problem mit wpa_supplicant?
Diskutiere problem mit wpa_supplicant? im Internet, lokale Netzwerke und Wireless Lan Forum im Bereich Netzwerke & Serverdienste; hi, mein wpa_supplicant unter ubuntu hardy macht zicken, und ich finde den fehler nicht. ich hab hier mal nen mitschnitt von wpa_supplicant...
  1. #1 Nemesis, 26.01.2008
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
    hi,
    wpa_supplicant -iwlan0 -Dwext -c /etc/wpa_supplicant/wpa_supplicant.conf -d
    Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
    Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
    Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
    ctrl_interface='/var/run/wpa_supplicant'
    eapol_version=1
    ap_scan=1
    Priority group 0
       id=0 ssid='Secure'
    Initializing interface (2) 'wlan0'
    EAPOL: SUPP_PAE entering state DISCONNECTED
    EAPOL: KEY_RX entering state NO_KEY_RECEIVE
    EAPOL: SUPP_BE entering state INITIALIZE
    EAP: EAP entering state DISABLED
    EAPOL: External notification - portEnabled=0
    EAPOL: External notification - portValid=0
    SIOCGIWRANGE: WE(compiled)=22 WE(source)=21 enc_capa=0xf
      capabilities: key_mgmt 0xf enc 0xf
    WEXT: Operstate: linkmode=1, operstate=5
    Own MAC address: 00:13:e8:84:df:9f
    wpa_driver_wext_set_wpa
    wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
    wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
    wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
    wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
    wpa_driver_wext_set_countermeasures
    wpa_driver_wext_set_drop_unencrypted
    Setting scan request: 0 sec 100000 usec
    Added interface wlan0
    RTM_NEWLINK: operstate=0 ifi_flags=0x1002 ()
    Wireless event: cmd=0x8b06 len=8
    Ignore event for foreign ifindex 3
    RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
    RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
    State: DISCONNECTED -> SCANNING
    Starting AP scan (specific SSID)
    Scan SSID - hexdump_ascii(len=8):
         61 65 67 65 63 65 66 65                           Secure
    Trying to get current scan results first without requesting a new scan to speed up initial association
    Received 0 bytes of scan results (0 BSSes)
    Scan results: 0
    Selecting BSS from priority group 0
    Try to find WPA-enabled AP
    Try to find non-WPA AP
    No suitable AP found.
    Setting scan request: 0 sec 0 usec
    Starting AP scan (broadcast SSID)
    Wireless event: cmd=0x8b19 len=8
    Received 246 bytes of scan results (1 BSSes)
    Scan results: 1
    0: 00:0f:b5:11:7b:d4 ssid='Secure' wpa_ie_len=26 rsn_ie_len=0 caps=0x11
       selected based on WPA IE
       selected WPA AP 00:0f:b5:11:7b:d4 ssid='Secure'
    Trying to associate with 00:0f:b5:11:7b:d4 (SSID='Secure' freq=2462 MHz)
    Cancelling scan request
    WPA: clearing own WPA/RSN IE
    Automatic auth_alg selection: 0x1
    WPA: using IEEE 802.11i/D3.0
    WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 1
    WPA: set AP WPA IE - hexdump(len=26): dd 18 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 00 00
    WPA: clearing AP RSN IE
    WPA: using GTK TKIP
    WPA: using PTK TKIP
    WPA: using KEY_MGMT WPA-PSK
    WPA: Set own WPA IE default - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
    No keys have been configured - skip key clearing
    State: SCANNING -> ASSOCIATING
    wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
    WEXT: Operstate: linkmode=-1, operstate=5
    wpa_driver_wext_associate
    Setting authentication timeout: 10 sec 0 usec
    EAPOL: External notification - EAP success=0
    EAPOL: External notification - EAP fail=0
