Problem mit Xinerama
Diskutiere Problem mit Xinerama im Sonstige Window Manager Forum im Bereich X Window; Hallo, habe mal versucht meine xorg.conf mit Hand zu schreiben, leider kriege ich den zweiten Monitor nicht an, was mache ich falsch?...
  1. #1 CuRaToR, 28.08.2007
    CuRaToR
    CuRaToR Doppel-As
    08.09.2006
    114
    Section "ServerLayout"
        Identifier     "Mulithead"
        Screen      0  "LCD-Screen" 0 0
        Screen      1  "CRT-Screen" RightOf "CRT-Screen"
        InputDevice    "Logitech EX110 KB" "CoreKeyboard"
        InputDevice    "Logitech EX110 MS" "CorePointer"
    EndSection
    Section "Files"
        RgbPath         "/usr/lib64/X11/rgb"
    EndSection
    Section "Module"
        Load           "dbe"
        Load           "extmod"
        Load           "type1"
        Load           "freetype"
        Load           "glx"
    EndSection
    Section "ServerFlags"
        Option         "Xinerama" "1"
    EndSection
    Section "InputDevice"
         Driver "mouse"
         Identifier "Logitech EX110 MS"
         Option "ButtonNumber" "5"
         Option "Name" "AutoDetected"
         Option "Protocol" "IMPS/2"
         Option "Vendor" "AutoDetected"
         Option "ZAxisMapping" "4 5"
    EndSection
    	Identifier  "Logitech EX110 KB"
    	Driver      "kbd"
    	Option	    "XkbModel" "pc105"
    	Option	    "XkbLayout" "de"
    EndSection
    Section "Monitor"
        Identifier     "LCD"
        VendorName     "Fujitsu Siemens"
        ModelName      "ScaleoView W19-1"
        HorizSync       55.5
        VertRefresh     60
        Option         "DPMS"
    EndSection
    Section "Monitor"
        Identifier     "CRT"
        VendorName     "Highscreen"
        ModelName      "MS 1779P"
        HorizSync       30.0 - 69.0
        VertRefresh     47.0 - 120.0
        Option         "DPMS"
    EndSection
    Section "Device"
        Identifier     "Asus 8500GT 1"
        Driver         "nvidia"
        VendorName     "NVIDIA Corporation"
        BusID          "PCI:1:0:0"
        Screen          0
    EndSection
    Section "Device"
        Identifier     "Asus 8500GT 2"
        Driver         "nvidia"
        BusID          "PCI:1:0:0"
        Screen          0
    EndSection
    Section "Screen"
        Identifier     "LCD-Screen"
        Device         "Asus 8500GT 1"
        Monitor        "LCD"
        DefaultDepth    24
        SubSection     "Display"
            Depth       24
            Modes      "1024x768"
        EndSubSection
    EndSection
    Section "Screen"
        Identifier     "CRT-Screen"
        Device         "Asus 8500GT 2"
        Monitor        "CRT"
        DefaultDepth    24
            Depth       24
            Modes      "1024x768"
        EndSubSection
    EndSection
    X Window System Version 7.2.0
    Release Date: 22 January 2007
    X Protocol Version 11, Revision 0, Release 7.2
    Build Operating System: Linux 2.6.22-gentoo-r5 x86_64
    Current Operating System: Linux QuadCore 2.6.22-gentoo-r5 #5 SMP Sat Aug 25 19:36:10 CEST 2007 x86_64
    Build Date: 25 August 2007
    	Before reporting problems, check http://wiki.x.org
    Module Loader present
    (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 29 16:11:06 2007
    (==) Using config file: "/etc/X11/xorg.conf"
    (==) ServerLayout "Mulithead"
    (**) |-->Screen "LCD-Screen" (0)
    (**) |   |-->Monitor "LCD"
    (**) |   |-->Device "Asus 8500GT 1"
    (**) |-->Screen "CRT-Screen" (1)
    (**) |   |-->Monitor "CRT"
    (**) |   |-->Device "Asus 8500GT 2"
    (**) |-->Input Device "Logitech EX110 KB"
    (**) |-->Input Device "Logitech EX110 MS"
    (WW) The directory "/usr/share/fonts/TTF/" does not exist.
    	Entry deleted from font path.
    (WW) The directory "/usr/share/fonts/OTF" does not exist.
