ATI 8.8.25 + KDE + XOrg 6.8 | Nur 1 Problem noch!
Diskutiere ATI 8.8.25 + KDE + XOrg 6.8 | Nur 1 Problem noch! im KDE Forum im Bereich X Window; Ich hab jetzt mal die neuen ATI Treiber zum Laufen bekommen, ohne das der KDE einfriert. SUSE9.2 + Xorg6.8.0 ATI X800Pro Nur paar...
  1. toooml
    toooml Grünschnabel
    01.02.2005
    SUSE9.2 + Xorg6.8.0
    ATI X800Pro
    Nur paar Darstellungsfehler hab ich :(.
    [​IMG]
    Hier meine Config fürn Xorg
    xorg.conf
    # File: XF86Config-4
    # File generated by fglrxconfig (C) ATI Research, a substitute for xf86config.
    # DRI Section
    Section "dri"
        Mode 0666
    EndSection
    Section "Module"
        Load "dbe"  	# Double buffer extension
        Load "type1"
        Load "freetype"
        Load "dri"   # libdri.a
        Load "/usr/X11R6/lib/modules/extensions/libglx.a"
        Subsection "extmod"
            Option "omit xfree86-dga"   # don't initialise the DGA extension
        EndSubsection
    EndSection
    Section "Files"
        # The location of the RGB database.  Note, this is the name of the
        # file minus the extension (like ".txt" or ".db").  There is normally
        # no need to change the default.
        RgbPath "/usr/X11R6/lib/X11/rgb"
        # Multiple FontPath entries are allowed (which are concatenated together),
        # as well as specifying multiple comma-separated entries in one FontPath
        # command (or a combination of both methods)
        # If you don't have a floating point coprocessor and emacs, Mosaic or other
        # programs take long to start up, try moving the Type1 and Speedo directory
        # to the end of this list (or comment them out).
        # FontPath   "/usr/X11R6/lib/X11/fonts/local/"
        FontPath "/usr/X11R6/lib/X11/fonts/misc/"
        FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
        # FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
        FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
        FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
        FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
        # FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
        # The module search path.  The default path is shown here.
        # ModulePath "/usr/X11R6/lib/modules"
    EndSection
    # Server flags section.
    Section "ServerFlags"
        EndSection
    # Uncomment this to cause a core dump at the spot where a signal is
    # received.  This may leave the console in an unusable state, but may
    # provide a better stack trace in the core dump to aid in debugging
    # Option "NoTrapSignals"
    # Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
    # This allows clients to receive this key event.
    # Option "DontZap"
    # Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
    # sequences.  This allows clients to receive these key events.
    # Option "Dont Zoom"
    # Uncomment this to disable tuning with the xvidtune client. With
    # it the client can still run and fetch card and monitor attributes,
    # but it will not be allowed to change them. If it tries it will
    # receive a protocol error.
    # Option "DisableVidModeExtension"
    # Uncomment this to enable the use of a non-local xvidtune client.
    # Option "AllowNonLocalXvidtune"
    # Uncomment this to disable dynamically modifying the input device
    # (mouse and keyboard) settings.
    # Option "DisableModInDev"
    # Uncomment this to enable the use of a non-local client to
    # change the keyboard or mouse settings (currently only xset).
    # Option "AllowNonLocalModInDev"
    # Input devices
    # Core keyboard's InputDevice section
    Section "InputDevice"
        Identifier "Keyboard1"
        Driver "keyboard"
        # Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
        # Option "Xleds"      "1 2 3"
        # Option "LeftAlt"    "Meta"
        # Option "RightAlt"   "ModeShift"
        # To customise the XKB settings to suit your keyboard, modify the
        # lines below (which are the defaults).  For example, for a non-U.S.
        # keyboard, you will probably want to use:
        # Option "XkbModel"   "pc102"
        # If you have a US Microsoft Natural keyboard, you can use:
        # Option "XkbModel"   "microsoft"
        # Then to change the language, change the Layout setting.
        # For example, a german layout can be obtained with:
        # Option "XkbLayout"  "de"
        # or:
        # Option "XkbVariant" "nodeadkeys"
        # If you'd like to switch the positions of your capslock and
        # control keys, use:
        # Option "XkbOptions" "ctrl:swapcaps"
        # These are the default XKB settings for XFree86
        # Option "XkbRules"   "xfree86"
        # Option "XkbModel"   "pc101"
        # Option "XkbLayout"  "us"
        # Option "XkbVariant" ""
        # Option "XkbOptions" ""
        # Option "XkbDisable"
        # For most OSs the protocol can be omitted (it defaults to "Standard").
        # When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
        # uncomment the following line.
        # Option "Protocol"   "Xqueue"
        Option "AutoRepeat" "500 30"
    EndSection
    # Core Pointer's InputDevice section
        # Identifier and driver
        Identifier "Mouse1"
        Driver "mouse"
        Option "Protocol" "ImPS/2"
        # When using XQUEUE, comment out the above two lines, and uncomment
        # the following line.
        # Baudrate and SampleRate are only for some Logitech mice. In
        # almost every case these lines should be omitted.
        # Option "BaudRate"   "9600"
        # Option "SampleRate" "150"
        # Emulate3Buttons is an option for 2-button Microsoft mice
        # Emulate3Timeout is the timeout in milliseconds (default is 50ms)
        Option "Emulate3Buttons"
        # Option "Emulate3Timeout"    "50"
        # ChordMiddle is an option for some 3-button Logitech mice
        # Option "ChordMiddle"
        Option "ZAxisMapping" "4 5"
    EndSection
    Section "Monitor"
        Identifier "Monitor0"
        HorizSync 31.5 - 80.5
        VertRefresh 60 - 75
        Option "DPMS"
    EndSection
    Section "Monitor"
        Identifier "Monitor1"
        HorizSync 31.5 - 48.4
        VertRefresh 60 - 75
        Option "DPMS"
    EndSection
    Section "Device"
        Identifier "device1"
        VendorName "ATI"
        BoardName "ATI Radeon (fglrx)"
        Driver "fglrx"
        Screen 0
        BusID "PCI:1:0:0"
        Option "DPMS"
        # === disable PnP Monitor  ===
        #Option                              "NoDDC"
        # === disable/enable XAA/DRI ===
        Option "no_accel"                   "no"
        Option "no_dri"                     "no"
        # === FireGL DDX driver module specific settings ===
        # === Screen Management ===
        Option "DesktopSetup"               "0x00000000"
        Option "MonitorLayout"              "AUTO, AUTO"
        Option "IgnoreEDID"                 "off"
        Option "HSync2"                     "unspecified"
        Option "VRefresh2"                  "unspecified"
        Option "ScreenOverlap"              "0"
        # === TV-out Management ===
        Option "NoTV"                       "yes"
        Option "TVStandard"                 "NTSC-M"
        Option "TVHSizeAdj"                 "0"
        Option "TVVSizeAdj"                 "0"
        Option "TVHPosAdj"                  "0"
        Option "TVVPosAdj"                  "0"
        Option "TVHStartAdj"                "0"
        Option "TVColorAdj"                 "0"
        Option "GammaCorrectionI"           "0x00000000"
        Option "GammaCorrectionII"          "0x00000000"
        # === OpenGL specific profiles/settings ===
        Option "Capabilities"               "0x00000000"
        # === Video Overlay for the Xv extension ===
        Option "VideoOverlay"               "on"
        # === OpenGL Overlay ===
        # Note: When OpenGL Overlay is enabled, Video Overlay
        #       will be disabled automatically
        Option "OpenGLOverlay"              "off"
        Option "CenterMode"                 "off"
        # === QBS Support ===
        Option "Stereo"                     "off"
