XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-14sarge2 20061002194300 jmm@galadriel)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.6.18-1-686 i686 [ELF]
Build Date: 02 October 2006
This version of XFree86 has been extensively modified by the Debian
Project, and is not supported by the XFree86 Project, Inc., in any
way. Bugs should be reported to the Debian Bug Tracking System; see
<URL: http://www.debian.org/Bugs/Reporting >.
We strongly encourage the use of the "reportbug" package and command
to ensure that bug reports contain as much useful information as
possible.
Before filing a bug report, you may want to consult the Debian X FAQ:
XHTML version: file:///usr/share/doc/xfree86-common/FAQ.xhtml
plain text version: file:///usr/share/doc/xfree86-common/FAQ.gz
Module Loader present
OS Kernel: Linux version 2.4.27-3-386 (pbuilder@dl360-g3) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 Thu Sep 14 08:44:58 UTC 2006
(==) Log file: "/var/log/XFree86.0.log", Time: Thu Jan 1 03:10:51 1998
(==) Using config file: "/etc/X11/XF86Config-4"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "3815 FA"
(**) | |-->Device "NVIDIA Corporation NV15 [GeForce2 GTS/Pro]"
(**) |-->Input Device "Generic Keyboard"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc105"
(**) XKB: model: "pc105"
(**) Option "XkbLayout" "de"
(**) XKB: layout: "de"
(**) Option "XkbVariant" "nodeadkeys"
(**) XKB: variant: "nodeadkeys"
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/lib/X11/fonts/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/lib/X11/fonts/CID" does not exist.
(**) FontPath set to "unix/:7100,/usr/lib/X11/fonts/misc,/usr/lib/X11/fonts/100dpi/:unscaled,/usr/lib/X11/fonts/75dpi/:unscaled,/usr/lib/X11/fonts/Type1,/usr/lib/X11/fonts/Speedo,/usr/lib/X11/fonts/100dpi,/usr/lib/X11/fonts/75dpi"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(++) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.2
XFree86 Video Driver: 0.6
XFree86 XInput driver : 0.4
XFree86 Server Extension : 0.2
XFree86 Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
ABI class: XFree86 Video Driver, version 0.6
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x80000060, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0691 card 0000,0000 rev 44 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8598 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0596 card 1106,0000 rev 12 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 0000,0000 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 08 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3050 card 0000,0000 rev 20 class 06,00,00 hdr 00
(II) PCI: 00:08:0: chip 1033,0035 card 182d,0035 rev 41 class 0c,03,10 hdr 80
(II) PCI: 00:08:1: chip 1033,0035 card 182d,0035 rev 41 class 0c,03,10 hdr 00
(II) PCI: 00:08:2: chip 1033,00e0 card 182d,6189 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:09:0: chip 10ec,8139 card 4554,434e rev 10 class 02,00,00 hdr 00
(II) PCI: 00:0b:0: chip 125d,1969 card 125d,8888 rev 01 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0150 card 1102,1047 rev a3 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xec000000 - 0xedffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:7:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus -1: bridge is at (0:7:3), (-1,-1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(--) PCI:*(1:0:0) nVidia Corporation NV15 [GeForce2 GTS/Pro] rev 163, Mem @ 0xec000000/24, 0xe0000000/27, BIOS @ 0xed000000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe8000000 from 0xebffffff to 0xe7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xee003000 - 0xee0030ff (0x100) MX[B]
[1] -1 0 0xee002000 - 0xee0020ff (0x100) MX[B]
[2] -1 0 0xee001000 - 0xee001fff (0x1000) MX[B]
[3] -1 0 0xee000000 - 0xee000fff (0x1000) MX[B]
[4] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[5] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
[6] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[7] -1 0 0xec000000 - 0xecffffff (0x1000000) MX[B](B)
[8] -1 0 0x0000ec00 - 0x0000ec03 (0x4) IX[B]
[9] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[10] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[11] -1 0 0x0000e000 - 0x0000e00f (0x10) IX[B]
[12] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[13] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[14] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[15] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xee003000 - 0xee0030ff (0x100) MX[B]
[6] -1 0 0xee002000 - 0xee0020ff (0x100) MX[B]
[7] -1 0 0xee001000 - 0xee001fff (0x1000) MX[B]
[8] -1 0 0xee000000 - 0xee000fff (0x1000) MX[B]
[9] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[10] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
[11] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[12] -1 0 0xec000000 - 0xecffffff (0x1000000) MX[B](B)
[13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[15] -1 0 0x0000ec00 - 0x0000ec03 (0x4) IX[B]
[16] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[17] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[18] -1 0 0x0000e000 - 0x0000e00f (0x10) IX[B]