    (==) FontPath set to:
    	/usr/share/fonts/misc/,
    	/usr/share/fonts/Type1/,
    	/usr/share/fonts/100dpi/,
    	/usr/share/fonts/75dpi/
    (**) RgbPath set to "/usr/lib64/X11/rgb"
    (==) ModulePath set to "/usr/lib64/xorg/modules"
    (**) Option "Xinerama" "1"
    (**) Xinerama: enabled
    (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    (II) No APM support in BIOS or kernel
    (II) Loader magic: 0x6ae0a0
    (II) Module ABI versions:
    	X.Org ANSI C Emulation: 0.3
    	X.Org Video Driver: 1.1
    	X.Org XInput driver : 0.7
    	X.Org Server Extension : 0.3
    	X.Org Font Renderer : 0.5
    (II) Loader running on linux
    (II) LoadModule: "pcidata"
    (II) Loading /usr/lib64/xorg/modules//libpcidata.so
    (II) Module pcidata: vendor="X.Org Foundation"
    	compiled for 7.2.0, module version = 1.0.0
    	ABI class: X.Org Video Driver, version 1.1
    (--) using VT number 7
    (II) PCI: PCI scan (all values are in hex)
    (II) PCI: 00:00:0: chip 8086,29c0 card 1043,8276 rev 02 class 06,00,00 hdr 00
    (II) PCI: 00:01:0: chip 8086,29c1 card 0000,0000 rev 02 class 06,04,00 hdr 01
    (II) PCI: 00:1a:0: chip 8086,2937 card 1043,8277 rev 02 class 0c,03,00 hdr 80
    (II) PCI: 00:1a:1: chip 8086,2938 card 1043,8277 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1a:2: chip 8086,2939 card 1043,8277 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1a:7: chip 8086,293c card 1043,8277 rev 02 class 0c,03,20 hdr 00
    (II) PCI: 00:1b:0: chip 8086,293e card 1043,829f rev 02 class 04,03,00 hdr 00
    (II) PCI: 00:1c:0: chip 8086,2940 card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1c:4: chip 8086,2948 card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1c:5: chip 8086,294a card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1d:0: chip 8086,2934 card 1043,8277 rev 02 class 0c,03,00 hdr 80
    (II) PCI: 00:1d:1: chip 8086,2935 card 1043,8277 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1d:2: chip 8086,2936 card 1043,8277 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1d:7: chip 8086,293a card 1043,8277 rev 02 class 0c,03,20 hdr 00
    (II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 92 class 06,04,01 hdr 01
    (II) PCI: 00:1f:0: chip 8086,2918 card 1043,8277 rev 02 class 06,01,00 hdr 80
    (II) PCI: 00:1f:2: chip 8086,2921 card 1043,8277 rev 02 class 01,01,8f hdr 00
    (II) PCI: 00:1f:3: chip 8086,2930 card 1043,8277 rev 02 class 0c,05,00 hdr 00
    (II) PCI: 00:1f:5: chip 8086,2926 card 1043,8277 rev 02 class 01,01,85 hdr 00
    (II) PCI: 01:00:0: chip 10de,0421 card 1043,8245 rev a1 class 03,00,00 hdr 00
    (II) PCI: 02:00:0: chip 1969,1048 card 1043,8226 rev b0 class 02,00,00 hdr 00
    (II) PCI: 03:00:0: chip 197b,2363 card 1043,824f rev 03 class 01,06,01 hdr 80
    (II) PCI: 03:00:1: chip 197b,2363 card 1043,824f rev 03 class 01,01,85 hdr 00
    (II) PCI: 05:01:0: chip 1131,7146 card 13c2,000e rev 01 class 04,80,00 hdr 00
    (II) PCI: 05:03:0: chip 1106,3044 card 1043,81fe rev c0 class 0c,00,10 hdr 00
    (II) PCI: End of PCI scan
    (II) Intel Bridge workaround enabled
    (II) Host-to-PCI bridge:
    (II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
    (II) Bus 0 I/O range:
    	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) Bus 0 non-prefetchable memory range:
    	[0] -1	0	0x00000000 - 0xffffffff (0x100000000) MX[B]
    (II) Bus 0 prefetchable memory range:
    (II) PCI-to-PCI bridge:
    (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
    (II) Bus 1 I/O range:
    	[0] -1	0	0x0000c000 - 0x0000cfff (0x1000) IX[B]
    (II) Bus 1 non-prefetchable memory range:
    	[0] -1	0	0xfa000000 - 0xfe8fffff (0x4900000) MX[B]
    (II) Bus 1 prefetchable memory range:
