Limewire Problem
Diskutiere Limewire Problem im Sandkasten Forum im Bereich Sonstiges; :hilfe2: ich brauche dringend hilfe leut :help: ich hab limewire version 4.10.9 installiert bekomme aber diese nachricht: LimeWire version...
  1. Bahar
    Bahar Grünschnabel
    10.04.2006
    LimeWire version 4.10.9
    Java version 1.5.0_06 from Sun Microsystems Inc.
    Windows XP v. 5.1 on x86
    Free/total memory: 506760/9437184
    FATAL ERROR!
    java.lang.ExceptionInInitializerError
    at com.limegroup.gnutella.RouterService.start(RouterService.java:423)
    at com.limegroup.gnutella.gui.Initializer.initialize(Initializer.java:300)
    at com.limegroup.gnutella.gui.GUILoader.load(GUILoader.java:41)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.limegroup.gnutella.gui.Main.main(Main.java:44)
    Caused by: java.lang.IllegalStateException: unread block data
    at java.io.ObjectInputStream$BlockDataInputStream.setBlockDataMode(Unknown Source)
    at java.io.ObjectInputStream.readObject0(Unknown Source)
    at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
    at java.io.ObjectInputStream.readSerialData(Unknown Source)
    at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
    at java.io.ObjectInputStream.readObject(Unknown Source)
    at java.util.HashMap.readObject(Unknown Source)
    at sun.reflect.GeneratedMethodAccessor14.invoke(Unknown Source)
    at java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
    at com.limegroup.gnutella.spam.RatingTable.readData(RatingTable.java:214)
    at com.limegroup.gnutella.spam.RatingTable.<init>(RatingTable.java:58)
    at com.limegroup.gnutella.spam.RatingTable.<clinit>(RatingTable.java:34)
    ... 8 more
    -- listing session information --
    Current thread: main
    Active Threads: 30
    Uptime: 0:05
    Is Connected: false
    Number of Ultrapeer -> Ultrapeer Connections: 0
    Number of Ultrapeer -> Leaf Connections: 0
    Number of Leaf -> Ultrapeer Connections: 0
    Number of Old Connections: 0
    Acting as Ultrapeer: false
    Acting as Shielded Leaf: false
    Number of Active Uploads: 0
    Number of Queued Uploads: 0
    Number of Active HTTP Downloaders: 0
    Received incoming this session: false
    Number of Shared Files: 98
    Guess Capable: false
    Received Solicited UDP: true
    SIMPP version: 46
    Port Stable: true
    FWT Capable: true
    Last Reported Port: 19844
    External Port: 19844
    IP Pongs Received: 14
    -- listing threads --
    SavedFileLoader: 1
    NIODispatcher: 1
    Image Fetcher 2: 1
    UDPHostRanker: 1
    DownloadWorker: 1
    main: 1
    MulticastService: 1
    Acceptor: 1
    AWT-EventQueue-0: 1
    AWT-Windows: 1
    AWT-Shutdown: 1
    Image Fetcher 1: 1
    Timer-0: 1
    Image Fetcher 0: 1
    Image Fetcher 3: 1
    IconLoader: 1
    MessageDispatch: 1
    ConnectionFetcher: 4
    FileManagerLoader: 1
    Thread-9: 1
    QueryUnicaster: 1
    ManagedDownload: 1
    Java2D Disposer: 1
    TimerQueue: 1
    QRPPropagator: 1
    UpdateHandler: 1
    HTTPAcceptor: 1
    -- listing properties --
    FILTER_HASH_QUERIES=true
    APP_HEIGHT=760
    FRACTIONAL_UPTIME=0.27325407
    LAST_EXPIRE_TIME=1143852743156
    SESSIONS=68
    LAST_ACCEPTABLE_BUG_VERSION=4.10.10
    UPDATE_DOWNLOAD_DELAY=10000000
    RUN_ONCE=true
    COUNTRY=
    MIN_CONNECT_TIME=7
    UI_LIBRARY_PLAY_LIST_TAB_DIVIDER_LOCATION=420
    CLIENT_ID=8084F552A1C127440C1065F9B8D9D600
    LAST_SHUTDOWN_TIME=1144166044921
    DAAP_PORT=5216
    MAX_UPLOAD_BYTES_PER_SEC=29
    IDLE_CONNECTIONS=2
    DAAP_ENABLED=false
    PORT=19844
    TOTAL_UPTIME=523482
    AVERAGE_UPTIME=7931
    UNSET_FIREWALLED_FROM_CONNECTBACK=true
    RUN_ON_STARTUP=false
    UPDATE_GIVEUP_FACTOR=24
    FLUSH_DELAY_TIME=256
    APP_WIDTH=1280
    INSTALLED=true
    MAX_SIM_DOWNLOAD=20
    LAST_GWEBCACHE_FETCH_TIME=1143928008765
    UI_LIBRARY_TREE_DIVIDER_LOCATION=195
    CONNECTION_SPEED=350
    WINDOW_Y=-4
    MAX_DOWNLOAD_BYTES_PER_SEC=218
    UPDATE_DELAY=252000020
    WINDOW_X=-4
    UI_MONITOR_UPLOAD_TAB_DIVIDER_LOCATION=274
    was kann ich machen wie komm ich weiter hilft mir bitte
    vielen dank :(
  3. #2 Commodore-Freak, 10.04.2006
    Commodore-Freak
    Commodore-Freak Grünschnabel
    30.01.2006
    5
    Dieses Forum ist nicht für Windows Probleme zuständig...
  4. Bahar
    Bahar Grünschnabel
    10.04.2006
    wo muß ich dann hinund fragen? sorry bin neu hier :(
  5. #4 root1992, 10.04.2006
    root1992
    02.01.2006
    1.138
    Märchenwald
    Na in einem Win forum. Oder du Installierst dir ein UNIX.
  6. #5 Nemesis, 10.04.2006
    Nemesis
    Nemesis N3RD
    28.01.2005
    2.165
Limewire Problem
Limewire Problem - Ähnliche Themen
  1. LimeWire Problem beim Ausführen
    LimeWire Problem beim Ausführen: Ich habe auf meinem Mandriva 2006 LimeWire installiert.. Beim Ausführen des Programms kommt nur der SplashScreen und dann passiert nichts.....
  2. LimeWire Abhängigkeit
    LimeWire Abhängigkeit: Hi, ich bräuchte eben mal einen Rat ;) Hab mir grad das "LimeWire-free-4.8.1-0" RPM gezogen. Bevor ich RPM's installiere, teste ich i.d.R mit...
  3. Virtualboxproblem
