Problem bei kdebluetooth [emerge]
Diskutiere Problem bei kdebluetooth [emerge] im Gentoo Forum im Bereich Linux Distributionen; Hallo ! Wenn ich: emerge /usr/portage/net-wireless/kdebluetooth/kdebluetooth-20040416.ebuild eingebe, bekomme ich ab dem make Befehl...
  1. Yaddi
    Yaddi Routinier
    30.06.2004
    277
    Gronau
    Hallo !
    Wenn ich:
    eingebe, bekomme ich ab dem make Befehl folgenden Fehler:
    <br>
    Good - your configure finished. Start make now
    make all-recursive
    make[1]: Entering directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416'
    Making all in doc
    make[2]: Entering directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc'
    Making all in .
    make[3]: Entering directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc'
    make[3]: Nothing to be done for `all-am'.
    make[3]: Leaving directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc'
    Making all in kdebluetooth
    make[3]: Entering directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc/kdebluetooth'
    /usr/kde/3.2/bin/meinproc --check --cache index.cache.bz2 ./index.docbook
    make[3]: *** [index.cache.bz2] Error 139
    make[3]: Leaving directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc/kdebluetooth'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416/doc'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/var/tmp/portage/kdebluetooth-20040416/work/kdebluetooth-0.0.20040416'
    make: *** [all] Error 2
    !!! ERROR: net-wireless/kdebluetooth-20040416 failed.
    !!! Function kde_src_compile, Line 129, Exitcode 2
    !!! died running emake, kde_src_compile:make
    Finde allerdings keine Lösung, kann mir jemand dabei helfen ?
    Benni
  3. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    Hmmmm ....
    Welche KDE Version hast du laufen ?
  4. Yaddi
    Yaddi Routinier
    30.06.2004
    277
    Gronau
    Bei mir läuft die Version 3.2.2
  5. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    Bei mir lief die aufm beiden rechnern ohne probleme durch !
    Könnte dir ein fertiges Packet anbieten ...
  6. Yaddi
    Yaddi Routinier
    30.06.2004
    277
    Gronau
    Komm ich drauf zurück wenns gleich nich geht,
    das komische ist ja vor ein paar Tagen konnte ich es installiern, habs dann wieder entfernt. Das einzige was ich zwischendrin gemacht hab ist ein update ... Mehr nicht ... Werd jetzt nochmal downgraden und dann nochmal schaun. Wenns dann nicht geht komm ich aufs fertige packet zurück - danke schonmal
  7. devilz
    devilz Pro*phet
    Administrator
    01.05.2002
    12.244
    Ok - kannst dich ja Notfalls per PN melden :)
  9. dragi
    dragi Grünschnabel
    10.10.2003
    ich kann dir zwar keine Lösung anbieten aber ich hatte das Problem das er bei mir nichts ausser den Docs installiert hat. Mit der aktuellen Bluez Version ist das kdebluetooth nicht mehr lauffähig. Es gibt ein neues ebuild, das es aber bis heute nicht ins portage geschafft hat, unter :
    http://bugs.gentoo.org/show_bug.cgi?id=55333
    Vielleicht hilft das ja auch bei diesem problem!
    Bis dahin
    dragi
  10. Yaddi
    Yaddi Routinier
    30.06.2004
    277
    Gronau
    Ich hatte das anders gelöst ...
    Hab mein Update mal mit
    emerge --update --deep world
    laufen lassen, danach hab ichs nochmal versucht und dann gings auf anhieb ...
Problem bei kdebluetooth [emerge] - Ähnliche Themen
  2. Virtualboxproblem
  5. Probleme mit YUM