    	[0] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
    (II) Bus 4: bridge is at (0:28:0), (0,4,4), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 4 prefetchable memory range:
    	[0] -1	0	0xf8f00000 - 0xf8ffffff (0x100000) MX[B]
    (II) Bus 3: bridge is at (0:28:4), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 3 I/O range:
    	[0] -1	0	0x0000d000 - 0x0000dfff (0x1000) IX[B]
    (II) Bus 3 non-prefetchable memory range:
    	[0] -1	0	0xfea00000 - 0xfeafffff (0x100000) MX[B]
    (II) Bus 2: bridge is at (0:28:5), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 2 non-prefetchable memory range:
    	[0] -1	0	0xfe900000 - 0xfe9fffff (0x100000) MX[B]
    (II) Subtractive PCI-to-PCI bridge:
    (II) Bus 5: bridge is at (0:30:0), (0,5,5), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 5 I/O range:
    	[0] -1	0	0x0000e000 - 0x0000efff (0x1000) IX[B]
    (II) Bus 5 non-prefetchable memory range:
    	[0] -1	0	0xfeb00000 - 0xfebfffff (0x100000) MX[B]
    (II) PCI-to-ISA bridge:
    (II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
    (--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0421) rev 161, Mem @ 0xfd000000/24, 0xd0000000/28, 0xfa000000/25, I/O @ 0xcc00/7, BIOS @ 0xfe8e0000/17
    (II) Addressable bus resource ranges are
    	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) OS-reported resource ranges:
    	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    (II) Active PCI resource ranges:
    	[0] -1	0	0xfebff000 - 0xfebff7ff (0x800) MX[B]
    	[1] -1	0	0xfebffc00 - 0xfebffdff (0x200) MX[B]
    	[2] -1	0	0xfeafe000 - 0xfeafffff (0x2000) MX[B]
    	[3] -1	0	0xfe9c0000 - 0xfe9fffff (0x40000) MX[B]
    	[4] -1	0	0xf9fff400 - 0xf9fff4ff (0x100) MX[B]
    	[5] -1	0	0xf9fff800 - 0xf9fffbff (0x400) MX[B]
    	[6] -1	0	0xf9ff8000 - 0xf9ffbfff (0x4000) MX[B]
    	[7] -1	0	0xf9fffc00 - 0xf9ffffff (0x400) MX[B]
    	[8] -1	0	0xfe8e0000 - 0xfe8fffff (0x20000) MX[B](B)
    	[9] -1	0	0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    	[10] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
    	[11] -1	0	0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
    	[12] -1	0	0x0000ec00 - 0x0000ec7f (0x80) IX[B]
    	[13] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
    	[14] -1	0	0x0000d480 - 0x0000d483 (0x4) IX[B]
    	[15] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
    	[16] -1	0	0x0000d880 - 0x0000d883 (0x4) IX[B]
    	[17] -1	0	0x0000dc00 - 0x0000dc07 (0x8) IX[B]
    	[18] -1	0	0x0000a400 - 0x0000a40f (0x10) IX[B]
    	[19] -1	0	0x0000a480 - 0x0000a48f (0x10) IX[B]
    	[20] -1	0	0x0000a800 - 0x0000a803 (0x4) IX[B]
    	[21] -1	0	0x0000a880 - 0x0000a887 (0x8) IX[B]
    	[22] -1	0	0x0000ac00 - 0x0000ac03 (0x4) IX[B]
    	[23] -1	0	0x0000b000 - 0x0000b007 (0x8) IX[B]
    	[24] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[25] -1	0	0x00009400 - 0x0000940f (0x10) IX[B]
    	[26] -1	0	0x00009480 - 0x0000948f (0x10) IX[B]
    	[27] -1	0	0x00009800 - 0x00009803 (0x4) IX[B]
    	[28] -1	0	0x00009880 - 0x00009887 (0x8) IX[B]
    	[29] -1	0	0x00009c00 - 0x00009c03 (0x4) IX[B]
    	[30] -1	0	0x0000a000 - 0x0000a007 (0x8) IX[B]
    	[31] -1	0	0x0000b480 - 0x0000b49f (0x20) IX[B]
    	[32] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
    	[33] -1	0	0x0000b080 - 0x0000b09f (0x20) IX[B]
    	[34] -1	0	0x0000bc00 - 0x0000bc1f (0x20) IX[B]
    	[35] -1	0	0x0000b880 - 0x0000b89f (0x20) IX[B]
    	[36] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
    	[37] -1	0	0x0000cc00 - 0x0000cc7f (0x80) IX[B](B)
    (II) Active PCI resource ranges after removing overlaps:
    (II) OS-reported resource ranges after removing overlaps with PCI:
    (II) All system resource ranges:
    	[4] -1	0	0xfebff000 - 0xfebff7ff (0x800) MX[B]
