mplayer - Problem beim stream rippen
L
LeSid
Ich versuche einen Stream zu rippen, was aber nicht klappt. Benutze ein Ubuntu Dapper, die win32-codecs und avisynth.dll sind installiert.
Vielleicht wird jemand aus dem output von mplayer -v schlau.
Besten Dank für jede Hilfe!
LeSid
user@usercompi:~/SFVideos$ mplayer -v [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
MPlayer 2:0.99+1.0pre7try2+cvs20060117-0ubuntu8 (C) 2000-2006 MPlayer Team
CPU: Intel Celeron 2/Pentium III Coppermine,Geyserville (Family: 6, Stepping: 1)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 0
Compiled with runtime CPU detection.
get_path('codecs.conf') -> '/home/user/.mplayer/codecs.conf'
Reading /home/user/.mplayer/codecs.conf: Can't open '/home/user/.mplayer/codecs.conf': No such file or directory
Reading /etc/mplayer/codecs.conf: 91 audio & 204 video codecs
CommandLine: '-v' 'http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm'
init_freetype
get_path('font/font.desc') -> '/home/user/.mplayer/font/font.desc'
font: can't open file: /home/user/.mplayer/font/font.desc
font: can't open file: /usr/share/mplayer/font/font.desc
Using MMX (with tiny bit MMX2) Optimized OnScreenDisplay
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Using nanosleep() timing
get_path('input.conf') -> '/home/user/.mplayer/input.conf'
Can't open input config file /home/user/.mplayer/input.conf: No such file or directory
Parsing input config file /etc/mplayer/input.conf
Input config file /etc/mplayer/input.conf parsed: 59 binds
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
get_path('sternstunde_20070304.rm.conf') -> '/home/user/.mplayer/sternstunde_20070304.rm.conf'
Playing [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url].
get_path('sub/') -> '/home/user/.mplayer/sub/'
Filename for url is now [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
STREAM_HTTP(1), URL: [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
Resolving real.xobix.ch for AF_INET6...
Couldn't resolve name for AF_INET6: real.xobix.ch
Resolving real.xobix.ch for AF_INET...
Connecting to server real.xobix.ch[146.159.229.31]: 80...
--- HTTP DEBUG HEADER --- START ---
protocol:           [HTTP/1.1]
http minor version: [1]
uri:                [(null)]
method:             [(null)]
status code:        [302]
reason phrase:      [Found]
body size:          [272]
Fields:
 0 - Date: Mon, 09 Apr 2007 09:19:48 GMT
 1 - Server: Apache
 2 - Location: [url]http://helix-v4.sri.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
 3 - Content-Length: 272
 4 - Connection: close
 5 - Content-Type: text/html; charset=iso-8859-1
--- HTTP DEBUG HEADER --- END ---
Filename for url is now [url]http://helix-v4.sri.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
Resolving helix-v4.sri.ch for AF_INET6...
Couldn't resolve name for AF_INET6: helix-v4.sri.ch
Resolving helix-v4.sri.ch for AF_INET...
Connecting to server helix-v4.sri.ch[62.2.180.200]: 80...
protocol:           [HTTP/1.0]
http minor version: [0]
uri:                [(null)]
method:             [(null)]
status code:        [200]
reason phrase:      [OK]
body size:          [0]
Fields:
 0 - Date: Mon, 09 Apr 2007 10:19:48 GMT
 1 - Server: RealServer
 2 - Content-Type: audio/x-pn-realaudio
 3 - Pragma: no-cache
 4 - Last-Modified: Thu, 01 Jan 1970 00:00:00 GMT
 5 - Content-Length: 222
Content-Type: [audio/x-pn-realaudio]
Content-Length: [222]
Cache size set to 320 KBytes
STREAM: [null] [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
STREAM: Description: http streaming
STREAM: Author: Bertrand, Albeau, Reimar Doeffinger, Arpi?
STREAM: Comment: plain http
CACHE_PRE_INIT: 0 [0] 0  pre:65536  eof:0
Cache fill:  0.07% (222 bytes)
Checking for YUV4MPEG2
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url] ext: .rm
Trying demuxer 11 based on filename extension
Checking for REAL
demuxer: continue fuzzy content-based format guessing...
