Probleme mit X
Diskutiere Probleme mit X im Gentoo Forum im Bereich Linux Distributionen; wenn ich X ausführe kommt diese meldung hera root # X This is a pre-release version of XFree86, and is not supported in any way. Bugs may...
  1. #1 trashcity, 20.12.2003
    trashcity
    trashcity Foren As
    30.11.2003
    96
    austria
    hera root # X
    way.  Bugs may be reported to [email]XFree86@XFree86.Org[/email] and patches submitted
    to [email]fixes@XFree86.Org[/email].  Before reporting bugs in pre-release versions,
    please check the latest version in the XFree86 CVS repository
    ([url]http://www.XFree86.Org/cvs[/url]).
    XFree86 Version 4.3.99.901 (4.4.0 RC 1)
    Release Date:  2 December 2003
    X Protocol Version 11, Revision 0, Release 6.6
    Build Operating System: Linux 2.4.21-ac4 i686 [ELF]
    Current Operating System: Linux hera 2.4.21-ac4 #10 SMP Mon Dec 8 18:59:47 CET 2003 i686
    Build Date: 20 December 2003
    Changelog Date: 03 December 2003
            Before reporting problems, check [url]http://www.XFree86.Org/[/url]
    Module Loader present
    (==) Log file: "/var/log/XFree86.0.log", Time: Sat Dec 20 21:09:32 2003
    (==) Using config file: "/etc/X11/XF86Config"
    Using vt 7
    (WW) via(0): Failed to set up write-combining range (0xe4000000,0x2000000)
    Symbol drmClose from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol drmOpen from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    (EE) xf86OpenSerial: Cannot open device mouse
            No such file or directory.
    (EE) Mouse1: cannot open input device
    (EE) PreInit failed for input device "Mouse1"
    The XKEYBOARD keymap compiler (xkbcomp) reports:
    > Error:            No Symbols named "de" in the include file "de"
    >                   Exiting
    >                   Abandoning symbols file "default"
    Errors from xkbcomp are not fatal to the X server
    No core pointer
    Fatal server error:
    failed to initialize core devices
    When reporting a problem related to a server crash, please send
    the full server output, not just the last messages.
    This can be found in the log file "/var/log/XFree86.0.log".
    Please report problems to [email]xfree86@xfree86.org[/email].
    was kann ich jetz tun
    mein system ist ein epia me6000
    gentoo läuft bis auf X perfekt
    grüße trash
  3. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    "failed to initialize core devices"
    Steht doch alles in dem Fehlerlog ? *g*
    Irgendwie scheint er deine Maus nicht zu finden ...
  4. #3 trashcity, 20.12.2003
    trashcity
    trashcity Foren As
    30.11.2003
    96
    austria
    na ja
    sieht so aus als würde X jetzt laufen doch
    wenn ich X ausführe
    kommt mein mouse curser nur ein shell oder sowas kommt nicht!
  5. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    Gentoo ?
    Dann pass mal deine /etc/rc.conf mit deinen default window manager an !
  6. #5 trashcity, 21.12.2003
    trashcity
    trashcity Foren As
    30.11.2003
    96
    austria
    könnt ihr mir da helfen
    hera root # X
    XFree86 Version 4.3.0
    Release Date: 27 February 2003
    (==) Log file: "/var/log/XFree86.0.log", Time: Sun Dec 21 14:28:00 2003
    Using vt 7
    (EE) via(0): No Display subsection in Screen section "Screen 1" for depth/fbbpp 1/1
    Symbol drmUnmap from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol drmMap from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol XAAFillSolidRects from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86Int10FreePages from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86ExecX86int10 from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86Int10AllocPages from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86I2CProbeAddress from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86FreeInt10 from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
    Symbol xf86InitInt10 from module /usr/X11R6/lib/modules/drivers/via_drv.o is unresolved!
       *** If unresolved symbols were reported above, they might not
       *** be the reason for the server aborting.
    Fatal server error:
    Caught signal 11.  Server aborting
    Aborted
    den via treiber hab ich jetzt drin nur wenn ich X aufrufe tut sich nicht viel!
Probleme mit X
Probleme mit X - Ähnliche Themen
  2. Probleme mit YUM