[19] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[20] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[21] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[22] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o": No symbols found
Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o": No symbols found
Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o": No symbols found
Skipping "/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_vertex.o": No symbols found
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.2
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 2.0.2
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "speedo"
(II) Loading /usr/X11R6/lib/modules/fonts/libspeedo.a
Skipping "/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o": No symbols found
(II) Module speedo: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.1
(II) Loading font Speedo
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.1.0
(II) LoadModule: "xtt"
(II) Loading /usr/X11R6/lib/modules/fonts/libxtt.a
(II) Module xtt: vendor="X-TrueType Server Project & After X-TT Project"
compiled for 4.3.0.1, module version = 1.4.1
(II) Loading font xtt
(II) LoadModule: "nv"
(II) Loading /usr/X11R6/lib/modules/drivers/nv_drv.o
(II) Module nv: vendor="The XFree86 Project"
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.4
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, GeForce4 440 Go 64M,
GeForce4 410 Go 16M, Quadro4 500 GoGL, Quadro4 550 XGL, Quadro4 NVS,
GeForce4 MX 440 with AGP8X, GeForce4 MX 440SE with AGP8X,
GeForce4 MX 420 with AGP8X, GeForce4 448 Go, GeForce4 488 Go,
Quadro4 580 XGL, Quadro4 280 NVS, Quadro4 380 XGL,
GeForce4 MX Integrated GPU, GeForce3, GeForce3 Ti 200,
GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600, GeForce4 Ti 4400,
0x0252, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, 0x0313, GeForce FX 5600SE,
0x0316, 0x0317, GeForce FX Go5600, GeForce FX Go5650,
Quadro FX Go700, 0x031D, 0x031E, 0x031F, GeForce FX 5200,
GeForce FX 5200 Ultra, GeForce FX 5200, GeForce FX 5200SE,
GeForce FX Go5200, GeForce FX Go5250, GeForce FX Go5200 32M/64M,
0x0329, Quadro NVS 280 PCI, Quadro FX 500, GeForce FX Go5300,
GeForce FX Go5100, 0x032F, GeForce FX 5900 Ultra, GeForce FX 5900,
GeForce FX 5900XT, GeForce FX 5950 Ultra, 0x0334, Quadro FX 3000,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, 0x0345, GeForce FX Go5700, GeForce FX Go5700,
0x0349, 0x034B, Quadro FX Go1000, Quadro FX 1100, 0x034F
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce2 GTS found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000ec00 - 0x0000ec03 (0x4) IX[B]
[19] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[20] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[21] -1 0 0x0000e000 - 0x0000e00f (0x10) IX[B]
[22] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[23] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[24] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[25] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[26] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[27] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) Reloading /usr/X11R6/lib/modules/linux/libint10.a
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(WW) System lacks support for changing MTRRs
(--) NV(0): Chipset: "GeForce2 GTS"
(**) NV(0): Depth 16, (--) framebuffer bpp 16
(==) NV(0): RGB weight 565
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xE0000000
(--) NV(0): MMIO registers at 0xEC000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/X11R6/lib/modules/libi2c.a
(II) Module i2c: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.2.0
(II) Loading sub module "ddc"
(II) Reloading /usr/X11R6/lib/modules/libddc.a
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "DDC:ddc2" removed.
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: FUS Model: 280 Serial#: 1304
(II) NV(0): Year: 2001 Week: 37
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) NV(0): Sync: Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 30 vert.: 23
(II) NV(0): Gamma: 2.30
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing is preferred mode
(II) NV(0): redX: 0.621 redY: 0.343 greenX: 0.298 greenY: 0.584
(II) NV(0): blueX: 0.146 blueY: 0.109 whiteX: 0.304 whiteY: 0.329
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 1024 vsize 768 refresh: 60 vid: 16481
(II) NV(0): #1: hsize: 1024 vsize 768 refresh: 75 vid: 20321
(II) NV(0): #2: hsize: 800 vsize 600 refresh: 60 vid: 16453
(II) NV(0): #3: hsize: 800 vsize 600 refresh: 75 vid: 20293
(II) NV(0): #4: hsize: 640 vsize 480 refresh: 60 vid: 16433
(II) NV(0): #5: hsize: 640 vsize 480 refresh: 75 vid: 20273
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 65.0 MHz Image Size: 304 x 228 mm
(II) NV(0): h_active: 1024 h_sync: 1048 h_sync_end 1184 h_blank_end 1344 h_border: 0
(II) NV(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 806 v_border: 0
(II) NV(0): Serial No: YEUN001304
(II) NV(0): Ranges: V min: 55 V max: 75 Hz, H min: 30 H max: 61 kHz, PixClock max 80 MHz
(II) NV(0): Monitor name: 3815 FA
(II) NV(0): Using CRT on CRTC 0