Checking for Nullsoft Streaming Video
Checking for MOV
Checking for VIVO
header block 1 size: 116
AVS: avs_check_file - attempting to open file [url]http://real.xobix.ch/ramgen/sfdrs/vod/sternstunde/2007/04/450k/sternstunde_20070304.rm[/url]
AVS: failed to load avs_create_script_environment()
AVS: Init failed
Checking for PVA
Checking for MPEG-TS...
THIS DOESN'T LOOK LIKE AN MPEG-TS FILE!
TRIED UP TO POSITION 0, FOUND ffffff00, packet_size= 0, SEEMS A TS? 0
Checking for LMLM4 Stream Format
Invalid packet in LMLM4 stream: ch=29300 size=976170798
LMLM4 Stream Format not found
MPEG Stream reached EOF
ds_fill_buffer: EOF reached (stream: video)
MPEG packet stats: p100: 0  p101: 0 p1B6: 0 p12x: 0 sli: 0 a: 0 b: 0 c: 0 idr: 0 sps: 0 pps: 0 PES: 0  MP3: 0, synced: 0
Not MPEG System Stream format... (maybe Transport Stream?)
MPEG packet stats: p100: 0  p101: 0 p1B6: 0 p12x: 0 sli: 0 a: 0 b: 0 c: 0 idr: 0 sps: 0 pps: 0 PES: 0  MP3: 0, synced: 3
Checking for DV
demux_aac_probe, failed to detect an AAC stream
vo: x11 uninit called but X11 not inited..
Exiting... (End of file)
wenn du code-tags benutzt wäre es übersichtlicher!!!
Hast du die "dumpstream"-Option ausprobiert?
/usr/bin/mplayer mms://a1709.l751822020.c7518.e.lm.akamaistream.net/D/1709/7518/v0001/reflector:22020 -dumpstream -dumpfile /media/hda3/wdr5/wdr5.wma
legt den wdr5-stream auf /hda3/wdr5 ab. mußt du nur noch mit deinem stream austauschen.
Danke für die Hinweise!
@ Shorti: Code-Tags sind nun drin
@madhatter und @ Dosenfleisch: Die dumpstream-Option ergibt das unten stehende.
Ich vermute, es hat etwas mit dem Stream zu tun, denn die meister der hier angegebenen streams kann ich abspielen. Spielt der Stream http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm bei Euch? Auf meiner Windows-Kiste funzt es, da es das Laptop der Firma ist, kann ich keine Programme wie den Streamripper installieren.
sidi@sidicompi:~$ mplayer -v http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm -dumpstream -dumpfile /home/sidi/SFVideos/Sternstunde20070304.wma
get_path('codecs.conf') -> '/home/sidi/.mplayer/codecs.conf'
Reading /home/sidi/.mplayer/codecs.conf: Can't open '/home/sidi/.mplayer/codecs.conf': No such file or directory
CommandLine: '-v' 'http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm' '-dumpstream' '-dumpfile' '/home/sidi/SFVideos/Sternstunde20070304.wma'
init_freetype
get_path('font/font.desc') -> '/home/sidi/.mplayer/font/font.desc'
font: can't open file: /home/sidi/.mplayer/font/font.desc
get_path('input.conf') -> '/home/sidi/.mplayer/input.conf'
Can't open input config file /home/sidi/.mplayer/input.conf: No such file or directory
get_path('vo...de_20070304.rm.conf') -> '/home/sidi/.mplayer/vo...de_20070304.rm.conf'
Playing http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm.
get_path('sub/') -> '/home/sidi/.mplayer/sub/'
Filename for url is now http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm
STREAM_HTTP(1), URL: http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm
uri:                [(null)]
method:             [(null)]
status code:        [302]
body size:          [239]
Fields:
 0 - Date: Thu, 12 Apr 2007 09:48:37 GMT
 1 - Server: Apache
 2 - Location: http://helix-v4.sri.ch/ramgen/sfdrs/vo...de_20070304.rm
 3 - Content-Length: 239
Filename for url is now http://helix-v4.sri.ch/ramgen/sfdrs/vo...de_20070304.rm
uri:                [(null)]
method:             [(null)]
status code:        [200]
reason phrase:      [OK]
body size:          [0]
Fields:
 0 - Date: Thu, 12 Apr 2007 10:48:37 GMT
 5 - Content-Length: 156
Content-Length: [156]
STREAM: [null] http://real.xobix.ch/ramgen/sfdrs/vo...de_20070304.rm
Stream not seekable!
Core dumped ;)
Akonadi startet nicht mehr
