mehrere PCI-Geräte auf dem gleichen IRQ
Diskutiere mehrere PCI-Geräte auf dem gleichen IRQ im RedHat,Fedora & CentOS Forum im Bereich Linux Distributionen; folgende ausgabe bei mit dem befehl lspci -v 00:00.0 Host bridge: VIA Technologies, Inc. VT8377 [KT400/KT600 AGP] Host Bridge Subsystem: VIA...
  1. dmaphy
    dmaphy Routinier
    16.04.2004
    482
    Hamburg
    	Subsystem: VIA Technologies, Inc.: Unknown device 0000
    	Flags: bus master, 66Mhz, medium devsel, latency 8
    	Memory at e0000000 (32-bit, prefetchable) [size=128M]
    	Capabilities: [a0] AGP version 2.0
    	Capabilities: [c0] Power Management version 2
    00:01.0 PCI bridge: VIA Technologies, Inc. VT8235 PCI Bridge (prog-if 00 [Normal decode])
    	Flags: bus master, 66Mhz, medium devsel, latency 0
    	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    	Memory behind bridge: dde00000-dfefffff
    	Prefetchable memory behind bridge: cdc00000-ddcfffff
    	Capabilities: [80] Power Management version 2
    00:06.0 RAID bus controller: Integrated Technology Express, Inc. IT/ITE8212 Dual channel ATA RAID controller (PCI version seems to be IT8212, embedded seems (rev 13)
    	Flags: bus master, 66Mhz, medium devsel, latency 0, IRQ 10
    	I/O ports at ec00 [size=8]
    	I/O ports at e800 [size=4]
    	I/O ports at e400 [size=8]
    	I/O ports at e000 [size=4]
    	I/O ports at dc00 [size=16]
    	Expansion ROM at dffe0000 [disabled] [size=128K]
    00:07.0 Ethernet controller: MYSON Technology Inc SURECOM EP-320X-S 100/10M Ethernet PCI Adapter
    	Subsystem: Sundance Technology Inc: Unknown device 6020
    	Flags: bus master, medium devsel, latency 32, IRQ 5
    	I/O ports at d800 [size=256]
    	Memory at dffdfc00 (32-bit, non-prefetchable) [size=1K]
    	Capabilities: [88] Power Management version 2
    00:0a.0 Network controller: Texas Instruments ACX 111 54Mbps Wireless Interface
    	Subsystem: Abocom Systems Inc: Unknown device ab90
    	Flags: bus master, medium devsel, latency 32, IRQ 10
    	Memory at dffdc000 (32-bit, non-prefetchable) [size=8K]
    	Memory at dffa0000 (32-bit, non-prefetchable) [size=128K]
    	Capabilities: [40] Power Management version 2
    00:0b.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
    	Subsystem: Hercules: Unknown device a650
    	I/O ports at d400 [size=256]
    00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
    	Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
    	Flags: bus master, medium devsel, latency 32, IRQ 11
    	I/O ports at c800 [size=32]
    00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
    	I/O ports at cc00 [size=32]
    00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 80) (prog-if 00 [UHCI])
    	I/O ports at d000 [size=32]
    00:10.3 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 82) (prog-if 20 [EHCI])
    	Subsystem: VIA Technologies, Inc. USB 2.0
    	Memory at dffdfb00 (32-bit, non-prefetchable) [size=256]
    00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
    	Flags: bus master, stepping, medium devsel, latency 0
    00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
    	Subsystem: VIA Technologies, Inc. VT82C586/B/VT82C686/A/B/VT8233/A/C/VT8235 PIPC Bus Master IDE
    	Flags: bus master, medium devsel, latency 32, IRQ 255
    	I/O ports at fc00 [size=16]
    00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 50)
    	Subsystem: Micro-Star International Co., Ltd.: Unknown device 7120
    	Flags: medium devsel, IRQ 5
    	I/O ports at c400 [size=256]
    00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102 [Rhine-II] (rev 74)
    	I/O ports at c000 [size=256]
    	Memory at dffdfa00 (32-bit, non-prefetchable) [size=256]
    01:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 440] (rev a3) (prog-if 00 [VGA])
    	Flags: bus master, 66Mhz, medium devsel, latency 248, IRQ 11
    	Memory at de000000 (32-bit, non-prefetchable) [size=16M]
    	Memory at d0000000 (32-bit, prefetchable) [size=128M]
    	Memory at ddc80000 (32-bit, prefetchable) [size=512K]
    	[virtual] Expansion ROM at dfee0000 [disabled] [size=128K]
    	Capabilities: [60] Power Management version 2
    	Capabilities: [44] AGP version 2.0
    besondere aufmerksamkeit möchte ich auf die abschnitte lenken,
    in denen der IRQ = 10 ist, einmal ein RAID-Controller mit festplatte, da ist musik drauf und xmms hängt sich immer auf, wenn ich zweitens:
    mit dem WLAN rumspiele, welches ich irgendwie immernoch nicht zum laufen bringe, aber das ist eine andere sache, es sei denn es hängt hiermit zusammen.
    soweit eine interessante beobachtung, jetz die frage:
    kann ich der WLAN-Karte vielleicht einen eigenen IRQ oder so zuweisen?
mehrere PCI-Geräte auf dem gleichen IRQ - Ähnliche Themen
  1. [Gelöst] Suchen und ersetzen mit Hilfe mehrerer Parameter
    [Gelöst] Suchen und ersetzen mit Hilfe mehrerer Parameter: Hallo zusammen, ich bin an einem Punkt angekommen, wo ich nicht mehr weiter komme und hoffe ihr könnt mir weiter helfen. Anbei ein Ausschnitt aus...
  2. Mehrere SSL Vhosts
    Mehrere SSL Vhosts: Hey zusammen, Ich habe zwei verschiedene VHosts mit einem Apache 2.4 am rennen. <VirtualHost *:80> ServerName test1.de DocumentRoot...
  3. Reverse Proxy einrichten für mehrere subdomains über Port 80
    Reverse Proxy einrichten für mehrere subdomains über Port 80: Guten Tag zusammen. Ich habe folgendes Problem. Bei mir laufen 2 Apache-Tomcat Services. Einer auf Port 8880 und einer auf Port 8080. Nun habe...
  4. Problem mit 1er Freigabe und mehreren Ordnern
    Problem mit 1er Freigabe und mehreren Ordnern: Hallo Ich habe auf unseren home Server das Neuste Debian mit der neusten stabilen Samba Version. Ich habe eine Freigabe die die mehrere Ordner...
  5. Artikel: Synergy - Mehrere PCs mit einer Maus steuern
    Artikel: Synergy - Mehrere PCs mit einer Maus steuern: Auf dem Schreibtisch steht oft mehr als ein Monitor, und oft gesellt sich dazu noch ein Notebook. Mit der Client-Server-Anwendung Synergy lassen...
