Probleme mit Update auf KDE 3.2 bei Suse
R
redstar
hab mich mal daran gewagt, als neuling, KDE upzudaten, hab jedoch ein Problem, ich poste aber am besten mal was alles in der Konsole drinsteht (nachdem ich ./configure) eingetippt hab, vielleicht hilfts.
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether g++ supports -Wmissing-format-attribute... yes
checking whether g++ supports -Wundef... yes
checking whether g++ supports -Wno-long-long... yes
checking whether g++ supports -Wnon-virtual-dtor... yes
checking whether g++ supports -fno-exceptions... yes
checking whether g++ supports -fno-check-new... yes
checking whether g++ supports -fno-common... yes
checking whether g++ supports -fexceptions... yes
checking how to run the C++ preprocessor... g++ -E
checking whether g++ supports -O0... yes
checking whether g++ supports -Wl,--no-undefined... yes
checking whether g++ supports -Wl,--allow-shlib-undefined... yes
not using lib directory suffix
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/i586-suse-linux/bin/ld
checking if the linker (/usr/i586-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i586-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... g77
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g77 accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/i586-suse-linux/bin/ld
checking whether the g++ linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
checking for shl_load... (cached) no
checking for shl_load in -ldld... (cached) no
checking for dlopen... (cached) no
checking for dlopen in -ldl... (cached) yes
checking whether a program can dlopen itself... (cached) yes
checking whether a statically linked program can dlopen itself... (cached) yes
appending configuration tag "F77" to libtool
checking for g77 option to produce PIC... -fPIC
checking if g77 PIC flag -fPIC works... yes
checking if g77 supports -c -o file.o... yes
checking whether the g77 linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking if C++ programs can be compiled... yes
checking for strlcat... no
checking if strlcat needs custom prototype... yes - in libkdefakes
checking for strlcpy... no
checking if strlcpy needs custom prototype... yes - in libkdefakes
checking for main in -lutil... yes
checking for main in -lcompat... no
checking for crypt in -lcrypt... yes
checking for socklen_t... socklen_t
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for inet_ntoa... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for sys/types.h... (cached) yes
checking for stdint.h... (cached) yes
checking for poll in -lpoll... no
checking CoreAudio/CoreAudio.h usability... no
checking CoreAudio/CoreAudio.h presence... no
checking for CoreAudio/CoreAudio.h... no
checking if res_init needs -lresolv... yes
checking if res_init is available... yes
checking for killpg in -lucb... no
checking for int... yes
checking size of int... 4
checking for short... yes
checking size of short... 2
checking for long... yes
checking size of long... 4
checking for char *... yes
checking size of char *... 4
checking for shl_unload in -ldld... no
checking for size_t... yes
checking size of size_t... 4
checking for unsigned long... yes
checking size of unsigned long... 4
checking sizeof size_t == sizeof unsigned long... yes
checking crt_externs.h usability... no
checking crt_externs.h presence... no
checking for crt_externs.h... no
checking for _NSGetEnviron... no
checking for vsnprintf... yes
checking for snprintf... yes
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for IceConnectionNumber in -lICE... yes
checking for libXext... yes
checking for pthread_create in -lpthread... yes
checking for extra includes... no
checking for extra libs... no
checking for libz... -lz
checking for libpng... -lpng -lz -lm
checking for libjpeg6b... no
checking for libjpeg... -ljpeg
checking for perl... /usr/bin/perl
checking for Qt... libraries /usr/lib/qt3/lib, headers /usr/lib/qt3/include using -mt
checking for moc... /usr/lib/qt3/bin/moc
checking for uic... /usr/lib/qt3/bin/uic
checking whether uic supports -L ... yes
checking whether uic supports -nounload ... yes
checking if Qt needs -ljpeg... no
checking for rpath... yes
checking for KDE... libraries /opt/kde3/lib, headers /opt/kde3/include
checking if UIC has KDE plugins available... yes
checking for KDE paths... defaults
checking for dcopidl... /opt/kde3/bin/dcopidl
checking for dcopidl2cpp... /opt/kde3/bin/dcopidl2cpp
checking for mcopidl... /opt/kde3/bin/mcopidl
checking for artsc-config... /opt/kde3/bin/artsc-config
checking for kde-config... /opt/kde3/bin/kde-config
checking for meinproc... /opt/kde3/bin/meinproc
checking for kconfig_compiler... not found
configure: error: The important program kconfig_compiler was not found!
Please check whether you installed KDE correctly.
Also für mich hört sich das an als ob ich dieses kconfig_compiler teil brauch, deswegen bin in ins YAST gegangen dann auf software installieren hab des kconfig gesucht haken gesetzt suse hats installiert, ging danach jedoch trortzdem nicht.
Hoffe ihr könnt mir helfen
warums einfach machen wenns auch schwer geht ;-)
ne, danke für den link, werds mit dem rpm mal probieren.
Tux-Forever schrieb:
...aber bei mir lief kde 3.2 nicht richtig rund ...