    	[5] -1	0	0xfebffc00 - 0xfebffdff (0x200) MX[B]
    	[6] -1	0	0xfeafe000 - 0xfeafffff (0x2000) MX[B]
    	[7] -1	0	0xfe9c0000 - 0xfe9fffff (0x40000) MX[B]
    	[8] -1	0	0xf9fff400 - 0xf9fff4ff (0x100) MX[B]
    	[9] -1	0	0xf9fff800 - 0xf9fffbff (0x400) MX[B]
    	[10] -1	0	0xf9ff8000 - 0xf9ffbfff (0x4000) MX[B]
    	[11] -1	0	0xf9fffc00 - 0xf9ffffff (0x400) MX[B]
    	[12] -1	0	0xfe8e0000 - 0xfe8fffff (0x20000) MX[B](B)
    	[13] -1	0	0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    	[14] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
    	[15] -1	0	0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
    	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[18] -1	0	0x0000ec00 - 0x0000ec7f (0x80) IX[B]
    	[19] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
    	[20] -1	0	0x0000d480 - 0x0000d483 (0x4) IX[B]
    	[21] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
    	[22] -1	0	0x0000d880 - 0x0000d883 (0x4) IX[B]
    	[23] -1	0	0x0000dc00 - 0x0000dc07 (0x8) IX[B]
    	[24] -1	0	0x0000a400 - 0x0000a40f (0x10) IX[B]
    	[25] -1	0	0x0000a480 - 0x0000a48f (0x10) IX[B]
    	[26] -1	0	0x0000a800 - 0x0000a803 (0x4) IX[B]
    	[27] -1	0	0x0000a880 - 0x0000a887 (0x8) IX[B]
    	[28] -1	0	0x0000ac00 - 0x0000ac03 (0x4) IX[B]
    	[29] -1	0	0x0000b000 - 0x0000b007 (0x8) IX[B]
    	[30] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[31] -1	0	0x00009400 - 0x0000940f (0x10) IX[B]
    	[32] -1	0	0x00009480 - 0x0000948f (0x10) IX[B]
    	[33] -1	0	0x00009800 - 0x00009803 (0x4) IX[B]
    	[34] -1	0	0x00009880 - 0x00009887 (0x8) IX[B]
    	[35] -1	0	0x00009c00 - 0x00009c03 (0x4) IX[B]
    	[36] -1	0	0x0000a000 - 0x0000a007 (0x8) IX[B]
    	[37] -1	0	0x0000b480 - 0x0000b49f (0x20) IX[B]
    	[38] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
    	[39] -1	0	0x0000b080 - 0x0000b09f (0x20) IX[B]
    	[40] -1	0	0x0000bc00 - 0x0000bc1f (0x20) IX[B]
    	[41] -1	0	0x0000b880 - 0x0000b89f (0x20) IX[B]
    	[42] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
    	[43] -1	0	0x0000cc00 - 0x0000cc7f (0x80) IX[B](B)
    (II) LoadModule: "dbe"
    (II) Loading /usr/lib64/xorg/modules/extensions//libdbe.so
    (II) Module dbe: vendor="X.Org Foundation"
    	Module class: X.Org Server Extension
    	ABI class: X.Org Server Extension, version 0.3
    (II) Loading extension DOUBLE-BUFFER
    (II) LoadModule: "extmod"
    (II) Loading /usr/lib64/xorg/modules/extensions//libextmod.so
    (II) Module extmod: vendor="X.Org Foundation"
    (II) Loading extension SHAPE
    (II) Loading extension MIT-SUNDRY-NONSTANDARD
    (II) Loading extension BIG-REQUESTS
    (II) Loading extension SYNC
    (II) Loading extension MIT-SCREEN-SAVER
    (II) Loading extension XC-MISC
    (II) Loading extension XFree86-VidModeExtension
    (II) Loading extension XFree86-Misc
    (II) Loading extension XFree86-DGA
    (II) Loading extension DPMS
    (II) Loading extension TOG-CUP
    (II) Loading extension Extended-Visual-Information
    (II) Loading extension XVideo
    (II) Loading extension XVideo-MotionCompensation
    (II) Loading extension X-Resource
    (II) LoadModule: "type1"
    (II) Loading /usr/lib64/xorg/modules/fonts//libtype1.so
    (II) Module type1: vendor="X.Org Foundation"
    	compiled for 7.2.0, module version = 1.0.2
    	Module class: X.Org Font Renderer
    	ABI class: X.Org Font Renderer, version 0.5
    (II) Loading font Type1
    (II) LoadModule: "freetype"
    (II) Loading /usr/lib64/xorg/modules/fonts//libfreetype.so
    (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
    	compiled for 7.2.0, module version = 2.1.0
    (II) Loading font FreeType
    (II) LoadModule: "glx"
    (II) Loading /usr/lib64/xorg/modules/extensions//libglx.so
