor)
close(54) = -1 EBADF (Bad file descriptor)
close(53) = -1 EBADF (Bad file descriptor)
close(52) = -1 EBADF (Bad file descriptor)
close(51) = -1 EBADF (Bad file descriptor)
close(50) = -1 EBADF (Bad file descriptor)
close(49) = -1 EBADF (Bad file descriptor)
close(48) = -1 EBADF (Bad file descriptor)
close(47) = -1 EBADF (Bad file descriptor)
close(46) = -1 EBADF (Bad file descriptor)
close(45) = -1 EBADF (Bad file descriptor)
close(44) = -1 EBADF (Bad file descriptor)
close(43) = -1 EBADF (Bad file descriptor)
close(42) = -1 EBADF (Bad file descriptor)
close(41) = -1 EBADF (Bad file descriptor)
close(40) = -1 EBADF (Bad file descriptor)
close(39) = -1 EBADF (Bad file descriptor)
close(38) = -1 EBADF (Bad file descriptor)
close(37) = -1 EBADF (Bad file descriptor)
close(36) = -1 EBADF (Bad file descriptor)
close(35) = -1 EBADF (Bad file descriptor)
close(34) = -1 EBADF (Bad file descriptor)
close(33) = -1 EBADF (Bad file descriptor)
close(32) = -1 EBADF (Bad file descriptor)
close(31) = -1 EBADF (Bad file descriptor)
close(30) = -1 EBADF (Bad file descriptor)
close(29) = -1 EBADF (Bad file descriptor)
close(28) = -1 EBADF (Bad file descriptor)
close(27) = -1 EBADF (Bad file descriptor)
close(26) = -1 EBADF (Bad file descriptor)
close(25) = -1 EBADF (Bad file descriptor)
close(24) = -1 EBADF (Bad file descriptor)
close(23) = -1 EBADF (Bad file descriptor)
close(22) = -1 EBADF (Bad file descriptor)
close(21) = -1 EBADF (Bad file descriptor)
close(20) = -1 EBADF (Bad file descriptor)
close(19) = -1 EBADF (Bad file descriptor)
close(18) = -1 EBADF (Bad file descriptor)
close(17) = -1 EBADF (Bad file descriptor)
close(16) = -1 EBADF (Bad file descriptor)
close(15) = -1 EBADF (Bad file descriptor)
close(14) = -1 EBADF (Bad file descriptor)
close(13) = -1 EBADF (Bad file descriptor)
close(12) = -1 EBADF (Bad file descriptor)
close(11) = -1 EBADF (Bad file descriptor)
close(10) = -1 EBADF (Bad file descriptor)
close(9) = -1 EBADF (Bad file descriptor)
close(8) = -1 EBADF (Bad file descriptor)
close(7) = -1 EBADF (Bad file descriptor)
close(6) = -1 EBADF (Bad file descriptor)
close(5) = -1 EBADF (Bad file descriptor)
close(4) = -1 EBADF (Bad file descriptor)
close(3) = -1 EBADF (Bad file descriptor)
brk(0) = 0x80a7000
brk(0x80c8000) = 0x80c8000
getuid32() = 500
getgid32() = 502
geteuid32() = 500
getegid32() = 502
rt_sigaction(SIGXFSZ, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGPIPE, {SIG_IGN}, {SIG_DFL}, 8) = 0
access("/home/sav/.nethackrc", F_OK) = -1 ENOENT (No such file or directory)
ioctl(0, SNDCTL_TMR_TIMEBASE or TCGETS, {B38400 opost isig icanon echo ...}) = 0
readlink("/proc/self/fd/0", 0x80a71b8, 4095) = -1 EACCES (Permission denied)
fstat64(0, {st_mode=S_IFCHR|0620, st_rdev=makedev(3, 1), ...}) = 0
stat64("/dev/pts", 0xbfffe178) = -1 ENOENT (No such file or directory)
open("/dev", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = 3
fstat64(3, {st_mode=S_IFDIR|0755, st_size=1024, ...}) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
getdents64(3, /* 55 entries */, 4096) = 1632
stat64("/dev/ttyp1", {st_mode=S_IFCHR|0620, st_rdev=makedev(3, 1), ...}) = 0
close(3) = 0
open("/var/run/utmp", O_RDONLY) = 3
read(3, "\10\0\0\0\201o\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
read(3, "\2\0\0\0\0\0\0\0~\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
read(3, "\1\0\0\0003N\0\0~\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
read(3, "\10\0\0\0Ct\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
read(3, "\10\0\0\0\201\177\0\0ttyp0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
read(3, "\7\0\0\0f?\0\0ttyp1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 384) = 384
close(3) = 0
socket(PF_FILE, SOCK_STREAM, 0) = 3
fcntl64(3, F_GETFL) = 0x2 (flags O_RDWR)
fcntl64(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0
connect(3, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
close(3) = 0
close(3) = 0
open("/etc/nsswitch.conf", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=1696, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4001c000
read(3, "#\n# /etc/nsswitch.conf\n#\n# An ex"..., 1024) = 1024
read(3, "es\nshadow: files\ngroup: "..., 1024) = 672
read(3, "", 1024) = 0
close(3) = 0
munmap(0x4001c000, 4096) = 0
close(3) = 0
open("/lib/libnss_files.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 \33\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=46552, ...}) = 0
old_mmap(NULL, 41616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x401e4000
old_mmap(0x401ed000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x401ed000
close(3) = 0
mprotect(0x401ed000, 4096, PROT_READ) = 0
open("/etc/passwd", O_RDONLY) = 3
fcntl64(3, F_GETFD) = 0
fstat64(3, {st_mode=S_IFREG|0644, st_size=1243, ...}) = 0
read(3, "root:x:0:0:root:/root:/bin/bash\n"..., 4096) = 1243
close(3) = 0
open("/etc/shadow", O_RDONLY) = -1 EACCES (Permission denied)
stat64("/dev/pts", 0xbfffe318) = -1 ENOENT (No such file or directory)
close(3) = 0
geteuid32() = 500
getegid32() = 502
open("/dev/ttyp1", O_RDWR|O_NONBLOCK) = 3
geteuid32() = 500
getegid32() = 502
close(3) = 0
umask(0) = 02
lstat64("/var/run/screen", {st_mode=S_IFDIR|0775, st_size=1024, ...}) = 0
fstat64(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(3, 1), ...}) = 0
ioctl(1, SNDCTL_TMR_TIMEBASE or TCGETS, {B38400 opost isig icanon echo ...}) = 0
write(1, "Directory \'/var/run/screen\' must"..., 49Directory '/var/run/screen' must have mode 777.
) = 49
exit_group(1) = ?
Process 29703 detached