        Option "StereoSyncEnable"           "1"
        # === Misc Options ===
        Option "UseFastTLS"                 "0"
        Option "BlockSignalsOnLock"         "on"
        Option "UseInternalAGPGART"         "no"
        Option "ForceGenericCPU"            "no"
        # === FSAA ===
        Option "FSAAScale"                  "1"
        Option "FSAADisableGamma"           "no"
        Option "FSAACustomizeMSPos"         "no"
        Option "FSAAMSPosX0"                "0.000000"
        Option "FSAAMSPosY0"                "0.000000"
        Option "FSAAMSPosX1"                "0.000000"
        Option "FSAAMSPosY1"                "0.000000"
        Option "FSAAMSPosX2"                "0.000000"
        Option "FSAAMSPosY2"                "0.000000"
        Option "FSAAMSPosX3"                "0.000000"
        Option "FSAAMSPosY3"                "0.000000"
        Option "FSAAMSPosX4"                "0.000000"
        Option "FSAAMSPosY4"                "0.000000"
        Option "FSAAMSPosX5"                "0.000000"
        Option "FSAAMSPosY5"                "0.000000"
    EndSection
    Section "Device"
        Identifier "device2"
        VendorName "ATI"
        Driver "radeon"
        Screen 0
        BusID "PCI:1:0:1"
        Option "DPMS"
    EndSection
    Section "Screen"
        Identifier "screen1"
        Device "device1"
        Monitor "Monitor0"
        DefaultColorDepth 24
        Subsection "Display"
            Depth 8
            Virtual 1024 768
        EndSubsection
            Depth 15
            Virtual 1024 768
        EndSubsection
            Depth 16
            Virtual 1024 768
        EndSubsection
            Depth 24
            Virtual 1024 768
        EndSubsection
    EndSection
    Section "Screen"
        Identifier "screen2"
        Device "device2"
        Monitor "Monitor1"
            Depth 8
            Virtual 1024 768
        EndSubsection
            Depth 15
            Virtual 1024 768
        EndSubsection
            Depth 16
            Virtual 1024 768
        EndSubsection
            Depth 24
            Virtual 1024 768
        EndSubsection
    EndSection
    # ServerLayout sections.
    # Any number of ServerLayout sections may be present.  Each describes
    # the way multiple screens are organised.  A specific ServerLayout
    # section may be specified from the X server command line with the
    # "-layout" option.  In the absence of this, the first section is used.
    # When now ServerLayout section is present, the first Screen section
    # is used alone.
    Section "ServerLayout"
        # The Identifier line must be present
        Identifier "Server Layout"
        # Each InputDevice line specifies an InputDevice section name and
        # optionally some options to specify the way the device is to be
        # used.  Those options include "CorePointer", "CoreKeyboard" and
        # "SendCoreEvents".
        InputDevice "Mouse1" "CorePointer"
        InputDevice "Keyboard1" "CoreKeyboard"
        Screen "screen1"
        Screen "screen2" RightOf "screen1"
        #Option "Xinerama"
    EndSection
    Schalte ich Option "OpenGLOverlay" "on" startet der KDE zwar, nur das Bild bleibt schwarz, aber Maus etc. ist da.
    Was könnt es da haben?
ATI 8.8.25 + KDE + XOrg 6.8 | Nur 1 Problem noch! - Ähnliche Themen
  1. Hilfe bei Xorg.confi und modprobe
    Hilfe bei Xorg.confi und modprobe: Hi ! Ich hatte mir vor einiger Zeit eine Roccat kone pure geholt (gamer Maus). Als ich versucht habe die Treiber zu installieren lief irgendwas...
  2. Angepasste Minimal-GUI xserver-xorg fvwm2
    Angepasste Minimal-GUI xserver-xorg fvwm2: Moin, ich habe bisher tiefgreifende Erfahrung auf der Kommandozeile, bin aber ein Dummchen für die Linux GUI, es gab einen anderen Thread,...
  3. UseFBDev-parameter bei der xorg.conf
    UseFBDev-parameter bei der xorg.conf: hallo zusammen ich frage mich gerade, was der parameter "UseFBDev" genau bedeutet? tönt irgendwie selbsterklärend, ist es aber scheinbar nicht......
  4. wie definiert man die primäre grafikkarte in xorg.conf
    wie definiert man die primäre grafikkarte in xorg.conf: hallo zusammmen weiss jemand, wie man die primäre grafikkarte in xorg.conf umstellt, z.b. wenn diese nicht die karte ist ab der der rechner...
  5. busid für grafikkarte in xorg.conf ??
    busid für grafikkarte in xorg.conf ??: hallo zusammen, per lspci habe ich die pci id der grafikkarte geholt. diese lautet gemäss den tool: 0003:00:02.0 in der Xorg.0.log steht aber...