    (II) Module glx: vendor="X.Org Foundation"
    (==) AIGLX enabled
    (II) Loading extension GLX
    (II) LoadModule: "nvidia"
    (II) Loading /usr/lib64/xorg/modules/drivers//nvidia_drv.so
    (II) Module nvidia: vendor="NVIDIA Corporation"
    	compiled for 4.0.2, module version = 1.0.0
    	Module class: X.Org Video Driver
    (II) LoadModule: "kbd"
    (II) Loading /usr/lib64/xorg/modules/input//kbd_drv.so
    (II) Module kbd: vendor="X.Org Foundation"
    	compiled for 7.2.0, module version = 1.1.0
    	Module class: X.Org XInput Driver
    	ABI class: X.Org XInput driver, version 0.7
    (II) LoadModule: "mouse"
    (II) Loading /usr/lib64/xorg/modules/input//mouse_drv.so
    (II) Module mouse: vendor="X.Org Foundation"
    	compiled for 7.2.0, module version = 1.1.1
    (II) NVIDIA dlloader X Driver  100.14.09  Sat May 26 00:45:12 PDT 2007
    (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    (II) Primary Device is: PCI 01:00:0
    (WW) NVIDIA: More than one matching Device section for instances
    	(BusID: PCI:1:0:0) found: Asus 8500GT 2
    (--) Chipset NVIDIA GPU found
    (II) Loading sub module "fb"
    (II) LoadModule: "fb"
    (II) Loading /usr/lib64/xorg/modules//libfb.so
    (II) Module fb: vendor="X.Org Foundation"
    	ABI class: X.Org ANSI C Emulation, version 0.3
    (II) Loading sub module "wfb"
    (II) LoadModule: "wfb"
    (II) Loading /usr/lib64/xorg/modules//libwfb.so
    (II) Module wfb: vendor="NVIDIA Corporation"
    	compiled for 7.1.99.2, module version = 1.0.0
    (II) Loading sub module "ramdac"
    (II) LoadModule: "ramdac"
    (II) Loading /usr/lib64/xorg/modules//libramdac.so
    (II) Module ramdac: vendor="X.Org Foundation"
    	compiled for 7.2.0, module version = 0.1.0
    (II) resource ranges after xf86ClaimFixedResources() call:
    (II) resource ranges after probing:
    	[16] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
    	[17] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
    	[18] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
    	[19] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[20] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[21] -1	0	0x0000ec00 - 0x0000ec7f (0x80) IX[B]
    	[22] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
    	[23] -1	0	0x0000d480 - 0x0000d483 (0x4) IX[B]
    	[24] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
    	[25] -1	0	0x0000d880 - 0x0000d883 (0x4) IX[B]
    	[26] -1	0	0x0000dc00 - 0x0000dc07 (0x8) IX[B]
    	[27] -1	0	0x0000a400 - 0x0000a40f (0x10) IX[B]
    	[28] -1	0	0x0000a480 - 0x0000a48f (0x10) IX[B]
    	[29] -1	0	0x0000a800 - 0x0000a803 (0x4) IX[B]
    	[30] -1	0	0x0000a880 - 0x0000a887 (0x8) IX[B]
    	[31] -1	0	0x0000ac00 - 0x0000ac03 (0x4) IX[B]
    	[32] -1	0	0x0000b000 - 0x0000b007 (0x8) IX[B]
    	[33] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[34] -1	0	0x00009400 - 0x0000940f (0x10) IX[B]
    	[35] -1	0	0x00009480 - 0x0000948f (0x10) IX[B]
    	[36] -1	0	0x00009800 - 0x00009803 (0x4) IX[B]
    	[37] -1	0	0x00009880 - 0x00009887 (0x8) IX[B]
    	[38] -1	0	0x00009c00 - 0x00009c03 (0x4) IX[B]
    	[39] -1	0	0x0000a000 - 0x0000a007 (0x8) IX[B]
    	[40] -1	0	0x0000b480 - 0x0000b49f (0x20) IX[B]
    	[41] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
    	[42] -1	0	0x0000b080 - 0x0000b09f (0x20) IX[B]
    	[43] -1	0	0x0000bc00 - 0x0000bc1f (0x20) IX[B]
    	[44] -1	0	0x0000b880 - 0x0000b89f (0x20) IX[B]
    	[45] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
    	[46] -1	0	0x0000cc00 - 0x0000cc7f (0x80) IX[B](B)
    	[47] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
    	[48] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
    (II) Setting vga for screen 0.