    EAPOL: External notification - portControl=Auto
    Wireless event: cmd=0x8b04 len=12
    Wireless event: cmd=0x8b1a len=16
    RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
    Wireless event: cmd=0x8c02 len=167
    Association info event
    req_ies - hexdump(len=50): 00 08 61 65 67 65 63 65 66 65 01 08 02 04 0b 16 0c 12 18 24 32 04 30 48 60 6c dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
    resp_ies - hexdump(len=16): 01 04 82 84 8b 96 32 08 0c 12 18 24 30 48 60 6c
    WPA: set own WPA/RSN IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
    Wireless event: cmd=0x8b15 len=20
    Wireless event: new AP: 00:0f:b5:11:7b:d4
    State: ASSOCIATING -> ASSOCIATED
    Associated to a new BSS: BSSID=00:0f:b5:11:7b:d4
    Associated with 00:0f:b5:11:7b:d4
    WPA: Association event - clear replay counter
    EAPOL: External notification - portEnabled=1
    EAPOL: SUPP_PAE entering state CONNECTING
    EAPOL: SUPP_BE entering state IDLE
    RX EAPOL from 00:0f:b5:11:7b:d4
    IEEE 802.1X RX: version=1 type=3 length=95
      EAPOL-Key type=254
      key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
      key_length=32 key_data_length=0
      replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
      key_nonce - hexdump(len=32): 17 f2 d4 b3 b1 a1 d1 95 25 ad ac 9c 25 72 e2 4c 65 fb 09 78 61 91 c1 45 07 ce 8a 78 52 e8 ff e6
      key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
      key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
      key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
      key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    WPA: ignoring 8 bytes after the IEEE 802.1X data
    State: ASSOCIATED -> 4WAY_HANDSHAKE
    WPA: RX message 1 of 4-Way Handshake from 00:0f:b5:11:7b:d4 (ver=1)
    WPA: Renewed SNonce - hexdump(len=32): 9d b3 c0 f8 63 c8 a4 11 94 fe e2 66 9b be 90 e8 fa 4a 36 59 bb 59 06 c0 a9 d8 5a b6 91 66 7e 2c
    WPA: PMK - hexdump(len=32): [REMOVED]
    WPA: PTK - hexdump(len=64): [REMOVED]
    WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
    WPA: Sending EAPOL-Key 2/4
    IEEE 802.1X RX: version=1 type=3 length=121
      EAPOL-Key type=254
      key_info 0x1c9 (ver=1 keyidx=0 rsvd=0 Pairwise Install Ack MIC)
      key_length=32 key_data_length=26
      replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
      key_mic - hexdump(len=16): de 12 96 b7 85 f7 92 19 4c 42 e4 09 e1 ae 50 97
    State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
    WPA: RX message 3 of 4-Way Handshake from 00:0f:b5:11:7b:d4 (ver=1)
    WPA: IE KeyData - hexdump(len=26): dd 18 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02 00 00
    WPA: Sending EAPOL-Key 4/4
    WPA: Installing PTK to the driver.
    WPA: RSC - hexdump(len=6): 00 00 00 00 00 00
    wpa_driver_wext_set_key: alg=2 key_idx=0 set_tx=1 seq_len=6 key_len=32
    State: 4WAY_HANDSHAKE -> GROUP_HANDSHAKE
    IEEE 802.1X RX: version=1 type=3 length=127
      EAPOL-Key type=254
      key_info 0x3a1 (ver=1 keyidx=2 rsvd=0 Group Ack MIC Secure)
      key_length=32 key_data_length=32
      replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 03
      key_nonce - hexdump(len=32): 17 f2 d4 b3 b1 a1 d1 95 25 ad ac 9c 25 72 e2 4c 65 fb 09 78 61 91 c1 45 07 ce 8a 78 52 e7 ff e5
      key_iv - hexdump(len=16): 4c 65 fb 09 78 61 91 c1 45 07 ce 8a 78 52 e9 ff
      key_rsc - hexdump(len=8): 7e 00 00 00 00 00 00 00
      key_mic - hexdump(len=16): b8 3c 9f 71 c1 27 de 33 eb b3 9d 9b b6 df e9 f1
    WPA: RX message 1 of Group Key Handshake from 00:0f:b5:11:7b:d4 (ver=1)
    State: GROUP_HANDSHAKE -> GROUP_HANDSHAKE
    WPA: Group Key - hexdump(len=32): [REMOVED]
    WPA: Installing GTK to the driver (keyidx=2 tx=0).
