Notebook:/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0 # make
make -C /lib/modules/2.6.22.18-0.2-default/build SUBDIRS=/home/marcel/Documents/
programme/RT25USB-SRC-V2.0.8.0 modules
make[1]: Entering directory `/usr/src/linux-2.6.22.18-0.2-obj/i386/default'
make -C ../../../linux-2.6.22.18-0.2 O=../linux-2.6.22.18-0.2-obj/i386/default m
odules
CC [M] /home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.o
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c: In function
‘CMDHandler’:
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1079: warning
: unused variable ‘pkey’
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1078: warning : unused variable ‘i’
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c: In function ‘usb_rtusb_probe’:
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1779: error: ‘struct net_device’ has no member named ‘get_wireless_stats’
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1807: error: ‘dev_base’ undeclared (first use in this function)
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1807: error: (Each undeclared identifier is reported only once
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1807: error: for each function it appears in.)
/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.c:1807: error: ‘struct net_device’ has no member named ‘next’
make[4]: *** [/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0/rtusb_main.o ] Fehler 1
make[3]: *** [_module_/home/marcel/Documents/programme/RT25USB-SRC-V2.0.8.0] Feh ler 2
make[2]: *** [modules] Fehler 2
make[1]: *** [modules] Fehler 2
make[1]: Leaving directory `/usr/src/linux-2.6.22.18-0.2-obj/i386/default'
make: *** [all] Fehler 2