    (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
    (==) NVIDIA(0): RGB weight 888
    (==) NVIDIA(0): Default visual is TrueColor
    (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
    (**) NVIDIA(0): Enabling RENDER acceleration
    (EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
    (EE) NVIDIA(0):     log file that the GLX module has been loaded in your X
    (EE) NVIDIA(0):     server, and that the module is the NVIDIA GLX module.  If
    (EE) NVIDIA(0):     you continue to encounter problems, Please try
    (EE) NVIDIA(0):     reinstalling the NVIDIA driver.
    (WW) NVIDIA(GPU-0): Unable to read EDID for display device CRT-1
    (II) NVIDIA(0): NVIDIA GPU GeForce 8500 GT (G86) at PCI:1:0:0 (GPU-0)
    (--) NVIDIA(0): Memory: 524288 kBytes
    (--) NVIDIA(0): VideoBIOS: 60.86.34.00.13
    (II) NVIDIA(0): Detected PCI Express Link width: 16X
    (--) NVIDIA(0): Interlaced video modes are supported on this GPU
    (--) NVIDIA(0): Connected display device(s) on GeForce 8500 GT at PCI:1:0:0:
    (--) NVIDIA(0):     FUS L19W-2 (CRT-0)
    (--) NVIDIA(0):     CRT-1
    (--) NVIDIA(0): FUS L19W-2 (CRT-0): 400.0 MHz maximum pixel clock
    (--) NVIDIA(0): CRT-1: 400.0 MHz maximum pixel clock
    (II) NVIDIA(0): Assigned Display Device: CRT-0
    (II) NVIDIA(0): Validated modes:
    (II) NVIDIA(0):     "1024x768"
    (II) NVIDIA(0): Virtual screen size determined to be 1024 x 768
    (--) NVIDIA(0): DPI set to (63, 75); computed from "UseEdidDpi" X config
    (--) NVIDIA(0):     option
    (==) NVIDIA(0): Disabling 32-bit ARGB GLX visuals.
    (--) Depth 24 pixmap format is 32 bpp
    (II) do I need RAC?  No, I don't.
    (II) resource ranges after preInit:
    	[0] 0	0	0xfa000000 - 0xfbffffff (0x2000000) MX[B]
    	[1] 0	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
    	[2] 0	0	0xfd000000 - 0xfdffffff (0x1000000) MX[B]
    	[3] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[4] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[5] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[6] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[7] -1	0	0xfebff000 - 0xfebff7ff (0x800) MX[B]
    	[8] -1	0	0xfebffc00 - 0xfebffdff (0x200) MX[B]
    	[9] -1	0	0xfeafe000 - 0xfeafffff (0x2000) MX[B]
    	[10] -1	0	0xfe9c0000 - 0xfe9fffff (0x40000) MX[B]
    	[11] -1	0	0xf9fff400 - 0xf9fff4ff (0x100) MX[B]
    	[12] -1	0	0xf9fff800 - 0xf9fffbff (0x400) MX[B]
    	[13] -1	0	0xf9ff8000 - 0xf9ffbfff (0x4000) MX[B]
    	[14] -1	0	0xf9fffc00 - 0xf9ffffff (0x400) MX[B]
    	[15] -1	0	0xfe8e0000 - 0xfe8fffff (0x20000) MX[B](B)
    	[16] -1	0	0xfa000000 - 0xfbffffff (0x2000000) MX[B](B)
    	[17] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
    	[18] -1	0	0xfd000000 - 0xfdffffff (0x1000000) MX[B](B)
    	[19] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
    	[20] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
    	[21] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
    	[22] 0	0	0x0000cc00 - 0x0000cc7f (0x80) IX[B]
    	[23] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[24] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[25] -1	0	0x0000ec00 - 0x0000ec7f (0x80) IX[B]
    	[26] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
    	[27] -1	0	0x0000d480 - 0x0000d483 (0x4) IX[B]
    	[28] -1	0	0x0000d800 - 0x0000d807 (0x8) IX[B]
    	[29] -1	0	0x0000d880 - 0x0000d883 (0x4) IX[B]