    WPA: RSC - hexdump(len=6): 7e 00 00 00 00 00
    wpa_driver_wext_set_key: alg=2 key_idx=2 set_tx=0 seq_len=6 key_len=32
    WPA: Sending EAPOL-Key 2/2
    WPA: Key negotiation completed with 00:0f:b5:11:7b:d4 [PTK=TKIP GTK=TKIP]
    Cancelling authentication timeout
    State: GROUP_HANDSHAKE -> COMPLETED
    CTRL-EVENT-CONNECTED - Connection to 00:0f:b5:11:7b:d4 completed (auth) [id=0 id_str=]
    wpa_driver_wext_set_operstate: operstate 0->1 (UP)
    WEXT: Operstate: linkmode=-1, operstate=6
    EAPOL: External notification - portValid=1
    EAPOL: External notification - EAP success=1
    EAPOL: SUPP_PAE entering state AUTHENTICATING
    EAPOL: SUPP_BE entering state SUCCESS
    EAPOL: SUPP_PAE entering state AUTHENTICATED
    RTM_NEWLINK: operstate=1 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
    EAPOL: startWhen --> 0
    RTM_NEWLINK: operstate=1 ifi_flags=0x1043 ([UP][RUNNING])
    Wireless event: new AP: 00:00:00:00:00:00
    Added BSSID 00:0f:b5:11:7b:d4 into blacklist
    CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
    State: COMPLETED -> DISCONNECTED
    wpa_driver_wext_set_operstate: operstate 1->0 (DORMANT)
    und meine wpa_supplicant.conf sieht wie folgt aus:
    eapol_version=1
    ap_scan=1
    network={
    	ssid="Secure"
    	scan_ssid=1
    	proto=WPA
    	key_mgmt=WPA-PSK
    	pairwise=TKIP
    	group=TKIP
    	psk=Geheim
    hat jemand ne idee an was das ligen könnte?
  3. #2 GambaJo, 26.01.2008
    GambaJo
    GambaJo Maxi King alraaaight!!!
    08.01.2008
    171
    Statt "Geheim" steht bei dir aber schon so ein relativ langer und kryptischer String?
  4. #3 Tomekk228, 26.01.2008
    Tomekk228
    Tomekk228 Lebende Foren Legende
    14.08.2007
    2.417
    /home/tomekk/
    Oh man. Ich hoffe natürlich ja :rofl:
  5. #4 Nemesis, 26.01.2008
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
    ich glaube ich brauche dazu keinen kommentar abgeben ;)
problem mit wpa_supplicant? - Ähnliche Themen
  1. wpa_supplicant Problem gentoo
    wpa_supplicant Problem gentoo: Moin, nach langem gefriggel läuft meine wlan karte schon fast, nur noch ein prob. mit der wpa_supplicant, ich hoffe allerdings das ihr mir hier...
  2. wpa_supplicant PEAP problem
    wpa_supplicant PEAP problem: Hallo, ich habe meinen Laptop paar wochen nicht benutzt und habe Jetzt Linux neu installiert. Jedoch läuft W-Lan in der Uni nicht, bei mir...
  3. Ubuntu 8.10 - Problem: Wlan mit WPA (wpa_supplicant)
    Ubuntu 8.10 - Problem: Wlan mit WPA (wpa_supplicant): Hallo Zusammen, ich versuche gerade eine WLAN-Verbindung von meinem Samsung P35 (Intel 2200BG Netzwerkkarte) zum Router (Speedport W700V)...
  4. Problem mit Windows auf Ordner auf dem Linuxsystem zuzugreifen
  5. Virtualboxproblem
