Problem mit Update unter Zen
Diskutiere Problem mit Update unter Zen im SuSE / OpenSuSE Forum im Bereich Linux Distributionen; Also mir wurde angeraten mein System zu Updaten und bei dem Versuch erhielt ich folgende Meldung mit der ich nix anfangen kann ... Dependency...
  1. #1 Mathilda, 26.09.2006
    Mathilda
    Mathilda Mitglied
    22.09.2006
    32
    Dependency Resolution Failed
    Updating kmymoney-0.8.2-16.i586[System packages] to kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    Installing MusE-1.0pre1-0.pm.svn20060918.i586[20060926-143805]
    There are no installable providers of libQtDesigner.so.4 for MusE-1.0pre1-0.pm.svn20060918.i586[20060926-143805]
    There are no installable providers of koffice-spreadsheet >= 1.5 for kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    libofx-0.8.2-43.pm.cvs20060826.i586[20060926-143805] provides libofx.so.3, but it is uninstallable. Try installing it on its own for more details.
    gwenhywfar-2.4.0-0.pm.1.i586[20060926-143805] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    aqbanking-2.2.1-0.pm.1.i586[20060926-143805] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    Installing aqbanking-2.2.1-0.pm.1.i586[20060926-143805]
    aqbanking-qt3-2.2.1-0.pm.1.i586[20060926-143805] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    opensp-1.5.1-91.i586[SUSE-Linux-10.1-DVD-i386-10.1-0-20060926-150514] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    aqbanking-kde3-2.2.1-0.pm.1.i586[20060926-143805] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    ktoblzcheck-1.11-42.pm.1.i586[20060926-143805] needed by kmymoney-0.8.5-99.pm.cvs20060920.i586[20060926-143805]
    dssi-0.9.1-0.pm.1.i586[20060926-143805] needed by MusE-1.0pre1-0.pm.svn20060918.i586[20060926-143805]
    libofx-0.8.2-43.pm.cvs20060826.i586[20060926-143805] provides libofx == 0.8.2-43.pm.cvs20060826, but it is uninstallable. Try installing it on its own for more details.
    There are no installable providers of libofx >= 0.8.2 for aqbanking-2.2.1-0.pm.1.i586[20060926-143805]
    libchipcard2-2.1.8-0.pm.1.i586[20060926-143805] needed by aqbanking-2.2.1-0.pm.1.i586[20060926-143805]
    Kann mir da jemand weiterhelfen ?
    Danke schonmal und Grüße Mathilda
  3. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    Welches SuSE denn?
  4. #3 gropiuskalle, 26.09.2006
    gropiuskalle
    gropiuskalle terra incognita
    01.07.2006
    4.857
    Berlin
    SuSE 10.1 (einfach mal im Profil nachschauen:D ).
  5. #4 Mathilda, 26.09.2006
    Mathilda
    Mathilda Mitglied
    22.09.2006
    32
    fällt keinem was ein ?
    Das System ist wie Kalle schon schrieb ein Suse 10.1, grad frisch von DvD draufgespielt ....
    Mathilda
  6. #5 gropiuskalle, 26.09.2006
    gropiuskalle
    01.07.2006
    4.857
    Berlin
    [​IMG] Leute! Sie muss doch updates einspielen können! Helft ihr!
  7. theton
    theton Bitmuncher
    27.05.2004
    4.820
    Berlin, Germany
  8. #7 fshTux, 27.09.2006
    fshTux
    fshTux Grünschnabel
    02.07.2006
    8
    Ruhrgebiet
    @ Mathilda,
    1. Gehe auf die ROOT-EBENE
    2. Öffne YAST
    3. Wähle dort: Online-Update -Konfiguration
    4. Lass dort die Online-Update-Konfiguration Routine durchlaufen - es dauert etwas.
    5. Nach erfolgreicher Online-Update Konfiguration bitte den Rechner neu starten.
    6. Nach erfolgtem Neustart gehe wieder auf die ROOT-EBENE
    7. Öffne YAST
    8. Wähle dort : Online-Update ( = YOU )
    9. Lass die jetzt beginnende Online-Update Routine durchlaufen.
    10. Nach erfolgreichem Online - Update bitte den Rechner neustarten.
    Jetzt dürften die ersten Probleme nach einer frischen Neuinstallation behoben sein.
    Gruesse
    fshTux
  9. Anzeige
  10. #8 Wolfgang, 27.09.2006
    Wolfgang
    Wolfgang Foren Gott
    24.04.2005
    3.978
    Erfurt
    [OT]
    Was sollte denn das?
    Beiträge sind hier nach wie vor freiwillig!
    Im Übrigen halte ich es nicht für eindeutig aussagekräftig was im Profil steht.
    <uebertreib>Hier haben schon User von Ubuntu geredet, die gerade Gestern noch Probleme zu Gentoo hatten, und weil morgen Fedora neu rauskommt Fedora wollen, wobei im Profil noch Suse steht.</uebertreib>
    Ich persönlich erwarte von jemanden der Hilfe will, dass die nötigen Auskünfte im Posting abgelegt werden.
    Die Mühe, mir die Profile der Hilfesuchenden anzusehen mach ich mir recht selten.
    Die Mühe das Benötigte mit zu Posten dagegen halte ich für das Mindeste, wenn man als Gegenleistung Support erwartet.
    Das wollte ich nur mal völlig wertfrei anmerken.
    Gruß Wolfgang
  11. #9 Mathilda, 28.09.2006
    Mathilda
    Mathilda Mitglied
    22.09.2006
    32
    Es ist vollbracht :D das Update ist aufgespielt
    Danke für eure Hilfe.
    Grüße Mathilda
Problem mit Update unter Zen - Ähnliche Themen
  1. Fedora mit Problem bei Paket-Updates
    Fedora mit Problem bei Paket-Updates: Die Paketverwaltung von Fedora 21 weist einige Fehler auf, die den Standardweg des Paket-Updates scheitern lassen können. Auf der Kommandozeile...
  3. Probleme nach Update auf Suse 12.1
  4. xorg-server update: umstieg von hal auf udev -> probleme mit tastatur & maus
    xorg-server update: umstieg von hal auf udev -> probleme mit tastatur & maus: Hi also der Betreff sagt schon des meiste. Hab mein Gentoo-System seit längerer Zeit mal wieder aktualisiert, was 2 größere Änderungen mit sich...
  5. Pacman Updateproblem
    Pacman Updateproblem: Hi, bin noch Archanfänger und hab ein kleines Problem. Hab auch schon im Wiki gesucht, jedoch nichts passendes gefunden :/ sudo pacman -Syu...