    	[30] -1	0	0x0000dc00 - 0x0000dc07 (0x8) IX[B]
    	[31] -1	0	0x0000a400 - 0x0000a40f (0x10) IX[B]
    	[32] -1	0	0x0000a480 - 0x0000a48f (0x10) IX[B]
    	[33] -1	0	0x0000a800 - 0x0000a803 (0x4) IX[B]
    	[34] -1	0	0x0000a880 - 0x0000a887 (0x8) IX[B]
    	[35] -1	0	0x0000ac00 - 0x0000ac03 (0x4) IX[B]
    	[36] -1	0	0x0000b000 - 0x0000b007 (0x8) IX[B]
    	[37] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[38] -1	0	0x00009400 - 0x0000940f (0x10) IX[B]
    	[39] -1	0	0x00009480 - 0x0000948f (0x10) IX[B]
    	[40] -1	0	0x00009800 - 0x00009803 (0x4) IX[B]
    	[41] -1	0	0x00009880 - 0x00009887 (0x8) IX[B]
    	[42] -1	0	0x00009c00 - 0x00009c03 (0x4) IX[B]
    	[43] -1	0	0x0000a000 - 0x0000a007 (0x8) IX[B]
    	[44] -1	0	0x0000b480 - 0x0000b49f (0x20) IX[B]
    	[45] -1	0	0x0000b400 - 0x0000b41f (0x20) IX[B]
    	[46] -1	0	0x0000b080 - 0x0000b09f (0x20) IX[B]
    	[47] -1	0	0x0000bc00 - 0x0000bc1f (0x20) IX[B]
    	[48] -1	0	0x0000b880 - 0x0000b89f (0x20) IX[B]
    	[49] -1	0	0x0000b800 - 0x0000b81f (0x20) IX[B]
    	[50] -1	0	0x0000cc00 - 0x0000cc7f (0x80) IX[B](B)
    	[51] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
    	[52] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
    (II) NVIDIA(0): Unable to connect to the ACPI daemon; the ACPI daemon may not
    (II) NVIDIA(0):     be running or the "AcpidSocketPath" X configuration option
    (II) NVIDIA(0):     may not be set correctly.  When the ACPI daemon is
    (II) NVIDIA(0):     available, the NVIDIA X driver can use it to receive ACPI
    (II) NVIDIA(0):     events.  For details, please see the "ConnectToAcpid" and
    (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
    (II) NVIDIA(0):     Config Options in the README.
    (II) NVIDIA(0): Setting mode "1024x768"
    (--) NVIDIA(0): No video decoder detected
    (II) Loading extension NV-GLX
    (II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
    (II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
    (==) NVIDIA(0): Backing store disabled
    (==) NVIDIA(0): Silken mouse enabled
    (**) Option "dpms"
    (**) NVIDIA(0): DPMS enabled
    (II) Loading extension NV-CONTROL
    (==) RandR enabled
    (II) Initializing built-in extension MIT-SHM
    (II) Initializing built-in extension XInputExtension
    (II) Initializing built-in extension XTEST
    (II) Initializing built-in extension XKEYBOARD
    (II) Initializing built-in extension XC-APPGROUP
    (II) Initializing built-in extension XAccessControlExtension
    (II) Initializing built-in extension SECURITY
    (II) Initializing built-in extension XINERAMA
    (II) Initializing built-in extension XFIXES
    (II) Initializing built-in extension XFree86-Bigfont
    (II) Initializing built-in extension RENDER
    (II) Initializing built-in extension RANDR
    (II) Initializing built-in extension COMPOSITE
    (II) Initializing built-in extension DAMAGE
    (II) Initializing built-in extension XEVIE
    (EE) AIGLX: DRI module not loaded
    (II) Loading local sub module "GLcore"
    (II) LoadModule: "GLcore"
    (II) Loading /usr/lib64/xorg/modules/extensions//libGLcore.so
    (II) Module GLcore: vendor="X.Org Foundation"
    (II) GLX: Initialized MESA-PROXY GL provider for screen 0
    (**) Option "CoreKeyboard"
    (**) Logitech EX110 KB: Core Keyboard
    (**) Option "Protocol" "standard"
