Samba und NTFS Platte
Diskutiere Samba und NTFS Platte im Samba Forum im Bereich Netzwerke & Serverdienste; hi hab eine ntfs platte im rechner und möchte sie per sambsa sharen. Ich krieg jedesmal ein zugriff verweigert -> fstab eintrag: /dev/hdd1...
  1. Aracon
    Aracon Routinier
    12.10.2003
    438
    fstab eintrag: /dev/hdd1 /mnt/data ntfs auto,users,exec,ro,umask=000 0 0
    smb.conf
    # This is the main Samba configuration file. You should read the
    # smb.conf(5) manual page in order to understand the options listed
    # here. Samba has a huge number of configurable options (perhaps too
    # many!) most of which are not shown in this example
    # Any line which starts with a ; (semi-colon) or a # (hash)
    # is a comment and is ignored. In this example we will use a #
    # for commentry and a ; for parts of the config file that you
    # may wish to enable
    # NOTE: Whenever you modify this file you should run the command "testparm"
    # to check that you have not made any basic syntactic errors.
    #======================= Global Settings =====================================
    [global]
    log file = /var/log/samba3/log.%m
    load printers = yes
    smb passwd file = /etc/samba/private/smbpasswd
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    map to guest = bad user
    encrypt passwords = yes
    printer admin = @adm
    dns proxy = no
    netbios name = Server
    printing = cups
    server string = Samba Server %v
    workgroup = ARBEITSGRUPPE
    os level = 20
    printcap name = cups
    security = user
    max log size = 50
    [printers]
    comment = All Printers
    path = /var/spool/samba
    browseable = no
    # to allow user 'guest account' to print.
    guest ok = yes
    writable = no
    printable = yes
    create mode = 0700
    # print command: see above for details.
    print command = lpr-cups -P %p -o raw %s -r # using client side printer drivers.
    ; print command = lpr-cups -P %p %s # using cups own drivers (use generic PostScript on clients).
    # The following two commands are the samba defaults for printing=cups
    # change them only if you need different options:
    ; lpq command = lpq -P %p
    ; lprm command = cancel %p-%j
    # This share is used for Windows NT-style point-and-print support.
    # To be able to install drivers, you need to be either root, or listed
    # in the printer admin parameter above. Note that you also need write access
    # to the directory and share definition to be able to upload the drivers.
    # For more information on this, please see the Printing Support Section of
    # /usr/share/doc/samba-<version>/Samba-HOWTO-Collection.pdf
    [print$]
    path = /var/lib/samba/printers
    browseable = yes
    read only = yes
    write list = @adm root
    guest ok = yes
    # This one is useful for people to share files
    ;[tmp]
    ; comment = Temporary file space
    ; path = /tmp
    ; read only = no
    ; public = yes
    # A publicly accessible directory, but read only, except for people in
    # the "staff" group
    ;[public]
    ; comment = Public Stuff
    ; path = /home/samba/public
    ; public = yes
    ; writable = no
    ; write list = @staff
    # Audited directory through experimental VFS audit.so module:
    # Uncomment next line.
    ; vfs object = /usr/lib/samba/vfs/audit.so
    # Other examples.
    # A private printer, usable only by Fred. Spool data will be placed in Fred's
    # home directory. Note that fred must have write access to the spool directory,
    # wherever it is.
    ;[fredsprn]
    ; comment = Fred's Printer
    ; valid users = fred
    ; path = /homes/fred
    ; printer = freds_printer
    ; public = no
    ; writable = no
    ; printable = yes
    # A private directory, usable only by Fred. Note that Fred requires write
    # access to the directory.
    ;[fredsdir]