Jau, bei mir auch nicht.:sly:
Vor allem konnte ich etliche nicht KDE-Programme, die ich vorher benutzt habe, nicht mehr zum "Laufen" bewegen. :rolleyes:
also ich verstehe es nicht ganz ...
hatte mir von der suse seite die ganzen kde-pakte gesaugt, rpm -Uvh *.rpm --nodeps --force (ugly) und gut wars :]
das einzige was war das ich konflikte mit kdepim und kdebase-suse (susewatcher + plugger) hatte. die aber nach deinstall von kdebase-suse gefixt waren.
das einzige was ich eben vermisse ist der susewatcher zweck's warn-icon bei updates :D
Tag,
ja ok danke für eure Antworten, aber so wies aussieht teste ich heute ehh mal Fedora aus ;-)
Das SuSE geht mir langsam aufn Sack, das friert die ganze Zeit ein :evil:
Gibt es eigentlich irgendeine Möglichkeit die kde-3.2-rpm´s von suse in einem Rutsch downzuloaden? Dauernd die Pakete anzuklicken geht einem ja auf´s Gemächt!
Ich benutze fuer solche Faelle GFTP. Da gebe ich die Adresse vom FTP-Server (z.B. ftp.kde.org) ein und in der rechten Fensterhaelfte navigiere bis zum Verzeichnis, wo die Pakete z.B. fuer SuSE liegen. In der linken Fensterhaelfte waehle ich das Verzeichnis, wo die Pakete abgelegt werden sollen. Dann in dem rechten Fenster die Pakete markieren und durch den Button in der Mitte die Pakete vom Server auf die Platte kopieren. :)
ich hab auch mal unter yast den ftp-server von suse als install-quelle eingetragen :]
Servername: ftp.suse.com
Pfad: pub/suse/i386/supplementary/KDE/update_for_9.0/yast-source
works for me :D
Ich hab das update schon mal mit synaptic probiert, aber da ist mehrfach misslungen...
damagers methode hört sich doch ganz gut an.
@schwedy: GFTP?
warum habe ich eigentlich nach kde 3.2 update soundprobleme bei SuSE 9??
miret schrieb:
Man kann auch KBear, NFTP, LFTP, Midnight Commander oder Konqueror dafür verwenden.:)
Ich bin nur am Anfang nicht mit KBear klar gekommen und da GNOME bei mir fast unter jeder Distri auch installiert ist, habe ich den gFTP genommen. Mit Konqueror habe ich auch gute Erfahrungen gemacht. ;)
Das Beste an diesen FTP-Clients ist, dass man Downloads fortsetzen kannst, wenn diese aus irgendeinem Grund wie z.B. Serverüberlastung abgebrochen waren. :sly:
sorry aber meine glaskugel ist im moment kapput :D
gehts auch etwas genauer (konsolenausgabe, syslog, fehlermeldungen u.s.w)?
dann musst du dir ein neues zulegen :rolleyes:
schlicht und einfach nur soundprobleme!... wenn ich von 3.14 auf 3.2 update....
schon bei splash anmeldung höre ich loginsound nicht, nur störgeräusche....
noch etwas genauer gehts leider nicht für ein Newbie!......
ich hab mir gedacht ich greife diesen Thread nochmal auf, da ich ein ziemlich ähnliches Problem mit dem Update aufs 3.2er KDE hab.
Ich hab mir die rpm´s vom Server geladen, im Terminal mit Yast installiert(so wie in dem Forum Howto beschrieben) und jetzt hab ich jedesmal wenn ich ne Software mit Yast installieren will, das Problem, dass er mir hunderte Abhängigkeiten nicht auflösen kann.
Ich hab mal begonnen diese manuell durchzugehen, aber teils ohne Erfolg da er nichts dafür findet.
Aber auch alle auf ignorieren stellen möchte ich auch nicht.
Gibts da Abhilfe? Oder Tips wie ich das Problem
a) beheben kann
b) oder KDE 3.2 wieder deinstallieren und nochmal neu installieren kann?
:help: :help: :help:
Vielen Dank schonmal
Chris
Hey Chris, hast du vielleicht mal versucht, einfach Yasts "Software installieren" drüberlaufen zu lassen, da versucht er alleine alle notwendigen Abhängigkeiten aufzulösen. Und von welchem Server hast du die rpms? Wenn du die vom KDE-Server hast, dann muss du noch ein paar grundsätzliche Pakete bei Suse runterladen, unter anderem das aktuelle Qt usw.
Um die Pakete wieder zu deinstallieren solltest du bei Software installieren nach allen KDE-Paketen und diese deinstallieren. Die wurden nämlich von Yast gleich eingehängt.
Meiner Erfahrung nach ist es übrigens wirklich am einfachsten, ein neues KDE auf ein "jungfräuliches" Suse zu installieren, bei dem zwar XFree, aber noch keine Form von KDE oder Gnome istalliert ist. Erst alle Pakete installieren, dann alle Abhängigkeiten wie oben genannt lösen und zuletzt erst die netten kleinen Tools nachinstallieren. Übrigens: Halte dich dringend an Version 3.2.1!
Cheers,
Knut
Hallo MeisterLampe...
Danke für deinen Tip.
Hab ich mittlerweile hinbekommen. Auch über das Yast so wie du es ungefähr beschreibst. Nur mit bissl mehr "basteln" :)
Aber no prob. Jetzt funzts super. Nur ein paar Bildchen im KDE-Kontrollcenter sind nicht mehr da, aber das stört mich grad auch net.
Das mit dem "jungfräulichem" System ist ne gute Idee nur möchte ich ja nicht immer wenn ich KDE Update, mir mein komplettes System erstmal platt machen und dann wieder neu aufspulen.
Ansonsten, vielen Dank für die Hilfe!!!
Chris
Samba 4 AD Member Server
Samba 4.1.3 auf falschen Netzwerkinterface
