DB2 Foreign Key Problem
Diskutiere DB2 Foreign Key Problem im SQL und Datenbanken Forum im Bereich Netzwerke & Serverdienste; Guten Tag zusammen, Ich habe folgendes Problem: Ich möchte über mehrere DB2 Tabellen eine Userverwaltung mir folgendem SQL aufbauen: CREATE...
  1. #1 element, 31.01.2008
    element
    element Guest
    Guten Tag zusammen,
    CREATE TABLE USERS (
      U_ID INTEGER NOT NULL GENERATED ALWAYS AS IDENTITY (START WITH 0, INCREMENT BY 1) PRIMARY KEY ,
      USERNAME VARCHAR(10) NOT NULL,
      NAME VARCHAR(64) NOT NULL,
      LOCKED INTEGER NOT NULL
    CREATE TABLE COMPS (
      C_ID INTEGER NOT NULL GENERATED ALWAYS AS IDENTITY (START WITH 0, INCREMENT BY 1) PRIMARY KEY ,
      COMP VARCHAR(3) NOT NULL,
      COMPNAME VARCHAR(64) NOT NULL
    CREATE TABLE GROUPS (
      G_ID INTEGER NOT NULL GENERATED ALWAYS AS IDENTITY (START WITH 0, INCREMENT BY 1) PRIMARY KEY ,
    CREATE TABLE PGMS (
      P_ID INTEGER NOT NULL GENERATED ALWAYS AS IDENTITY (START WITH 0, INCREMENT BY 1) PRIMARY KEY ,
      CLASS VARCHAR(64) NOT NULL,
      DIRECTORY VARCHAR(128) NOT NULL,
      DESCRIPTION VARCHAR(256) NOT NULL,
      PGMCALL VARCHAR(64) NOT NULL,
    CREATE TABLE GROUPPGMS (
      P_ID INTEGER NOT NULL,
      G_ID INTEGER NOT NULL,
      LOCKED INTEGER NOT NULL,
      RW INTEGER NOT NULL,
      CONSTRAINT GROUPPGMS_P_ID FOREIGN KEY (P_ID) REFERENCES PGMS (P_ID) ON DELETE CASCADE,
      CONSTRAINT GROUPPGMS_G_ID FOREIGN KEY (G_ID) REFERENCES GROUPS (G_ID) ON DELETE CASCADE
    CREATE TABLE GRPCOMP (
      C_ID INTEGER NOT NULL,
      CONSTRAINT GRPCOMP_G_ID FOREIGN KEY (G_ID) REFERENCES GROUPS (G_ID) ON DELETE CASCADE,
      CONSTRAINT GRPCOMP_C_ID FOREIGN KEY (C_ID) REFERENCES COMPS (C_ID) ON DELETE CASCADE
    CREATE TABLE USERCOMP (
      U_ID INTEGER NOT NULL,
      CONSTRAINT USERCOMP_C_ID FOREIGN KEY (C_ID) REFERENCES COMPS (C_ID) ON DELETE CASCADE,
      CONSTRAINT USERCOMP_U_ID FOREIGN KEY (U_ID) REFERENCES USERS (U_ID) ON DELETE CASCADE
    CREATE TABLE USERGRPS (
      CONSTRAINT USERGRPS_U_ID FOREIGN KEY (U_ID) REFERENCES USERS (U_ID) ON DELETE CASCADE,
      CONSTRAINT USERGRPS_G_ID FOREIGN KEY (G_ID) REFERENCES GROUPS (G_ID) ON DELETE CASCADE
    CREATE TABLE USERPGMS (
      ACCESS INTEGER NOT NULL,
      CONSTRAINT USERPGMS_P_ID FOREIGN KEY (P_ID) REFERENCES PGMS (P_ID) ON DELETE CASCADE,
      CONSTRAINT USERPGMS_U_ID FOREIGN KEY (U_ID) REFERENCES USERS (U_ID) ON DELETE CASCADE
    Nun habe ich folgendes Problem:
    Wenn ich in der "USERS" eine Datensatz einfüge mit einem normalen "INSERT INTO ...." kann ich diesen nicht mehr löschen.
    Kann mir da vllt. jemand helfen?
    mfg element
  3. rdg
    rdg ???
    12.10.2006
    357
    Berlin
    ich würd mal sagen das du vorher die Referenzen löschen musste und dann erst den User, sonnst zerschiest du dir gleich deine DB
    dort wo:
    CONSTRAINT ... REFERENCES USERS (U_ID) ON DELETE CASCADE
    steht
  4. #3 element, 31.01.2008
    element
    element Guest
    Ne das glaube ich nciht das das dann ja nciht der Sinn von Referensen ist. Oder sehe ich das flasch? Kann dienen vorschlag leider grade nciht ausprobieren sonst würde ich es testen
  5. #4 rdg, 31.01.2008
    rdg
    rdg ???
    12.10.2006
    357
    Berlin
    Naja, ohne unhöflich klingen zu wollen, worin siehst du denn den Sinn von Referenzen?
    gruß
    rdg
    warte mal ...
    doch ich bleibe dabei, warum sonst Fremdschlüssel mit UID?!
    hast mich ganz schön durcheinander gebracht. ;)
    http://de.wikipedia.org/wiki/Referenzielle_Integrität
    ...Datenbank stellt sicher, dass der Primärschlüssel existiert und nur gemeinsam mit dem Fremdschlüssel geändert oder gelöscht werden kann.
  6. #5 element, 04.02.2008
    element
    element Guest
    Genau das war mein Ziel. Nur kann ich keinen Benutzer löschen obwohl in der Detailtabelle keine Daten vorhanden sind.
DB2 Foreign Key Problem - Ähnliche Themen
  1. MySQL 5 foreign keys Problem
    MySQL 5 foreign keys Problem: Hallo zusammen ACHTUNG PROBLEM HAT SICH ERLEDIGT... packagescript war nicht engine=innodb! Habs nach dem Absenden bemerkt :)) Ich habe 3...
  2. Datentyp für foreign key postresql
    Datentyp für foreign key postresql: Hi! Also ich muss für die Uni eine postgresql Datenbank erstellen mit den dazugehörigen joint Befehlen! Ich habe bereits drei Tabellen...
  3. mysql 5 kennt keine foreign keys?
    mysql 5 kennt keine foreign keys?: Morgen. Ich hab in nem Buch zu Mysql 4.1 gelesen, dass MySQL keine Foreign Keys kennen würde. Kann das sein, dass selbst die 5.0 er MySQL...
  4. POST requests from foreign hosts are not allowed.
    POST requests from foreign hosts are not allowed.: POST requests from foreign hosts are not allowed. Das kommt wenn ich mich versuche über die Startseite"www.unixboard.de" versuche einzuloggen....
  5. Problem mit Windows auf Ordner auf dem Linuxsystem zuzugreifen
