Probleme Installation Fluxbox Gentoo
mincer
mincer
Mitglied
Hy Leute ...
Versuche gerade fluxbox unter Gentoo aus Portage zu installieren ... Leider bricht der Compiler immer ab !
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x4fa): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_context_set_display'
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x51e): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_context_set_visual'
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x542): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_context_set_colormap'
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x566): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_context_set_drawable'
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x65c): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_render_pixmaps_for_whole_image'
FbTk/libFbTk.a(ImageImlib2.o)(.text+0x715): In function `FbTk::ImageImlib2::load(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int) const':
: undefined reference to `imlib_free_pixmap_and_mask'
collect2: ld returned 1 exit status
make[4]: *** [fluxbox] Error 1
make[4]: Leaving directory `/var/tmp/portage/fluxbox-0.9.13-r1/work/fluxbox-0.9.13/src'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/var/tmp/portage/fluxbox-0.9.13-r1/work/fluxbox-0.9.13/src'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/var/tmp/portage/fluxbox-0.9.13-r1/work/fluxbox-0.9.13/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/fluxbox-0.9.13-r1/work/fluxbox-0.9.13'
make: *** [all] Error 2
!!! ERROR: x11-wm/fluxbox-0.9.13-r1 failed.
!!! Function src_compile, Line 74, Exitcode 2
!!! make failed
Kann mir jemand von euch erklären wie ich dieses Problem beheben kann ?!
Xorg ist bereits installiert und läuft auch schon mit TWM !
Danke für eure Hilfe
Grüsse
mInCEr
poste mal deine CFLAGS.. , oder probier aufs erste mal ne andere version
MFG
Dennis
Hy Dennis
Danke für die schnelle Antwort ...
Hier sind meine FLAGS:
CFLAGS="-march=pentium3 -O2 -pipe -fomit-frame-pointer"
CHOST="i686-pc-linux-gnu"
CXXFLAGS="-march=pentium3 -O2 -pipe -fomit-frame-pointer"
CPU ist ein P-III mit 1 GHz
Kernel: Linux g-srv 2.6.9-gentoo-r1
Gruss
mInCEr
Danke MrFenix ...
Diese Libs haben anscheinend noch gefehlt ! ...
Gruss
mInCEr
könnte das der hinweis sein?
Funktion nicht gefunden
GCC Crosscompiler unter Debian Wheezy
Raspberry Pi custom Kernel
Ausführbare C-Datei von Mac OS auf Embedded Linux ausführen
X startet nichtmehr
