Brennen macht Probleme (Brasero,Xubuntu)
S
softcreate
GESPERRT
Brasero log file vom 23.8.12
Checking session consistency (brasero_burn_check_session_consistency brasero-burn.c:1739)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroLocalTrack called brasero_job_set_output_size_for_current_track
BraseroLocalTrack stopping
BraseroLocalTrack called brasero_job_get_session_output_size
BraseroLocalTrack called brasero_job_get_current_track
BraseroLocalTrack no remote URIs
BraseroChecksumFiles called brasero_job_get_output_type
BraseroChecksumFiles called brasero_job_get_current_track
BraseroChecksumFiles called brasero_job_get_action
Brase
raseroLibburn called brasero_job_set_current_action
BraseroLibburn called brasero_job_get_session_output_size
BraseroLibburn called brasero_job_set_current_action
BraseroLibburn Libburn reported an error Exceeding range of permissible write addresses (2295104 >= 2295104)
BraseroLibburn called brasero_job_error
BraseroLibburn finished with an error
BraseroLibburn asked to stop because of an error
error = 1
message = "Exceeding range of permissible write addresses (2295104 >= 2295104)"
BraseroLibburn stopping
BraseroLibburn closing connection for BraseroLibburn
Session error : Exceeding range of permissible write addresses (2295104 >= 2295104) (brasero_burn_record brasero-burn.c:2856)
Guten Morgen. Ich wollte brennen mit Pangolin, aber es klappte nicht. Habe hier von der Fehlermeldung Anfang und Ende einkopiert.
Bin Laie und Anfänger.
Edit
k3b sagt: Brennen erfolgreich und die CD oder DVD ist leer.
29812 19 Uhr 03.
teste low-level brennen in einer konsole:
ALT-F2, "konsole" eingeben.
sudo -s
wodim dev=/dev/sr0 /pfad/zu/einem/image.iso
Danke. Es hat geklappt. Da ich Anfänger bin
was ist der Unterschied von alt-f2
und Terminal aufrufen?
Werde dann über Konsole brennen und bin froh, dass der Brenner nicht defekt ist.
Wie kann Linux feststellen ob Brenner defekt ist oder Hardware?
ALT-F2 stellt lediglich eine minimale "Eingabeaufforderung" zur Verfügung, "konsole" (d.h. "/usr/bin/konsole") ist dann ein Fenster, das Dir eine SHELL zur Eingabe von Befehlen bietet.
Grundsätzlich ist die z.B. Ausgabe von
dmesg | tail -50
ein Startpunkt, dessen Ausgabe der Suchmaschine Deines geringsten Misstrauens gefüttert sein darf.
Danke für Hilfe. Brenner ist ok.
Wie geht brennen mit Konsole? Habe zwar viel im www gefunden, komme aber nicht damit zurecht.
zB habe ich das gefunden:
mkisofs -r /tmp/datendirectory | cdrecord -v -eject -driveropts=burnfree fs=6m speed=24 dev=0,1,0 -
Ist cdrecord der richtige Befehl?
Ich will backup machen also im ordner abc die beiden Dateien a.zip und b.zip
Brasero macht ab und zu Probleme, habe den Verdacht, das Problem sind zu lange Dateinamen. Wie kann ich das verhindern, weil zippen in a.zip oder ae. hat das Problem nicht gelöst.
Langfristig ist mir aber, wenn ich es verstehe, die Konsole lieber.
Danke für Hife.
CentOS 6.3 RADIUS - Keine Verbindung möglich
Samba Update von 3.2.5 auf 3.5.6 - Probleme beim Server Browsen
Probleme bei erster Gentoo Installation
