Probleme bei Plugininstallation für XMMS
Diskutiere Probleme bei Plugininstallation für XMMS im Anwendungen Forum im Bereich Linux/Unix Allgemein; Hallo. wollte für XMMS ein Plugin für eine Media Library installieren. Hab die Datei in mein Documentsverzeichniss runtergeladen und entpackt....
  1. #1 hundbsc123, 03.01.2009
    hundbsc123
    hundbsc123 Grünschnabel
    18.02.2008
    5
    Hallo.
    Hab die Datei in mein Documentsverzeichniss runtergeladen und entpackt. Im Install steht folgendes:
    The simplest way to compile this package is:
    1. `cd' to the directory containing the package's source code and type
    `./configure' to configure the package for your system. If you're
    using `csh' on an old version of System V, you might need to type
    `sh ./configure' instead to prevent `csh' from trying to execute
    `configure' itself.
    Running `configure' takes awhile. While running, it prints some
    messages telling which features it is checking for.
    2. Type `make' to compile the package.
    3. Optionally, type `make check' to run any self-tests that come with
    the package.
    4. Type `make install' to install the programs and any data files and
    documentation.
    Hab dann folgendes in der Konsole eingegeben:
    linux-en3d:/home/andreas/Documents # cd MediaLibrary-0.3
    linux-en3d:/home/andreas/Documents/MediaLibrary-0.3 # ls
    aclocal.m4 confdefs.h config.log COPYING Makefile.am NEWS
    AUTHORS config.cache config.sub INSTALL Makefile.in README
    bootstrap config.guess configure install-sh missing src
    ChangeLog config.h.in configure.in ltmain.sh mkinstalldirs stamp-h.in
    linux-en3d:/home/andreas/Documents/MediaLibrary-0.3 # ./configure
    loading cache ./config.cache
    checking for a BSD compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking whether make sets ${MAKE}... no
    checking for working aclocal... missing
    checking for working autoconf... missing
    checking for working automake... missing
    checking for working autoheader... missing
    checking for working makeinfo... missing
    checking for gcc... no
    checking for cc... no
    configure: error: no acceptable cc found in $PATH
    Bin mir nicht sicher was das zu bedeuten hat:
    Bin ich im richtigen Verzeichniss? Habe recht wenig Erfahrung Programme über die Konsole zu installieren! Benutze übrigens Opensuse 11.0.
    Gruß Andreas
  3. Gast1
    Gast1 Guest
    Kompilieren ohne compiler (gcc) hat noch nie funktioniert.
  4. #3 saeckereier, 03.01.2009
    saeckereier
    saeckereier Graue Eminenz
    08.05.2005
    1.920
    Im schönen Norden
    Abgesehen davon ist xmms mittlerweile mehr oder weniger tot. Zumindest in den meisten Distributionen ist der nicht mehr enthalten.
  5. #4 pferdefreund, 05.01.2009
    pferdefreund
    pferdefreund Doppel-As
    26.12.2007
    144
    aber trotzdem ein feiner Player - insbesondere mit dem eq-plugin - Übrigens
    zur Kompilierung werden dann auch die -devel Paketer von X, gtk1.2 usw gebraucht
Probleme bei Plugininstallation für XMMS - Ähnliche Themen
  2. Probleme mit YUM