    ; comment = Fred's Service
    ; path = /usr/somewhere/private
    ; public = no
    ; writable = yes
    ; printable = no
    # a service which has a different directory for each machine that connects
    # this allows you to tailor configurations to incoming machines. You could
    # also use the %u option to tailor it by user name.
    # The %m gets replaced with the machine name that is connecting.
    ;[pchome]
    ; comment = PC Directories
    ; path = /usr/pc/%m
    ; public = no
    ; writable = yes
    # A publicly accessible directory, read/write to all users. Note that all files
    # created in the directory by users will be owned by the default user, so
    # any user with access can delete any other user's files. Obviously this
    # directory must be writable by the default user. Another user could of course
    # be specified, in which case all files would be owned by that user instead.
    ;[public]
    ; path = /usr/somewhere/else/public
    ; public = yes
    ; only guest = yes
    ; writable = yes
    ; printable = no
    # The following two entries demonstrate how to share a directory so that two
    # users can place files there that will be owned by the specific users. In this
    # setup, the directory should be writable by both users and should have the
    # sticky bit set on it to prevent abuse. Obviously this could be extended to
    # as many users as required.
    ;[myshare]
    ; comment = Mary's and Fred's stuff
    ; path = /usr/somewhere/shared
    ; valid users = mary fred
    ; public = no
    ; writable = yes
    ; printable = no
    ; create mask = 0765
    [Data]
    guest only = yes
    public = yes
    path = /mnt/data
    Ich möchte als gast rein. Könnt ihr mir helfen
  3. khs
    khs Routinier
    19.08.2004
    408
    Was steht denn in log.smb?
    Du kannst es auch mal mit security=share probieren. Dank "map to guest=bad user" sollte es eigentlich auf Anhieb klappen...
    -khs
  4. dalex
    dalex Tripel-As
    28.10.2003
    175
    Augsburg
    Moment,
    habe ich das richtig verstanden. Du hast im deinem Linux Rechner eine Platte mit NTFS hängen und willst eine NTFS-Platte unter Linux freigeben.
    Geht das Überhaupt?
    Zum freigeben von Windows-Partitionen, brauchts du doch (imho) Windows. Ich glaube nicht,das du das unter Linux hinkriegst.
    Gruß dalex
  5. #4 theborg, 30.08.2004
    theborg
    06.08.2004
    688
    Hamburg
    eigentlich solte es egal sein welches dateisystem du scharst bei übertragen werden die daten doch eh konvertiert
  6. #5 qmasterrr, 30.08.2004
    qmasterrr
    qmasterrr Foren Gott
    01.01.2004
    2.735
    Germany/NRW/Wesel
    solange das datensystem voll lesbar ist sollte es gehen aber sobald etwas mit schreiben kommt sieht es dunkel aus (ext3 ist eh besser)
  7. Anzeige
  8. #6 Schedeffen, 30.08.2004
    Schedeffen
    Schedeffen Grünschnabel
    23.08.2004
    3
    Kontrolliere mal, wer alles auf das Laufwerk Zugriff hat. Bei einigen Distris hat das nur root. Falls du dir nicht sicher bist, poste mal deine /etc/fstab
  9. soeme
    soeme Grünschnabel
    28.08.2007
    mounte deine ntfs platte mit "-o umask=002" dann klappt's :)
    vielleicht ein bisschen spät, aber besser spät als nie
Samba und NTFS Platte - Ähnliche Themen
  1. Samba / Rechteproblem mit NTFS Partition
    Samba / Rechteproblem mit NTFS Partition: Hallo! Ich habe mit meiner NTFS Partition ein kleines Problem.. Nachdem mir leider mein Mainboard am WE abgeraucht ist,:( habe ich kurzerhand...
  2. Samba
    Samba: Hi, ich bin noch ganz neu in der Samba Welt
  3. Samba - Konfiguration
    Samba - Konfiguration: Hallo, ich benötige eure Hilfe bei der Konfiguration von Samba. Und zwar möchte ich 2 Benutzer, die sich, sobald sie die IP des Servers aufrufen,...
  4. Samba4 AD DC
  5. Samba Active Directory SUBDOMAIN
    Samba Active Directory SUBDOMAIN: Hi, ich habe eine Samba Domäne ESC.LAN mit Samba 4.5 aufgebaut. Jetzt würde ich gern einen neuen Domänen AD im Tree MUNICH.ESC.LAN also eine...