    (**) Logitech EX110 KB: Protocol: standard
    (**) Option "AutoRepeat" "500 30"
    (**) Option "XkbRules" "xorg"
    (**) Logitech EX110 KB: XkbRules: "xorg"
    (**) Option "XkbModel" "pc105"
    (**) Logitech EX110 KB: XkbModel: "pc105"
    (**) Option "XkbLayout" "de"
    (**) Logitech EX110 KB: XkbLayout: "de"
    (**) Option "CustomKeycodes" "off"
    (**) Logitech EX110 KB: CustomKeycodes disabled
    (**) Option "Protocol" "IMPS/2"
    (**) Logitech EX110 MS: Device: "/dev/input/mice"
    (**) Logitech EX110 MS: Protocol: "IMPS/2"
    (**) Option "CorePointer"
    (**) Logitech EX110 MS: Core Pointer
    (**) Option "Device" "/dev/input/mice"
    (==) Logitech EX110 MS: Emulate3Buttons, Emulate3Timeout: 50
    (**) Option "ZAxisMapping" "4 5"
    (**) Logitech EX110 MS: ZAxisMapping: buttons 4 and 5
    (**) Logitech EX110 MS: Buttons: 9
    (II) XINPUT: Adding extended input device "Logitech EX110 MS" (type: MOUSE)
    (II) XINPUT: Adding extended input device "Logitech EX110 KB" (type: KEYBOARD)
    (II) Logitech EX110 MS: ps2EnableDataReporting: succeeded
    (II) 3rd Button detected: disabling emulate3Button
    [/CODE]
    Danke für Hilfe, Alex
  3. blinx
    blinx Eroberer
    22.06.2006
    63
  4. #3 CuRaToR, 28.08.2007
    CuRaToR
    CuRaToR Doppel-As
    08.09.2006
    114
    Hm, ok ich habe folgendes Problem:
    Ich habe eine 19" 16:9 LCD und einen 17" 4:3 CRT
    Beide sollen laufen, und ich hätte gerne die Funktion, Fenster auf nur einem Monitor maximiewren zu können, so will ich z.B. beim Proggen andere Fenster auslagern.
    Hatte Twin View mit den Nvidia Treibern gangbar, da hatte ich neben dem Problem, dass ich keine Auflösungskombination gefunden habe, die gleiche vertikale Werte hat, und das ein Maximieren das Fenster auf beide Monitore erweitert. Ich dachte da eher da das Prinzip wie in Windows.
    Geht das denn mit Twin View?
  5. #4 CuRaToR, 31.08.2007
    CuRaToR
    CuRaToR Doppel-As
    08.09.2006
    114
    Niemand damit Erfahrungen?
  6. #5 hermann4, 01.09.2007
    hermann4
    hermann4 Firmware v.3.1
    29.09.2006
    522
    Hamburg
    Wie ich sehe, hast du ne Nvidia Karte.
    Ich glaube, da gibt es extra grafische Progs für die Konfiguration von Karten von diesem Hersteller.
  7. caba_
    caba_ (caba{_,}|manuw)
    07.08.2007
    334
    Nimm mal das "Screen 0" aus beiden "Section "Device""
Problem mit Xinerama - Ähnliche Themen
  1. Probleme bei 2 TFT's - keine Augabe auf TFT 2 - Xinerama
    Probleme bei 2 TFT's - keine Augabe auf TFT 2 - Xinerama: EDIT: Problem behoben! :) Siehe eingefügte Zeilen in xorg.conf "rot markiert" Hallo liebe Community, gestern habe ich einen zweiten...
  2. Xinerama & OpenGL Fullscreen: Mausprobleme
    Xinerama & OpenGL Fullscreen: Mausprobleme: Hallo, ich habe z.B. bei den Spielen Armyops und Etwolf grosse Probleme mit der Maus, wenn die Programme im Fullscreen laufen. D.h. der...
  3. Nvidia: Xinerama//TwinView Problem
    Nvidia: Xinerama//TwinView Problem: hoj, ich besitze eine Geforce 5200 FX und habe mir nun vor kurzem einen 2. Monitor geholt und an den DVI ausgang angeschlossen. Blöderweisse...
  4. Xinerama Problem nach Neustart
    Xinerama Problem nach Neustart: Hi folks, ich hab hier ein etwas komisches verhalten. vielleicht hat ja schonma einer was davon gehört. Ich habe hier eine Matrix G200...
  5. Virtualboxproblem
