Problem mit Texteingabe
Diskutiere Problem mit Texteingabe im C/C++ Forum im Bereich Programmieren unter Linux/Unix; Moin, ich programmiere grade in C++ ein Programm in dem man Profile anlegen kann und stehe noch ziemlich am Anfang :) #include <iostream>...
  1. #1 betaros, 13.08.2010
    betaros
    betaros Computerspezi
    02.02.2008
    181
    Moin,
    #include <iostream>
    #include <string>
    #include <fstream>
    #include <stdio.h>
    #include <string.h>
    using namespace std;
    int menu(int menutype);
    int profiles(int profilemenu);
    int main(){
    	int status,menutype = 0;
    	status = menu(menutype);
    	if(status == 1){
    		cout << "Action failed! Maybe wrong Input?" << endl;
    		return 1;
    	return 0;
    int menu(int menutype){
    	switch(menutype){
    		default: return 1;
    		case 0:
    			int input, status;
    			cout << "Monex 0.01" << endl;
    			cout << "----------" << endl;
    			cout << "1) Create Profile" << endl;
    			cout << "2) Load Profile" << endl;
    			cout << "3) Delete Profile" << endl;
    			cin >> input;
    			status = profiles(input);
    			if(status == 0){
    				cout << "Action was successful!" << endl;
    				return 0;
    			} else {
    				return 1;
    		break;
    		return 1;
    int profiles(int profilemenu){
    	switch(profilemenu){
    		default: return 1;
    		case 1:
    			ofstream create_profile("1.txt");
    			string correct;
    			do{
    			char fullname[256], address[256], city[256], country[256];
    			cout << "Full Name: ";
    			cin.getline(fullname,256);
    			cout << "Address:   ";
    			cin.getline(address,256);
    			cout << "City:      ";
    			cin.getline(city,256);
    			cout << "Country:   ";
    			cin.getline(country,256);
    			cout << "Sie heißen " << fullname << " und kommen aus " << address << ", " << city << ", " << country << ". Ist das korrekt? (J/N)";
    			cin >> correct;
    			if(correct == "J" || correct == "j"){
    				char buffer[1028];
    				strcat(buffer,fullname);
    				strcat(buffer,":");
    				strcat(buffer,address);
    				strcat(buffer,":");
    				strcat(buffer,city);
    				strcat(buffer,":");
    				strcat(buffer,country);
    				strcat(buffer,"#");
    				cout << buffer << endl;
    				create_profile.write(buffer,1028);
    				create_profile.close();
    				return 0;
    			}}while(correct=="N"||correct=="n");
    		return 1;
    Mein Problem erkennt man wahrscheinlich bei der Ausführung:
    [betaros@Chef ~]$ ./Entwicklung/monex/main
    Monex 0.01
    1) Create Profile
    2) Load Profile
    3) Delete Profile
    Full Name: Address:   Zuhause
    City:      Hier
    Country:   Am Arsch der Welt
    Sie heißen  und kommen aus Zuhause, Hier, Am Arsch der Welt. Ist das korrekt? (J/N)j
    �K:Zuhause:Hier:Am Arsch der Welt#
    Ich kann Fullname nicht angeben :( Deshalb kommt am Anfang der Ausgabe "�K". Wie kann ich das Problem beheben?
    betaros
  3. #2 marcellus, 13.08.2010
    marcellus
    marcellus Kaiser
    09.05.2007
    1.392
    #include <iostream>
    #include <string>
    #include <fstream>
    #include <stdio.h>       [B]// <= solltest du in einem C++ Programm vermeiden, wenns schon sein muss cstdio[/B]
    #include <string.h>      [B]// ditto[/B]
    int main(){
            if(status == 1){
                    return 1;
            return 0;
            switch(menutype){
                    default: return 1;
                    case 0:
                            int input, status;
                            cout << "Monex 0.01" << endl //die vielen cout kannst du dir sparen
                          [B]  //input ist ein int, das '\n' bleibt im stdin[/B]
                            cin >> input;
                            if(status == 0){
                                    return 0;
                            } else {
                                    return 1;
                    break;
                    return 1;
                    default: return 1;
                    case 1:
                            string correct;
                            do{
                            [B]//das \n von input wird eingelesen[/B]
                           [B] // fullname ist 256 gross, du brauchst platz für das '\0'
                            // ein C++ string wär da natürlich schöner[/B]
                            cout << "City:      ";
                            cout << "Sie heissen " << fullname << " und kommen aus " << address << ", " << city << ", " << country << ". Ist das korrekt? (J/N)";
                            cin >> correct;
                          [B]  //bei sowas match immer auf 'j', nicht auf "j", "j" ist ein null terminierter string, 'j' ist der platz der ansi tabelle an der 'j' steht[/B]
                                    char buffer[1028];
                                    strcat(buffer,":");
                                    strcat(buffer,":");
                                    strcat(buffer,":");
                                    strcat(buffer,"#");
                                    return 0;
                    return 1;
    Ich war jetzt nicht motiviert das ganze selber zu kompilieren, ich hoff aber doch das die kommentare dir weiterhelfen.
  4. #3 betaros, 13.08.2010
    betaros
    02.02.2008
    181
    Vielen Dank für die schnelle Hilfe :)
    nun habe jetzt die Bibliotheken am anfang geändert und bin grade dabei aus
    cin >> input;
    ein
    cin >> s_input;
    input = atoi(s_input.c_str);
    zu machen, wobei s_input ein String ist. Beim kompilieren, sagt er mir dann folgendes:
    main.cpp:34:30: Fehler: Argument des Typs »const char* (std::basic_string<char>::)()const« passt nicht zu »const char*«
    Habe ich dich vielleicht auch nur falsch verstanden?
    betaros
  5. #4 marcellus, 13.08.2010
    marcellus
    marcellus Kaiser
    09.05.2007
    1.392
    strin::c_str() ist eine funktion, das was du probierst ist vermutlich
    input = atoi(s_input.c_str());
    Es spricht eh nichts dagegen ein int einzulesen, nur du solltest zb
    cin >> input;
    cin.ignore(1, '\n')
    machen, das du das '\n' aus dem buffer rausbekommst.
    Die Anmerkung mit den Strings war eher auf deine char arrays bezogen, hässlich sowas :oldman
  6. #5 betaros, 13.08.2010
    betaros
    02.02.2008
    181
    Nochmal vielen Dank! Jetzt ist das Problem verschwunden :)
    Ich habe jetzt aus den chars strings gebaut und wieder ein Problem: create_profile.write() benötigt chars (deshalb diese char Lösung) Da ich aber nur Strings habe, gibt er mir natürlich Fehler. Wenn du du mir das auch noch machst, bin ich dir unendlich dankbar :D
    betaros
    //Edit:
    Problem gelöst:
    		default: return 1;
    		case 1:
    			string correct;
    			do{
    			string fullname, address, city, country;
    			getline(cin,fullname);
    			getline(cin,address);
    			cout << "City:      ";
    			getline(cin,city);
    			getline(cin,country);
    			cin >> correct;
    				string buffer = fullname + ":" + address + ":" + city + ":" + country + "#";
    				const char* c_buffer = buffer.c_str();
    				int l_buffer = buffer.length();
    				create_profile.write(c_buffer,l_buffer);
    				return 0;
    		return 1;
Problem mit Texteingabe - Ähnliche Themen
  1. Virtualboxproblem
  4. Probleme mit YUM