(--) NV(0): VideoRAM: 32768 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(WW) NV(0): config file hsync range 28-38kHz not within DDC hsync range 30-61kHz
(WW) NV(0): config file vrefresh range 43-72Hz not within DDC vrefresh range 55-75Hz
(II) NV(0): 3815 FA: Using hsync range of 28.00-38.00 kHz
(II) NV(0): 3815 FA: Using vrefresh range of 43.00-72.00 Hz
(II) NV(0): Clock range: 12.00 to 350.00 MHz
(II) NV(0): Not using default mode "640x350" (vrefresh out of range)
(II) NV(0): Not using default mode "320x175" (vrefresh out of range)
(II) NV(0): Not using default mode "640x400" (vrefresh out of range)
(II) NV(0): Not using default mode "320x200" (vrefresh out of range)
(II) NV(0): Not using default mode "720x400" (vrefresh out of range)
(II) NV(0): Not using default mode "360x200" (vrefresh out of range)
(II) NV(0): Not using default mode "640x480" (vrefresh out of range)
(II) NV(0): Not using default mode "320x240" (vrefresh out of range)
(II) NV(0): Not using default mode "640x480" (hsync out of range)
(II) NV(0): Not using default mode "320x240" (hsync out of range)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "400x300" (hsync out of range)
(II) NV(0): Not using default mode "1024x768" (vrefresh out of range)
(II) NV(0): Not using default mode "512x384" (vrefresh out of range)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(II) NV(0): Not using default mode "512x384" (hsync out of range)
(II) NV(0): Not using default mode "1152x864" (hsync out of range)
(II) NV(0): Not using default mode "576x432" (hsync out of range)
(II) NV(0): Not using default mode "1280x960" (hsync out of range)
(II) NV(0): Not using default mode "1280x1024" (hsync out of range)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (hsync out of range)
(II) NV(0): Not using default mode "1792x1344" (hsync out of range)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (hsync out of range)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (hsync out of range)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "832x624" (hsync out of range)
(II) NV(0): Not using default mode "416x312" (hsync out of range)
(II) NV(0): Not using default mode "1152x768" (hsync out of range)
(II) NV(0): Not using default mode "576x384" (hsync out of range)
(II) NV(0): Not using default mode "1400x1050" (hsync out of range)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "1600x1024" (hsync out of range)
(II) NV(0): Not using default mode "800x512" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
(--) NV(0): Virtual size is 800x600 (pitch 800)
(**) NV(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync
(**) NV(0): *Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline "640x480" 25.20 640 656 752 800 480 490 492 525 -hsync -vsync
(**) NV(0): Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync
(**) NV(0): Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline "400x300" 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync
(**) NV(0): Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline "400x300" 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync
(**) NV(0): Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "320x240" 12.60 320 328 376 400 240 245 246 262 doublescan -hsync -vsync
(--) NV(0): Display dimensions: (300, 230) mm
(--) NV(0): DPI set to (67, 66)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.2
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B]
[1] 0 0 0xec000000 - 0xecffffff (0x1000000) MX[B]
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xee003000 - 0xee0030ff (0x100) MX[B]
[8] -1 0 0xee002000 - 0xee0020ff (0x100) MX[B]
[9] -1 0 0xee001000 - 0xee001fff (0x1000) MX[B]
[10] -1 0 0xee000000 - 0xee000fff (0x1000) MX[B]
[11] -1 0 0xe8000000 - 0xe7ffffff (0x0) MX[B]O
[12] -1 0 0xed000000 - 0xed00ffff (0x10000) MX[B](B)
[13] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[14] -1 0 0xec000000 - 0xecffffff (0x1000000) MX[B](B)
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000ec00 - 0x0000ec03 (0x4) IX[B]
[21] -1 0 0x0000e800 - 0x0000e803 (0x4) IX[B]
[22] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[23] -1 0 0x0000e000 - 0x0000e00f (0x10) IX[B]
[24] -1 0 0x0000dc00 - 0x0000dc3f (0x40) IX[B]
[25] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[26] -1 0 0x0000d400 - 0x0000d41f (0x20) IX[B]
[27] -1 0 0x0000d000 - 0x0000d00f (0x10) IX[B]
[28] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[29] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
(**) Option "dpms"
(**) NV(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Keyboard "Generic Keyboard" handled by legacy driver
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: Core Pointer
(**) Option "Device" "/dev/input/mice"
(EE) xf86OpenSerial: Cannot open device /dev/input/mice
No such device.
(EE) Configured Mouse: cannot open input device
(EE) PreInit failed for input device "Configured Mouse"
(II) UnloadModule: "mouse"
(WW) No core pointer registered
No core pointer
Fatal server error:
failed to initialize core devices
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to submit@bugs.debian.org.
